troubleshooting exhaust bypass valve | FerrariChat
Discussion in '348/355' started by 44qsake, May 13, 2012.
  1. 44qsake
    44qsake Rookie
    Oct 25, 2011
    36
    #1 44qsake, May 13, 2012
    I am troubleshooting exhaust bypass valve failure. I have vacuum pressure in the green areas, none in the red (see attached picture). I am uncertain if there should be vacuum pressure in the red areas at all times or only when the bypass valve is called to open. Can anyone advise?
  2. MicroFirm
    MicroFirm Karting
    Dec 6, 2010
    231
    Colorado
    Frank
    My understanding is the bypass valve is operated under vacuum and when vacuum is present. Therefore the red line going to the bypass valve should switch between vacuum and no vacuum.
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    ^^^ Correct!
  4. tispkj
    tispkj Karting
    Sep 26, 2011
    54
    Paul Jennings
    Hi, seems you had the same problem as I did, your little solenoid valves have seized up with corrosion due in part to silly positioning by ferrari and also my guess is build up of moisture over time.
    Take off and test, as you power up the solenoid air should pass through, test with a small plastic petrol pipe and blow.
    Take a look on my post in the interchangable parts section, from memory you need to ebay search ERG140
    Regards
  5. WATSON
    23,699
    WI
    #5 WATSON, May 14, 2012
    The vacuum is applied to the areas in red in your diagram via the solenoid valves. It is not uncommon to have these stick or the electrical connections corrode. A good cleaning helps.
    The valves are #8 below.....
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Same thing happened to me yesterday, valve stuck wide open.
    Good part sounds good around town LOL
  7. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Does anyone know the correct voltage to the solenoids?
    Are they getting voltage during idle?
    I think my inward solenoid with the black plug bit the big one
  8. WATSON
    23,699
    WI
    Goodness, I hope it is 12 volts.
    I pulled mine and cleaned them on the bench and tested them with a 12 volt source.....
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Same here, I do get 6 volts at the outer solenoid, thats why I ask
    Another quicky, is the outer plug the blue one? I have a black and a blue plug want to make sure I did not mix them up
    Thanks much :)
  10. tispkj
    tispkj Karting
    Sep 26, 2011
    54
    Paul Jennings
    Both solenoids are the same 12v
    No they dont get voltage until the ECU powers them up at a set throttle load.
  11. WATSON
    23,699
    WI
    The blue plug is the outboard solenoid on my car.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Thank you Sir, much appreciated
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Much appreciated :)
