Trouble plugging a V1 into a F430 | FerrariChat
Discussion in '360/430' started by msgm1, Jul 29, 2007.
  1. msgm1
    msgm1 Formula Junior
    Nov 4, 2003
    454
    NYC
    I am having trouble plugging my V1 radar detector into my F430, either the V1 connector is too long or the connection too slack. Either way if I go over a bump the connection goes bad and the detector stops working. Has anyone else had this problem please?
  2. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    1. Try a two plug adapter like they sell at Wal-Mart. If it works you will have and estra plug in. Also, you can modify the cheap Wal-Mart adapter and not worry about totally ruining your V1 plug.
    2.WD-40 helps improve connections...use just a little, you don't want to short out your system and fry your fuse. Have a spare fuse HANDY.
    3. Have your V1 hard wired.
  3. SANguru
    SANguru Formula 3
    Jul 15, 2005
    1,258
    Bay Area, CA
    Josh
    try popping one of the springs out on the adaptor and bending it outwards.
  4. THE BEAST 360
    THE BEAST 360 Formula Junior
    Jul 17, 2005
    646
    Maryland
    Nathan K
    Fold up a little piece of paper and wedge it on the side of the plug.
  5. JChoice
    JChoice Formula Junior
    Jan 20, 2004
    582
    Southern California
    JC
    There is a different adapter available from Valentine if the problem is that your power adapter won't stay plugged in tight enough to the cig outlet in the car.
    I had my V1 wired to the dome light. It's much cleaner this way.
  6. SANguru
    SANguru Formula 3
    Jul 15, 2005
    1,258
    Bay Area, CA
    Josh
    that would be a fire hazard...
  7. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I also had mine hard wired to dome light. (Don't know if you can do this in a spider).
    Dave
  8. cglass17
    cglass17 Rookie
    Sep 12, 2004
    49
    I had this same problem. Called Valentine and told them about it. They sent me another plug. It looked identical. However, it solved the problem
  9. msgm1
    Nov 4, 2003
    454
    NYC
    Called Valentine and they sent me another plug which looks to have solved the problem.
    Just as well as my v1 saved my bacon twice yesterday when driving out in the Hamptons, NY...
    Thanks again for all your help!
