Trouble in F355 paradise, please help | FerrariChat
Discussion in '348/355' started by Dutchman, Mar 10, 2010.
  1. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Hi guys,
    I need urgent help.
    Last weekend I picked up de F355 spider from the UK and drove it home. The car run like a dream. Today I drove it another 150 miles to Ferrari for the homologation procedure.
    After that I drove to a friend to show it and it was parked for about 30 minutes. When I wanted to leave the car did not start. The engine turns but does not fire up. (there is a strong fuel smell) We tried this for 30 minutes and decided to tow-start it. The car started right away.
    Later tonight I wanted to take it for a test drive and drove to another friend. Again when I wanted to leave the car did not want to start. After several attempts and one very long startrun the engine fired up. The rpm is very irregular. Sometimes it jumps up to above 2500 rpm without touching the throttle. Just before I arrived back home the engine started to make a knocking sound and I have lost most of the power.
    Back in the garage I checked all connectors and tried to reset the ecu by turning off the power. But again it does not want to start.
    I need to bring the car in for a technical inspection in two days. Can you please help me what to look at? What could be wrong?
    Thanks for your help.
    Ton
  2. Oengus
    Oengus F1 World Champ
    this happened on mine.......it was a bad connection at the main shut off knob. I had some corrosion on the dial.
    I put a new one in and I was good to go.
  3. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    But in that case I would have no power right? The electricity is fine. The engine turns, but it does not fire up. Or do you mean a different main shut off knob?
  4. mwhitesell
    mwhitesell Formula 3
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    I'm about 80% sure it's this.
    1997 FERRARI F355 SPIDER 3.5L 3496cc V8 FI (X) DOHC : Fuel/Air : Fuel Injection Pressure Regulator. 175 bucks at Rock Auto.
    Two of these. One on each side. Somewhat easy to change if you can fit into small places. I had the exact same thing happen. Fixed these and it was perfect. You can buy one and have a 50-50 chance. I lost that chance and it was the second one. Someone may have a way to test these.
  5. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Should it not run on one bank then? Or does it not fire up at all when one fails?
  6. Oengus
    Sorry Tom........I missed the turn over bit.
  7. TheOnlyest
    TheOnlyest Formula 3
    Sep 25, 2007
    1,686
    Las Vegas Nevada, US
    Steve
    These pesky 355's, they wont start, cracking headers, shifters breaking off in your hand while driving, Spider tops wont raise or lower, 5-figure F1 pumps... You shoulda had a 348! :D
  8. mwhitesell
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    I just assumed that the extra gas flooded one bank. The extra gas probably threw off all of the sensors and made it idle fast. Search through here and you will find a lot of stories about those pressure regulators going bad and the high rev, hard start and rough idle are all common.
  9. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    Is your check engine light working? It should come on then turn off when you try to start the car. It's possible that whatever is causing your problem would set a code. You might try getting an OBDII reader and checking for codes.
    Also, I have seen many posts saying to switch off the battery or disconnect the ECU to reset it. I have tried this and it doesn't seem to actually reset the ECU. In fact, I have two ECUs, so I have experimented with this. I can cause a code such as P1451 to appear in my ECU. Swap the ECUs and see no codes. Then put the original ECU back and the code is still there. It appears that the only way to truly reset the ECU is with the OBDII reader.
  10. BLAMPEE
    BLAMPEE Man Card Status: Never Issued
    Not attempting to hijack...but I have had this code pop on my 355 a few times since I owned it. Once it was a blown fuse...the other 2 times there is nothing wrong with the secondary air pump.
    Did you have a problem with this code specifically, too?
  11. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I can create it by disconnecting a cable. I think it was the cable to one of the Thermal ECUs, but I would have to look to verify.
  12. mwhitesell
    Sep 17, 2006
    1,083
    Atlanta
    Mark
    When this happened to mine, it did not throw a code.
  13. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    The check engine light is working. I will call Ferrari today and ask them for advice.
    I am not a very technical person, so I have no clue what to do with the mentioned error codes. I guess Ferrari does (although they are 75 miles away from me).
    Thanks for all the input guys. I will keep you updated.
    T.
  14. Future ferrari collector
    Oct 12, 2006
    1,795
    All the best! I'm not technical as well so no help, sorry.
  15. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    They think that the crankshaft pulley might be loose. We will check that tomorrow.
    Does that sound plausible?
  16. jm348
    jm348 F1 Rookie
    Mar 21, 2007
    3,017
    Redondo Beach, CA
    Jeff M
    Sounds odd :eek:
  17. f355spider
    f355spider F1 World Champ
    18,055
    #17 f355spider, Mar 11, 2010
    Maybe they mean crankshaft sensor? If so, it should throw a "check engine" light, and an OBDII code reader would confirm. Is your "check engine" light currently illuminated when the engine was/is running?
  18. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    No, the light is not on.
    He thinks it might be the crankshaft pulley because the car was serviced recently. They might not have tightened the pulley enough. I hope they will know more later today.
  19. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    It's not the pulley. :)
    Probably it is the crankshaft sensor. That is a big relief. We also found one of the spark plugs failing. We will stick a new sensor and set of new spark plugs and take it from there.
    Thank you all very much for your input. It feels reassuring that I can always drop the question here to a crowd of very knowledgeable people.
  20. hotrod406
    hotrod406 Formula Junior
    Sep 18, 2007
    540
    Grand rapids area,MI
    Tim
    Glad you're on to something. Don't forget to update the thread when you figure it out. :)
  21. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    I picked up the car yesterday.
    We replaced the crankshaft ingnition sensor and the spark plugs. The car started fine, and the engine sounds good. When it is hot it starts right up but then is a bit hesitant in revs. It is as if it is looking for the right fuel/air mixture. This continues for a few seconds and then the revs stabilize on 1000 rpm. Does this sound familiar? I also hear a light knocking sound when I am at the left side of the car. Probably this is normal, but I just never noticed. Am I getting paranoid? :)
    The car drives fine, the engine sounds good and it revs up as it should. The only thing is that the exhaust "rumbles" a lot when I release the throttle.
    Sorry if this all sounds a bit silly, but I am not a technical person at all. I am just someone who is very happy with his new machine, and was unpleasantly surprised by the recent trouble.
    Would an ECU reset do anything in favour of this all?
  22. full_garage
    full_garage Formula 3
    Feb 15, 2010
    2,241
    Sarasota Florida
    Jay
    If these symptoms are only when cold it could be your air pump- Quickest thing to check is the fuse in the passenger footwell for the air pump- factory is 15 amp but usually it's replaced with a 20 amp. When the air pump is on you know it- It's that awful metallic whine for the first 3-5 minutes.
    In my search for a good 355 I don't think i started up a single car cold that was not a little bit lumpy and hesitant for a little bit... But with the air pump off the car runs very, very rich and can stall if you try and rev it.
  23. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    It runs fine when cold. It feels like it runs a bit rich when it is hot.
  24. rllucero
    rllucero Formula Junior
    Jul 11, 2006
    559
    Santa Fe/San Diego
    richontravel
    Where are you getting your information from?
  25. matkat
    matkat Formula 3
    Mar 18, 2003
    1,840
    Scotland
    Dave McGuire
    Indeed as I thought my thread regarding changing the electric motor had dispelled that myth.
