trouble starting | FerrariChat
trouble starting
Discussion in '308/328' started by psmaia, Jun 11, 2007.
  1. psmaia
    psmaia Karting
    Oct 26, 2005
    219
    greenwich, conn.
    Paul Marchese
    every now and then, when i go to start my 328, i just get a clicking noise when i turn the key...if i keep trying, eventually it will start normally...is this an ignition switch problem, or a solonoid?
  2. SonomaRik
    SonomaRik F1 Veteran
    yes:
    I know, sounds like both.
    Check out the threads on no or hot start problems for this and 348.
    Might help
  3. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Could be battery as well.
    (Weak battery's do the same thing)
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    It might be bad/dirty starter motor brushes or where they contact in the starter motor. If the starter turns the motor over at normal speed when it does crank that would eliminate a weak battery. I would check for loose connections at the solenoid and starter motor to begin troubleshooting.
    Erich
