trivial oil filter question 308 | FerrariChat
Discussion in 'Technical Q&A' started by Martin308GTB, May 5, 2007.
  1. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,268
    Black Forest Germany
    Martin N.
    Hello from Germany,
    this question is no joke, but can I reuse my oil filter after removal ? I have just performed an oil / filter change and now has to remove it once more to get at the water thermistor.
    This time I installed a Baldwin filter and would hate it, if I had to scrap it after only several hundred kms.
    Best Regards and thank you in advance for your thoughts.
    Martin
  2. PAP 348
    Dec 10, 2005
    100,224
    Mount Isa, Australia
    Pap
    Yes you can re-use it, Go for it mate, make sure when you refit it you apply a small smear of engine oil on the sealing o'ring on the top of the filter so you don't pinch it ;)
  3. Martin308GTB
    Jan 22, 2003
    4,268
    Martin N.
    thanks ! Yes, I always apply a small smear of grease onto the seal prior to installation.
    Best Regards from Germany
    Martin
  4. PAP 348
    Dec 10, 2005
    100,224
    Pap
    auf wiedersehen :)
