Trouble in paradise | Page 2 | FerrariChat
Trouble in paradise
Discussion in '348/355' started by FDT, Nov 20, 2012.
  1. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    Things don't always fail catastrophically and instantly. It sounds like it is completely plugged up now though.
    During the process of failure the cat ecu system doesn't kick in until it reaches running temp and won't shut the bank down until its warmed up. But now as a complete failure it just is off at the get go because it physically can't operate regardless of the warning system so no light and bank down when cold.
  2. FDT
    FDT Formula Junior
    May 18, 2010
    423
    La
    Ric
    I turned the battery off then restarted the car and let it idle for 12 minutes. It sounded rough at first then smoothed out. I just drove it and all the temps were normal and the car ran fine. Does this mean I have an electrical issue, or could it be something else? If it was the cats plugging up would it or could it act this way.
  3. bosshog8
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    It could but if its melted its melted so its unlikely but there is no rule book. If you say you did the reset procedure and are confident it runs good then this is very typical for the cat ecu problems previously described. I personally removed the entire system due to it being such an annoying piece of garbage.
    Drive the car and see what happens. If it kills the bank you need to check the cat temp at that moment and see if its significantly hotter than the other side. That would be a positive indication of a failed cat and the cat ecu system functioning correctly.
  4. FDT
    FDT Formula Junior
    May 18, 2010
    423
    La
    Ric
    Thanks for everyone's help but I have a feeling this problem is going to rear it's ugly head again. I just drove again, got everything good and hot, car ran great. I let it sit for a few minutes to heat Soak and drove it again,it ran perfect? From what I am hearing sounds like an electrical issue with the ecu. You mentioned that you got rid of the whole system. How? I have a 95 so everything I hear is that this is an easier car to mod so how would I go about removing this system. When I simply unplugged the ecu it lit up the slow down light. Could I put bypass pipes on and then leave the sensors plugged up but not actually screwed into anything?
  5. F355Bob
    F355Bob Formula 3
    I had a problem last month where my car would start running on 4 cylinders and could not rev past 3000rpm. All of a sudden it would run fine for a few days and then it would happen again. I changed my fuel pump relays and have not had a problem in 500 miles.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    LOL
    Good one.
  7. cuneo
    cuneo Formula 3
    2,484
    That test it to determine if you have a bad cat ecu. i.e. did the non-running bank switch sides when you switched cat ecus?
  8. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Well it seems that the problem has corrected itself for the moment.......see a follow up post by the O.P.
    http://ferrarichat.com/forum/showthread.php?t=390202
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Nah, it'll come back.
    I still say he needs to check the cats.
  10. ClydeM
    ClydeM F1 World Champ
    12,086
    Wayne, NJ
    Clyde E. McMurdy
    It's a 95. It's easy enough to pull the code(s).
    Let it tell you what's wrong.
    And I would stay away from turning on & off the battery - doing that toasted my 3rd party alarm. Read the cels & then follow the procedure to clear them with the buttons.
    (BTW: my 95 it was the thermo sensor. Slowdown would light, the car would go into limp mode - one bank would shut down - then after a minute or two, it would power back up for a while, then limp mode...and so on. Of course the CELs would light with the bank down)
  11. cuneo
    cuneo Formula 3
    2,484
    Sorry about this post, it was supposed to be post #21 last night but for some reason it took
    until 1:00 pm today to hit the board. Lame!!
    Good luck getting your issue sorted.
