Triple Seals - The Easy Way | FerrariChat
Discussion in '348/355' started by 348Jeff, Nov 18, 2022.
  1. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    Hi guys
    Whilst fitting a new clutch the other week I decided to do the triple seals and upgrade them to Viton ones. I was slightly hesitant as they were awkward to do last time so I thought I'd try a new approach that worked a treat :)
    I just used the polythene bag they came from (SuperPerfromanace) and cut it so it formed a shroud. I then just slid them over the bag until roughly in the right place then made a ring with my fingers like an 'OK' to hold them in place and just pulled the bag away a bit like doing a tablecloth trick. Took me all of a couple of minutes if that to do all 3. I didn't need to do any heating to shrink them back or anything - absolutely simple.
    It's important that the corner of the bag goes over the end of the shaft and you don't cut the bag too short ie it must be long enough to cover the recess for the seal nearest the engine
    ernie, Targatime, Qavion and 2 others like this.
  2. fatbillybob
    Aug 10, 2002
    29,017
    socal
    Ernie calls that "especial tool numero vente sis"
    ernie likes this.
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,572
    San Carlos, CA
    Mitchell Le
    The easy way is to order the viton triple seals.
    ernie, INTMD8, SoCal1 and 1 other person like this.
  4. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,631
    Elliott Caras
    Yes there is nothing hard about installing the Viton version.
    INTMD8 likes this.
  5. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,227
    CT
    John Kreskovsky
    Seriously over thinking this. :rolleyes:
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    I think the point I was making may have been lost...
    The last time I did this job was about 8 years ago using the OEM type seals and it was a right pain. Adding to my woes one of the seals broke so if you do this job, once you have it so it will go inside the shaft pull it out, and double-check all is good.
    I used parcel tape after trying the plastic bottle /warming neither of which worked. I'm confident with a bit of oil on the bag too you can do this with OEM seals. The advantage of the bag too is that it protects the inner of the seal from damage as those serrations are quite sharp.
    KevZep likes this.
  7. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    I made a conical sleeve out of an old plastic water bottle, also seeing some other creative solutions too...
    Those teflon seals are sure difficult to stretch....
