488 - Trying to understand the portable power pack for 488 batteries | FerrariChat
488 Trying to understand the portable power pack for 488 batteries
Discussion in '458 Italia/488/F8' started by DiamondDog, Jun 9, 2022.
  1. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,465
    Orange County, CA
    I have 2018 488. Battery is fine and always on tender. This forum has me worried that this battery may go out at any time.
    Read about a portable power pack. So if battery goes dead, these things will start it? You use keep one in your car?
    How often does the power pack need to be charged?
    Which brand and model is recommended
  2. Mrpseudonym
    Mrpseudonym Formula Junior
    602
    Sydney, Australia
  3. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    Thanks for this
    What reading indicates your car won’t start?
    Curious as to what others think of these battery monitors. Available on Amazon. They are pretty small.
    Anyone else using one?
  4. Mrpseudonym
    602
    Sydney, Australia
    The main reading that indicates you have a problem is the cranking voltage test. Each time you start the car the monitor looks at the voltage while cranking. I got an alert to my phone when the cranking voltage was 9.2V. Here is a screen shot from the monitor app. Cranking alert was on 2nd April. Battery failed on the 21st. Looking back through the monitor history though, there is a warning as far back as Feb.
  5. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    Thanks for this. So between the alerts there were many normal cranking days? So you should replace battery at first abnormal crank?
    I would think that if there was on red, the next days would be red again?
  6. Mrpseudonym
    602
    Sydney, Australia
    I’d suggest you replace battery at second or third abnormal crank. I remember getting an abnormal crank message once when I only half depressed the starter button and car ticked over but didn’t start.
    as for your question on green days between red, there are other factors at play. Starting a warm car for example is easier than starting a cold one.
  7. OldDog
    OldDog Karting
    Nov 2, 2017
    55
    Sarasota, FL
    JJ
    Image Unavailable, Please Login I was concerned about having battery failure on my 488 so I bought a portable power pack (jump box). I also was sure that if it happened I would be somewhere, dressed up, at night (probably on the rain) and I did not want the work of uncovering the battery (try it, it is not that easy) and connecting the alligator clips. So I took the leads from my new jump box (center of picture) and cut off the clips (left side of picture). I purchased 3 plugs intended for high amperage starter loads and some 8AWG copper cable. I made an extension pig tail (right side of picture) which I installed on to the distribution device mounted on top of the battery and had the plug come out under the dash. Now to use the jump box I only need to take it out of the glove box and lean over and plug it in. I also put a connector onto the old clips (stowed under the hood) so I could do a good samaritan start on another car if that was ever needed. I recharge the jump box every 3-6 months to keep it fresh.
    Does it work? I am confident it will but I have yet to have the battery fail and it has now been 3 years. Sort of like carrying an umbrella to insure it is unlikely to rain.
    italiafan, mdrums and AD211 like this.
  8. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    Very resourceful!
    I think the solution is to have the battery monitor and a power pack jump starter just in case. I love how you made the quick connector.
  9. Mrpseudonym
    602
    Sydney, Australia
    Nice project!
  10. Bigbobo
    Bigbobo Karting
    Jul 25, 2020
    211
    Northern CA
    Well I feel your concern. My 2022 F8 that I have had less than 4 moths did not start today. It has been on the factory trickle charger every second that it is not driven. Now I have to figure out when to jump it and get it back to the dealer that is 90 minutes away.
  11. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    Get a portable jump starter on Amazon as they are relatively inexpensive. Jump and drive to dealer for service.
    I’ve done a lot of research and watched video reviews on YouTube and the GOOLOO GP4000 seems to be the best as far as performance and value. The noco gp70 is good too, but is a lot more expensive
    Install a battery monitor per this thread so you can see your battery starting to fail before hand
  12. rw99
    rw99 Karting
    Jan 1, 2019
    130
    SF Bay Area
    Rich
    Wow, that’s really disappointing. Please return to this thread when it’s been diagnosed…
  13. Mrpseudonym
    602
    Sydney, Australia
    DiamondDog likes this.
  14. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    I could not find an easy way to get the Matson brand in the USA
    I bought this and it has Bluetooth 5.0 and pretty long range. I think these are pretty much the same.
    For those of you worried about you battery dying, this 40 dollar device tackles a minute to install and will warn you before you battery fails.
    https://a.co/d/j1BnMuV
  15. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    Best thing is just replace your battery with an Antigravity and you won’t have to worry.
  16. DiamondDog
    Aug 29, 2021
    1,465
    Orange County, CA
    You guys may want to consider this 40 dollar solution
    It will tell you when your battery starts failing
    2 minute install
    LNEX Car Battery Tester, Wireless Bluetooth 5.0 RV Battery Monitor, 12V 24V A... https://a.co/d/j1BnMuV
    Matson has a good version that shows you every start on a calendar. But it’s only available in Australia. Lots of versions in USA but none I can find so far that records every day on a calendar view
    Mrpseudonym and AD211 like this.
