trunk bonnet switch not workingin my Mondial T | Page 2 | FerrariChat
Discussion in 'Mondial' started by jal, Aug 29, 2009.
  1. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    Here’s my front solenoid. Looks toasted. Getting power though cuz it trips 25a fuse every time I push switch. Looks like the RM-1683b solenoid is still available from same seller on EBay.
  2. Stef65
    Stef65 Karting
    Apr 28, 2015
    196
    reg Antwerp Belgium
    Stef
    I had to replace mine 4 years ago.
    I decided to buy a cheap version as a temporary solution, till I was sure why the solenoid burned. I was afraid that I would end up buying several.
    8Kg Holding Force DC 12V Pull Linear Solenoid Electromagnet-in Other Electronic Components from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
    43.26US$ home delivered versus 718US$ @ eurospares.co.uk (http://www.eurospares.co.uk/partsListing.asp?M=1&Mo=392&A=2&B=21169&S=&ID4=921417)
    Later I found out that once in a while the switch kept hanging after pressing, probably causing the burning of the solenoid
    I would replace it with the original version, but still today I have the temporary solution in place.
  3. Wingnut
    Wingnut Karting
    Feb 11, 2005
    164
    Corolla, NC
    Is there a current supplier of solenoid switches for the Mondial t? I'm thinking of replacing mine now after seeing this thread.
  4. Incaico
    Incaico Karting
    Jun 13, 2020
    70
    SoCal
    JR Sandoval
    My fuse also kept blowing. Found out it was the switch getting stuck. Now, I push switch and push it back into place. Hood opens and fuse is not blown. Weird how it would burn out before fuse does...
  5. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    It's always best to use authentic parts, instead of ordering non-functional cheap reproductions in China. The latter will last for a couple of months and then stop functioning.
  6. porphy
    porphy Formula 3
    1,210
    LouisvilleKY/Switzld
    Randall Gatz
    Have you considered rewinding the coil. Wire is available and the process is not complicated. It looks like the solenoid is easily taken apart?
  7. Louis Brown
    Louis Brown Karting
    Dec 24, 2019
    83
    Richardson Texas
    Louis Brown
    I have not. Would I need to enroll in night classes trade school to know what i’m doing ?
  8. porphy
    porphy Formula 3
    1,210
    Randall Gatz
    Try YouTube there are usually excellent explanations. It pretty simple.
    Louis Brown likes this.
  9. Ferrariver
    Ferrariver Rookie
    May 31, 2013
    5
    Toronto
    Well, here we are in 2025 and the solenoid I installed back in 2013 is still functioning perfectly. The solenoid is not a reproduction, it's just a solenoid with similar specs.
    We had an amazing summer here cruising with the top down, in and around Niagara Falls, Ontario and New York. Almost 1000 miles logged. Best summer yet. Enjoy your Ferraris!
