Tricky spinning nut on bolt.... | Page 6 | FerrariChat
Discussion in 'Technical Q&A' started by lotusk, Oct 1, 2014.
  1. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    I'd carefully try a coupling nut with thread cutting oil on the stud instead of a die to straighten the threads-out. a nut will try to “move” material to reshape the threads and a die will “remove” material.
    When testing the thread you should probably use a torque wrench and torque it to where a 6mm bolt should be (70-80 Ft Lbs) because it would be easy to over tighten a 6mm nut and strip the remaining area of the stud.
    If the stud turns-out to be unsalvageable here are a couple choices.
    1) Remove the stud, drill a tap drill size hole into the stud and tap it 6mm. The welded-in head of this stud is probably strong enough to hold a bolt.
    2) . Drill a clearance hole where the stud is and you could probably weld-up some kind of a caged type of thing-nut and lower it into the big hole on the top of the box to catch a bolt inserted into the stud hole?
    3) Additionally, because of that big hole in the top of that “Box” so it may not be a real high stress area you could get a piece of 6mm thick steel about 12mm x 30mm and tap a 6mm hole into one end and cut a hole in the top of that box and lower it to where the hole from the stud is and epoxy it into place on the inside of that box.
  2. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Mark...
    Thanks..one query...
    If i go down route number 1 how would i tap the hole into the bolt head when there is not enuf space to use the tap holder tool to rotate the tap?
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Forget using a die, you'll do more damage. If you want to repair threads ( probably unnecessary) the proper tool is a re-threader. The size there is M6x1.00. It looks like a 6mm nut and takes a 10mm wrench or socket. As I have recommended before, just put a few washers on and a new nut. It's really that simple.
  4. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Drill a hole slightly smaller than the tap, then just lock the back end of the tap tightly in a pair of vice grips and you can usually cut new threads like that. Use cutting oil. If it gets tough to turn stick a screw driver in a space in the vice grips for leverage.
  5. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Ok
    Got it
    Hoping the washers and new nut will do it
  6. BJJ
    BJJ Formula 3
    1,301
    Correct! You might have overlooked this in my related post?
  7. BJJ
    BJJ Formula 3
    1,301
    This bolt appears completely ruined. Even the remaining thread is reduced in diameter and only maybe two turns are left. Imagine how low the torque has to be for avoiding to kill the remaining thread. And then imagine how easily the new nut may then come loose again.
    There is, I believe, no alternative to either replace the bolt or to cut a new thread of lower diameter onto the remains of the bolt. Replacement of the bolt might be done by drilling out and positioning a rivet nut instead of the bolt in the chassis sheet. Then instead of a nut a bolt is screwed in, obviously.
    In any case, do not overtorque again ...
  8. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Did it
    Washers x3 new nut...tightened down nicely.
    Phew
    Panic over
    Learnt a few lessons there.
    Be careful threading nuts onto bolts
  9. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Unbelievable: 7 pages and 133 posts for one stinkin' bolt.
    Get a Dremel and a life, dudes.;)
  10. Mark 328
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Glad you got it resolved:)
    If you don't have one you may want to get a in pound torque wrench. It is amazing how little torque those 6mm nuts can take. The typical torque for a 6mm nut is 80 inch pounds and that is only about 6 ft pounds.
    Even though it is OBE, you had a question about how to tap the hole. Taps can be driven with an opened-end wrench and a many of them have a center hole on the back of the shank. This center hole is used when the tap is made and can be used to hold a tap straight while you are driving a tap-in with a a tap wrench or an open end wrench. A point like a center punch or another tap can be used to hold the tap in-line. The most effective way is with a pointed center in a drill-press chuck or a milling machine, but a center punch in your hand can be better than nothing.
  11. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Pretty important bolt though
    Dremel = little drastic
    Easy does it.
  12. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Thanks Mark
  13. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    Love to see some photo's of the
    process, and the completed repair....
  14. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,459
    Dublin, Ireland
    Greg
    Well done again.
    Certainly no waste of time in terms of the post count from my point of view. Interesting to see/read the various solutions offered.
  15. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Sorry
    All put back together again.
    There was enuf thread left on the end of the bolt for the nut to tighten down.
    Just had to pack the distance out with three small M6 washers.
    Anyways all throttle pedal linkages under there lubricated...RHD cars have a bellcrank with two rods....also replaced the plastic cover thst protects the linkage...mine was cracked somehow.
  16. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Yup
    Main reason why i asked so many questions.
    Got some great ideas ....
    There's some talented engineer types around here!
  17. TZ 750
    Jul 18, 2009
    912
    If you have not already done it......
    Next time you "service" that area,
    you might want to consider some
    strong LOCTITE to hold things well.
  18. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Not needed there
    The nyloc nuts hold the bellcrank well tight.
  19. bdgs1
    bdgs1 Rookie
    Feb 10, 2012
    22
    Tennessee
    Daryl S
    Just my opinion--if the nyloc's work fine?? how did this happen in the first place??
    I have progressively reduced the diameter of a small bolt by use smaller and smaller dies and then used a external threaded insert as the conection between nut and bolt
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,545
    Dumpster Fire #31
    SMG
    It was overtightened. I don't know if the OP directly mentioned that but this type of problem/failure is most always indicative of that. Due to how nuts and bolts have differing properties for them to function as designed, in general the bolt will almost always loose the fight and it's threads get stripped or the bolt shears.
  21. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Couldn't have been over tightened as the nut was never tightened down against the bracket because it just spun without moving up nor down the bolt.
    I guess it was mis threaded yet the first 2 mm or so of the bolt was unaffected...this is the small bit of thread that is now allowing the nut to tighten down against three washers which then butt up against the bracket tight.
