360 - Troubleshooting question... | FerrariChat
360 Troubleshooting question...
Discussion in '360/430' started by deportm, Feb 5, 2020.
  1. deportm
    deportm Karting
    62
    El Paso, TX
    Anthony Figueroa
    2002 360 Spyder, 18800 miles...kept getting P0442 error code. Failed emission test. Smelled fuel while taking a sharp right turn... read about micro cracks in fuel pump caps. Checked fuel pumps and caps... everything peachy till I filled the tank, now an overpowering smell of fuel, but cannot find leakage or puddles anywhere.
    Wife is afraid I may blow up the house, so can anyone share any knowledge or experience on this?
    Thanks in advance...
  2. RedNeck
    RedNeck F1 World Champ
    12,328
    The CSA
    Me
    EVAP leak. Checked your gas cap? Checked you charcoal canister?
  3. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
  4. mello
    mello F1 Veteran
    5,489
    CA Bay Area
    Steve
    The quickest and surest way to get to the problem is a smoke test.
  5. deportm
    deportm Karting
    62
    El Paso, TX
    Anthony Figueroa
    Me again, to make a correction on earlier statement, the fuel pumps were changed, along with the gas tank cap. The smell is less, but still faint... smoke test was performed before fuel pumps changed with no luck in isolating the vapor leak.
  6. one4torque
    one4torque F1 Veteran
    5,725
    Houston
    One4torque
    Would not park it in a sealed garage until fixed.
    have a qualified shop look at it.
    or if you have time and skills take off side covers and inspect entire fuel evap system
