Tupolev A-3. Not exactly a plane, but... | FerrariChat
Discussion in 'Aviation Chat' started by Crawler, Nov 7, 2012.
  1. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    #1 Crawler, Nov 7, 2012
    This machine was at the Hilton Head Concours last weekend. According to the owner, it was built by Tupolev in the late 60s as a rescue vehicle for cosmonauts stranded at sea. Due to the prevailing water temperatures, it was essential to get to survivors as rapidly as possible. It was designed to be carried by a helicopter and winched up and down. Extremely cool!
    Here's the Wiki entry. Different story than what I heard. It even mentions this particular "survivor".
    http://en.wikipedia.org/wiki/Tupolev_A-3_Aerosledge
  2. Gatorrari
    Gatorrari F1 World Champ
    16,460
    Georgia
    Jim Pernikoff
    #2 Gatorrari, Nov 7, 2012
  3. johnei
    johnei Formula 3
    1,298
    Seattle
    John Wiley
  4. Tcar
    Tcar F1 Rookie
    Hmmm...
    Thought they'd be counter-rotatating props.
    But the metal edge guards look like they both rotate clockwise.
    Anyone know?
    Also, the props were painted between the first and the second set of pics, it looks like.
    It's obviously running in a couple of the pics...
    Edit: Since the prop offset is the same in all pics, I'm now assuming that they both rotate clockwise; staggered about 10 degrees or so. Strange.
  5. Cliff Torus
    Cliff Torus Karting
    Oct 10, 2012
    134
    Fairfax County VA
    Cliff Torus
    Uh Tcar, it's rotating not rotatating. C'mon buddy...chop chop
  6. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    I imagine that the small diameter limited the mass flow that was required. Two wide cord blades slightly offset seems like a damn good idea to operate them like a slotted wing flap. I don't know what the heck I said but it sounds really hi techinal.
  7. Gatorrari
    16,460
    Georgia
    Jim Pernikoff
    I think that's basically the technology, Bob.
    Not only have the props been refinished, but he's painted the beast's name on the bow and added a red stripe to the black one running along the side. I wonder if he can get the engine to run, now?
  8. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I am surprised they didn't go with a ducted fan design.
    One of the most efficient in a small area.
  9. Tcar
    Tcar F1 Rookie
    #9 Tcar, Nov 7, 2012
    Slotted flap... works for me.
    Also, looking closer, the inside blade is a wider (chord?) than the outside blade... the inside blades almost look like paddles. Like a two-stage compressor. :)
    The '57 Caddy fins are cool too.
  10. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    But your last photo appears to show it running?
    Pete
  11. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    The Germans and us would most likely go for a ducted fan but the Russians are driven to do the simplest and most rudimentary solution to basic problems. They are good at it.The T-34 tank is a good example of it as was the Stormovik . You're correct, though, a ducted fan would probably be the most efficient but fancy and expensive for the Russians, maybe.
  12. Gatorrari
    16,460
    Georgia
    Jim Pernikoff
    That was him trying to run it! The engine would sputter long enough for the prop to make a couple of revolutions, but it would never keep running. The engine is just a common aircraft radial, so I don't know why all the problems.
  13. Ferrari_250tdf
    Ferrari_250tdf Formula Junior
    Mar 3, 2005
    479
    I remember this thing being on a BJ auction in Scottsdale some years ago. But I don't remember the year and the if it was sold there.
    Matthias
  14. Tspringer
    Tspringer F1 Veteran
    Apr 11, 2002
    6,155
    Skills man.... you got skills!
    Terry
  15. Tcar
    Tcar F1 Rookie
    It's running in the first and last pics...
  16. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,948
    The Cold North
    Tom
    Looks like a small version of the ekranoplan's the soviets built during the Cold War.
  17. Tcar
    Tcar F1 Rookie
  18. Gatorrari
    16,460
    Georgia
    Jim Pernikoff
    #18 Gatorrari, Nov 8, 2012
  19. Ak Jim
    Ak Jim F1 Veteran
    9,616
    North Pole AK
    Sir, great analysis, the only thing I would add is it probably requires 12 gallons of prop wash per mission.
  20. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    Thanks, just my thoughts about it. The " Prop Wash" brings back the first day on the line at Hondo when an old hand told me to see if I could find a gallon of prop wash that they needed. Well, I spent the entire day tramping all over the flight line " looking " for that prop wash and checking out everything that was going on in all locations. I had the day off, had a good meal at the mess hall, and pulled a bit of a gag on the old hand because I knew damn well what prop wash was. Then I was sent to get a spool of flight line. The beat went on.
  21. Crawler
    Crawler F1 Veteran
    Jul 2, 2006
    5,018
    #21 Crawler, Nov 9, 2012
    Those, in turn, remind me of the famous German "Rail Zeppelin" of the early 1930s. Capable of more than 200 kph!
  22. Gatorrari
    16,460
    Georgia
    Jim Pernikoff
    #22 Gatorrari, Nov 9, 2012
    And that, in turn, reminded me of the "Black Beetle", a New York Central RDC that was modified with a twin-J47 jet pod from off of a retired B-36 bomber, and a special streamlined nose. In July 1966 it set a U.S. speed record of nearly 184 MPH (which still stands). Then the modifications were removed and the RDC was returned to normal service. The J47s were transferred to a snow-blower car that the railroad built.
  23. Gatorrari
    16,460
    Georgia
    Jim Pernikoff
    #23 Gatorrari, Nov 9, 2012
  24. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    That streamlined nose with the small windscreen "eyes" and NYC logo "mouth" looks meaner and more determined than Darth Vader.
  25. Tcar
    Tcar F1 Rookie
    But... that's 'only' about 120 mph...
    Shoot, the 'Santa Fe Super Chief' went almost that fast (well over 100 mph) across Kansas and eastern Colorado in the 40's, 50's and 60's. It was just a stock EMC (General Motors) Diesel-Electric locomotive passenger train. I rode on it when I was a kid (Iowa to Albuquerque and Albuquerque to LA).
    https://en.wikipedia.org/wiki/Super_Chief
