Trying to choose between 2 355s - Help! | FerrariChat
Discussion in '348/355' started by AML355, Dec 12, 2004.
  1. AML355
    AML355 Karting
    Dec 11, 2004
    52
    After 3 911s I am taking the Ferrari plunge. I am looking at two black 355 Spiders. A '95 Black/Tan with 14k miles and Tubi. The other a '96 Black/Black with 21k miles and with Challenge Grill and Challenge Exhaust. Both about the same price. Should I go with age or mileage? Both seem to be in great shape and have had belts done. There is some minor paint bubbling/raised paint on the rear deck of the '96 which is creating some concern that maybe there had been an engine overheat issue.... I hear the 95's had slightly more power due to emissions modifications that started in '96 (does this explain the difference in engine configuration: Y vs. parallel straight pipes)? Both cars are at reputable car dealerships though the '95 was just fully ran through a Ferrari dealership which is the sister to the Maserati dealership which has it. It was also sold new by that Ferrari dealership so history is all there.
    What do people think is more important for residual value: low mileage or year? I am likely only to put 3-4k miles per year on the car.
    Any all thoughts welcome as I take this plunge. Thanks!
  2. mrmckay
    mrmckay Formula Junior
    Jul 14, 2003
    488
    MD, USA
    Chris
    Have you driven both of them? If not I would try to get some seat time in both of them.
    Regards,
    Chris
  3. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    I can do no better than refer you to Mitch Alsup's superb post outlining the evolution of the 355 model.You haven't mentioned the difference in price between your 2 cars and whether this will affect your decision.My personal choice FWIW, based on colour preference and your description of the cars,would be the Black /Tan. Anyways, here's Mitch's post
    The Ferrari F355 has two different engine packages (OBDIO-I=95 and OBDIO-II=96-99), and three different brake packages (95, 96-97, and 98-99). In street braking, there is not much difference in the braking setup and response; and for track use all brake packages should have a set of pads that are more tollerent of heat.
    When F1 became available in ?96 or 97? it arrived with an uprated slave cylinder in the clutch throwout system. Like the F348s the clutch (and associated parts) is easy to change even if the parts are expensive. If you have to change anything in the clutch, do the whole thing and use the uprated slave cylinder. Its smoother, lighter, and ever so slightly faster.
    The 95 engine has a little more HP and TQ (5 HP and 2-3 lb-ft) from a slightly richer mixture allowed by the OBDIO-I emissions specification. All engines will have header issues if tracked regularly, and the 95 modle year is more affected than later. There is a uprated materials specification if/when header replacement is required. Even with the uprated materials, challenge cars replace the headers yearly. With indifferent street use headers have gone as far as 103,000 miles without failure. The hydraulic pump of the F1 cars saps some power from the engine but performance improves through the faster gear changes available through computer controlled timing of the events. The 360 F1 system is miles ahead in smoothness especially after 2001.
    Engines up through the 98 model year can be affected by a valve guide issue detected in 95 based on the 94 348 Challenge cars where the factory changed the vavle guide specification from <some> bronze to sintered steel. In general, if the engine has not run into the valve guide issue by the time it has 20,000 miles it will likely not run into the issue.
    The suspension system is excellent, with minor issues relating to the computer controlled shoch absorbers (connector corrosion). The oversteer/understeer relationship is easily manipulated with rear ride height (Google on: Ride couple distribution). The factory specs are just fine for street and even agressive track driving on street tires. I get 9 K miles on a set of max performance street tires where 1,500 of those miles occur on a race track with factory specs. Both front tires and both rear tires turn from treaded tires to slicks within 100 miles of each other. Adding camber speeds up the chassis but beware of making the car faster than the driver. Adding toe calms the car under steady state straight line operation and under braking. Running toe-out is only for track use. The suspension is easily dialed into the driver preference as long as the driver known which direction he want the cars response to move towards. If you lower the car be aware of a high speed heavy braking issue at the front suspension. Staying at the <already> factory ride heights (4.2" of ground clearance) is a good bet and prevents this high speed braking issue.
    If you want to use r-compound tires or racing slicks, find the challenge specifications for alignment, but don't lower the car unless you also add the challenge spring and shock package. For noon-agressive track use, r-compounds and slicks work pretty well with the factory alignments.
    The alignment system (shims) works so well that if you like agressive track driving and calm street driving, get the car sorted on the track first, and them get it aligned back to factory specs on an alignment gig. The difference between the shim thickness can be measured, and when you get to the trank, loosen a bolt, insert the required shims (8 times) and go to town. At the end of the day remove the shims, and presto you are back at street alignment. You will also get most of the toe change desired (out at track and in on the street) with this change as a side bonus.
    I dislike the power assist for the steering and prefer the 348 feel of the steering wheel, but I rate this as a very minor issue.
    Cars that are used hard over irregular surfaces will see minor paint spider webbing on the rear flying butress (C-piller) as evidence of hard use.
    The plastic parts in the interior need to be kept away from Armoural and similar plastic protectants--it turns the plastic parts into a gooy mess.
    The leather <especially> needs to be protected from drying out. Feeding the leather once every couple of months or every time you drive for any distance with the windows down; and avoiding letting the car sit in sunlight help a lot. The leather is higher in quality than <say> a C5 Vette, but less tollerant of lack of care.
    Overall, the engine internals, the transmission, suspensions and brakes are basically unbreakable. There are no long term issues with the paint and exterior materials.
    With the age of these cars approaching 10 years (95) and only the 98s and 99s still under the 8-year emissions warentee, the potential buyer is ever more dependent upon a high quality PPI than before. These are wonderful high performance machines that can take a lot of abuse (or designed for use) without fail. The engine has a big broad torque curve that is readily accessible and the sound at RedLine is simply out of this world. When the tail drifts out in a 100 MPH sweeper, you dial in a touch of steering and add throttle, and grin all the way to the next braking zone. However, like an Italian mistress, they are demanding upon your time and wallet. Choose wisely.
  4. AML355
    AML355 Karting
    Dec 11, 2004
    52
    Tony/Chris:
    Thanks for the piece on the 355, that helps. What do you make of the paint issue on the rear deck. I prefer the '96 with black/tan but hesitate as to what the paint may signal vis-a-vis the engine. As to the price, both cars have the same asking price at $80k.
    Were there any kinks in the '95 that were perfected in '96 and thereafter that should cause me to shy away from the '95?
    I haven't driven either as they are on opposite sides of the country.... though i had the '96 one driven by a local friend who said it was outstanding.
    Thanks again. I welcome all views.
  5. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    It's really unusual for there to be a problem with paintwork on these cars, GTB C-pillar apart. Is it on the engine lid itself or the rear bumper area. I would have thought engine heat would effect the bumper area as the engine lid itself has vented slats for the heat to escape from.
    The major changes from '95 to '96 cars was Bosch Motronic 2.7 to 5.2 and subsequent uprated engine management from OBD1 to OBD2.
    FWIW, i have a '95 Spider :) Any other questions, just fire away.
  6. Kds
    Kds F1 World Champ
    Buy the black on tan car.....
    You never mentioned the pedigree of the black on black one.....but the 95 has just been inspected thru a Ferrai dealer and has all the history in one place....meaning fewer stores at resale time.
    Also....black on black is unbearably hot in a spider on a nice summer day with the top down.....I just spent this past summer with a black on black SL600 and hated it for that very reason.
    OBD1 versus OBD2 as well as the slightly shorter gears in the 95 I think are the other differences in it's favor.
  7. AML355
    AML355 Karting
    Dec 11, 2004
    52
    KDS:
    The b/b one is the '95 with 14k miles. It was sold by the same dealer which just did the service and is effectively the dealer which has it for sale. Apparently, first owner was meticulous and the car also went through an inspection (and associated work) at the ferrari dealer before the sister dealership (Maserati) put it on it floor.
    The black/tan is the '96 with 21k miles. At non-ferrari dealership but allegedly inspected by one of its ferrari trained mechanics.
    I am reluctant on the b/b for the reasons you mentioned.....but should i go for the lower mileage car?
  8. amslb182
    amslb182 Formula Junior
    Oct 3, 2004
    590
    Ct
    Andrew LeGrant
    No major kinks were really fixed until 1997, the first year for the F1 gearbox in the 355, ive heard of people having top problems in the pre 97 355s so make sure you check out the top. Otherwise go for whichever one looks better and is more mechanicaly sound, neither one should give you more problems than the other.
  9. Kds
    Kds F1 World Champ
    AML355....
    Your original post had the color/years reversed.....that's no problem though.....so to answer your question in if it was me I'd pop for the black on black 1995 with 14K miles. While the heat can get to you......I'd personally be more comfortable with the pedigree than on the other car.
  10. 348SStb
    348SStb F1 Rookie
    Regarding the paint:
    Bubbling could signify a poorly done repaint. Are you certain that that portion of the car was not repainted? I would have a body repair expert examine that if you don't consider yourself qualified.
  11. Steve R
    Steve R F1 Rookie
    3,018
    MeSoNeedy, CA
    TorQ Master
    First off, those are really good prices. I too am in the market and as I type this I have a 355 getting a PPI...keepin' my fingers crossed. Mine's a '97 w/16k miles and I'll make no secret that the guy is extorting me for $99k...but it's clean and tight. I know and feel it's just a $95k car, but I'll make him fix everything we find and have some peace-of-mind.
    Personally, I'd avoid the black/black...no color and hot. I too was looking at a B/t and B/b right next to eachother...the B/t definitely had a nicer/classier look to it. Course, that's just personal opinion....
    Next are the valves...research points to a higher % of '95 with valve issues, especially the earliest models. Another huge point is in the resale: many buyers are thoroughly adversed to even looking at a '95: you'll re-sell easier with the '96. It's also newer, and the rule is to buy the newest/nicest Ferrari you can afford.....
    You've got to be careful and patient too. I ran into several lemons out there, one I almost bought and it needs about $12k of work that we discovered...who knows how far that'll go once opened-up!!!
    Don't fear mileage...these things need to be driven. As noted above, the 21k car is very likely past the valve issue and it's not excessive for a '95
    The bubbling is likely a re-paint. Buying a car sight-unseen...scares the heck out of me, but that's just me. Each car I found at first looked awesome...then the history revealed, the stories came..and..ughhhhh. Buyer beware!
    My vote therefore falls firmly on the '96 Black/tan
    ...and don't listen to that 348SStb...he's too passionate!!! ;)
  12. AML355
    AML355 Karting
    Dec 11, 2004
    52
    Thanks for the recent replies. As I wait to see how the situation develops here is a bit more info....Let me also clarify which car is which so everyone can give me accurate advice. I had reversed the color combos in my initial string. Here is the right description: '95 B/B with about 14k miles and a tubi. Car has extensive history ('95 to date) and was just reviewed at Ferrari dealership before put on showroom floor. The other is a '96 B/T with about 21k miles and a Challenge grill and exhaust. Service records are spotty (but dealer trying to get them) but it allegedly passed another's PPI last week (financing came undone) as well as the dealership's review. Dealer is told the belts are done and likely the clutch. The '96 had the paint issue which is right between the convertible cover and first rear deck vent (so, quite far forward on the rear deck). This was the concern. Dealer wet-sanded it today and said it is great. Thought the problem was maybe due to a scratch and then a somewhat poor re-spray.
    I like the '96 B/T combo for all the reasons people suggest. But hard to beat the '95's recorded history. Price is a bit cheaper and mileage lower too.... But B/B and this will be a summer car with the top down....gonna be hot I guess.
    Doesn't sound like anyone is terribly worried about the paint issue on the '96 which is good. My guess is everyone will say good pedigree on the '95 and be scared of the '96 unless i get an outstanding PPI.
    Thanks to everyone who has helped thus far. Knowing what to look for is obviously key.
  13. TTG
    TTG Formula 3
    Jun 11, 2002
    1,555
    East Hanover, NJ
    Todd Gieger
    Get the car that YOU really want...The worst thing is looking back after you have the car and saying, "Man, I wish I bought that other car"...regardless of price...No regrets brother!
