trouble with reverse | FerrariChat
Discussion in '360/430' started by Drflint, Sep 17, 2018.
  1. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    had 1 time trouble getting car into reverse with sensor showing hood open when it was closed and gas door storage door and hood door switches not working. Finally after I minute everything worked fine & car has driven well since F1 trans otherwise has shifted well
  2. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    When you say hood do you mean engine cover or front trunk hood. There is a symbol on the dash that looks like the engine hood open but that's the f1 pump light. It also shows up if you have tail lights out.
  3. Skidkid
    Skidkid F1 Veteran
    9,524
    Campbell, CA
    John Zornes
    Charlie, I believe it is actually the F1 Error light. It isn't specifically about the pump but indicates a transmission problem.
    cpep likes this.
  4. cpep
    cpep Formula Junior
    438
    new york
    CHARLIE
    Sorry John My bad. I called it a pump light and you are correct it's a trans light. I have only seen it on my car when I put led bulbs in my taillights.
  5. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    Yeah, it is the transmission fault light and it can illuminate for a variety of reasons such as what was stated above, faulty bonnet microswitch, relay issues, and pump cycling issues.
  6. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Looks like your first post.
    Common practice here is a quick introduction about yourself as a friendly gesture so that experienced and helpful people here will make time to try and help you with your car issues.
    At any rate, my experience tells me it could be front storage compartment latch micro switch going bad, dirty engine bay closed sensor contact or relay going bad.
  7. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    it was the hood
  8. Drflint
    Drflint Rookie
    Aug 17, 2016
    20
    florida and indiana
    doug flint
    Thanks for the feedback This is my 3rd Ferrari previous ones being 308gts and 512bb These were much simpler machines.We did change the cam belts in the 512bb without removing the engine Not as familiar with the F430 and all its sensors.E diff slow down sensor occasionally appears also even though this has been worked on by Naples Motorsports.Car equipped with ceramic brakes and terrific sounding Fabspeed headers.
