Trunk / Engine bay lights | FerrariChat
Discussion in 'Boxers/TR/M' started by lear60man, Dec 27, 2012.
  1. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    What fuse makes these three lights happy? Its not in the manual or fusebox diagram. The bulbs are good, but nada. If there is another common for all three to be bad Im all ears. Relay?
    Thanks,
    Christian
  2. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    #2 302Tim, Dec 27, 2012
    Fuse #13. The OM doesn't do a very good job of explaining ("only when outer lighting switch is turned on") but those lights only work when the hood or trunk is open AND the external light switch (or steering column stalk, referred to as the "retractable headlights and high/low beam control knob") is in position #1 or 2. If your column switch is on and you have no lights in either compartment, check fuse #13. If it blows right away refer to this thread for probable cause:
    http://www.ferrarichat.com/forum/showthread.php?t=238053
    Good luck, let us know what you find.
  3. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Big thanks for the translation Tim. The stalk wasn't in position 1. I cleaned every contact, checked bulbs, fuses, trunk switch etc....then did a search here.
    Now that she is all put back together from my 'modifications', I'm going for a spin.
    Christian.
