Trouble starting my 2003 360 | FerrariChat
Discussion in 'Technical Q&A' started by Robert Burlison, Feb 10, 2022.
  1. Robert Burlison
    Aug 18, 2020
    30
    Robert
    Nothing happens when i turn the key after receiving the "Check Ok" then the display goes from "n" to "1". when I try to switch gears using the paddles nothing happens. any help will be greatly appreciated. Had the car for over a year, Battery is 3 months old. its never done this before always started right up.
    error codes:
    P0600 CAN Error Code
    P1760 Brake Error
    P1747 Reverse Gear Switch
    P1730 Pump Relay
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,955
    Central NJ
    Dominick
    One error is relay ..so you hear pump go on when open doors ..
    Does you Obd tool read data streams
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,671
    South East
    Jimmie
    How long since you last drove - could it be as simple as flat battery ?
    Are there multiple threads on this ?
    Qavion likes this.
  4. Qavion
    Qavion F1 World Champ
    14,341
    Ian Riddell
    And your battery is always on a good trickle charger when the car is not in use?
    That's a lot of codes.
    If the battery is low, the F1 pump may not be able to provide enough hydraulic power to put the car into neutral for start.
  5. Robert Burlison
    Aug 18, 2020
    30
    Robert
    i used the foxwell to put the car in neutral. now it starts but i can not change gears out of neutral with paddles.
  6. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,963
    The Cold North
    Tom
    Are your brake lights operating? Check to be sure all the lights back there are working.
    Clear the faults and try again. If it fails start again re-scan and see what faults reoccur and chase those faults.
    I have seen broken reverse levers cause these types of issues.
  7. Robert Burlison
    Aug 18, 2020
    30
    Robert
    None of the brake lights work. cleared and re-scan only get P0600 code.
  8. Qavion
    14,341
    Ian Riddell
  9. tbakowsky
    Sep 18, 2002
    19,963
    The Cold North
    Tom
    Put a jumper wire across the brake switch harnees connector..and see if the lights work. Dumb question..you do have the key on when checking the lights correct,?
  10. Robert Burlison
    Aug 18, 2020
    30
    Robert
    yes pump runs when i open door yes i can read data streams
  11. Robert Burlison
    Aug 18, 2020
    30
    Robert
    yes key is on which of the four prongs
    brand new upgraded brake switch and fuse is good
    Qavion likes this.
  12. Qavion
    14,341
    Ian Riddell
    Not sure about the 4 prong type which has two sets of contacts. You'd have to go by wire colour. How many wires do you have feeding the switch? 2, 4 or 3 plus a jumper?
    Red with green stripe is power in (from fuse). Red wire is the power out to brake lights, RH Engine ECU and F1 TCU when brake pedal is pushed (i.e. switch plunger un-pushed). Some cars have an additional brown/red wire going to the RH engine ECU. I don't know if this additional wire operates in the opposite sense to the other wire (i.e. power when switch plunger is pushed and no power when switch plunger is unpushed)
    I started drawing some wiring diagrams, but I don't have access to a 360, so can't confirm the switch internals.
    Is it possible you could confirm the operation of the switch contacts for us? And possibly take a photo of the wiring?
  13. Robert Burlison
    Aug 18, 2020
    30
    Robert
    Qavion likes this.
  14. Robert Burlison
    Aug 18, 2020
    30
    Robert
    Two red and green wires one red and one brown. Push the brake pedal down plunger extends and brake lights are activated
  15. Qavion
    14,341
    Ian Riddell
    Thanks for the photo! So 4 wires. The two red/green wires are spliced somewhere.
    But are you saying your lights started working? Or just that you have continuity between:
    1) red/green and red when brake pedal pushed?
    2) red/green and brown/red when brake pedal pushed? By the way, I don't see a red stripe on the brown wire (or is it hidden?)
  16. Qavion
    14,341
    Ian Riddell
  17. Robert Burlison
    Aug 18, 2020
    30
    Robert
    the lights still do not work, i have not tried to jump them yet either. Two wires are red with green strips. one is solid red and one solid brown.
    Qavion likes this.
  18. Qavion
    14,341
    Ian Riddell
    Speculation: The second pair of switch wires (which also go to the RH engine ECU) may be part of some kind of cross-checking system or may help define the fault code.
    If you can determine what the brown wire does with the brake pedal pushed and not pushed, this would be very helpful. I've been looking for an answer to this for over a year now.
    Here's my current full wiring diagram (Spider, but coupe should be the same)
    https://www.dropbox.com/t/h78UAYQ8fPmdFkS5
    Plug 16G (if you can find it in the diagram), is the interface between the brake pedal switch and the F1 system.
    I'll upload a new one if more information comes to hand.
    Here's the F1 wiring diagram (see plug 11P/16G)
    https://www.dropbox.com/t/1uhXfvXdnWwM3nk1
    Links expire in 7 days
  19. tbakowsky
    Sep 18, 2002
    19,963
    The Cold North
    Tom
    You should be able to check switch function with a continuity tester. Switch plunger compressed..switch will show open. Plunger extended switch should complete the circuit.
    What do you have for voltage at the switch? Should be one reference signal in then a ground.
  20. Qavion
    14,341
    Ian Riddell
    Was the part number of the new switch 334064?
    There is talk on the Maserati forums that this part is used on the Maserati 4200 and the switch contacts are across diagonal pairs of pins.
    https://www.************.com/threads/common-issues-and-fixes.67529/page-3
    i.e. 1 & 4 and 2 and 3. This would not only make my wiring diagram switch internals incorrect, but it would put on the brake lights permanently. Hopefully you can solve this mess with an ohmmeter.
    What do you mean by "then a ground", Tom? You have 12 volts power in (from the fuse), 12 volts power out (to lamps and ECUs) with the plunger extended. There is a ground on the "out" ... but only if you go through the resistances of the brake lamps and other components.
  21. Qavion
    14,341
    Ian Riddell
    Correction... I had my wires crossed (too many times)
    Here's what the switch circuit would look like with the diagonal pins hooked up (with the brake pedal pushed and unpushed)
    Redrawing the switch internals...
    So it is possible that the pins are diagonally linked. To be confirmed, of course.
  22. Robert Burlison
    Aug 18, 2020
    30
    Robert
    that is the switch i received from Ricambi. I will put the mulit-meter on it today
    Qavion likes this.
  23. Robert Burlison
    Aug 18, 2020
    30
    Robert
    your diagram is correct i have continuity at 1 and 4 with plunger in (pedal not pressed) and continuity at 2 and 3 with plunger out (pedal pressed). from the car continuity at 3 and 4
    Qavion likes this.
  24. Robert Burlison
    Aug 18, 2020
    30
    Robert
    let me check my old switches now that i think of it
  25. Robert Burlison
    Aug 18, 2020
    30
    Robert
    old switch operates the same as your diagram. so the old switch is good
    Qavion likes this.
