Trouble draining coolant on my 328 | FerrariChat
Discussion in '308/328' started by lopena, May 2, 2020.
  1. lopena
    lopena Formula Junior
    762
    Car is a 1988 328 GTB. I’ve already removed the front coolant hose and got a couple of gallons to drain out. I will be installing a Clark & Clark petcock to make future drainings easier.
    My problem is the drain plug on the engine block. No matter what I try I just can’t get enough leverage on it to remove it. I’ve put the car on a lift, removed the rear undertray, sprayed the plug with Liquid Wrench and used every wrench in my arsenal but the damn thing just won’t budge.
    Are there any secrets to doing this? Should I remove the right rear wheel and fender-liner to attack it from the side?
    As always, your assistance is very much appreciated.
    Alan
    N.J.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    2 options:
    1. Get more leverage
    2. Leave the plug and flush the system completely
  3. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    open your heater valves too.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,824
    Cerritos, CA.
    I just did this yesterday on my QV although I’m not sure if the 328 is the same, I always drained it from the heater hose on the bottom as it’s the lowest part of the cooling system. Around four plus gallons came out. I never did try to open the petcock on the block, I’m afraid it might break cause it’s very tight.
  5. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,624
    San Carlos, CA
    Mitchell Le
    I do three things:
    1. I drain it from the heater hose connection at the bottom of the front. THEN I installed a T connection with a cap to aid in future drainage.
    2. I drain from the engine block plug. I think it is a 19mm plug. THEN I replace it with a petcock for future drainage.
    3. When all else fails, I apply 10 PSI to the over flow tank, and catch the rest of the fluid draining out from the heater hose under the front of the car.
    Lastly, getting to the block drain plug is easier from the wheel well.
  6. lopena
    762
    Yelcab:
    Yes, I have installed a petcock on the front heater hose and will do the same at the engine block as soon as I remove the drain plug through the wheelwell...my project for tomorrow.
    Thanks to all for your responses.
    Alan
    N.J.
  7. lopena
    762
    Well, I had a successful day under the 328. Working from the right-rear wheelwell, I easily removed the engine coolant drain plug (there’s no other way to access this bolt..not from the top, not from the bottom). I drained the coolant from both the engine and front heater hose and installed the petcock kits from Clark & Clark. I refilled her with fresh coolant then took Angelina for a brisk drive and checked for leaks...dry as a bone.
    Job done!
    Alan
    N.J.
    miketuason and thorn like this.
  8. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,611
    California SF bay area
    Paul
    I've always gotten to the block drain from the side so yea, pull the wheel and liner, it's a direct reach from there with pretty good leverage.
