Turn signal always illuminated when headlights on | FerrariChat
Discussion in '348/355' started by chris marsh, Aug 10, 2023.
  1. chris marsh
    chris marsh F1 Veteran
    5,742
    Detroit
    Chris Marsh
    I really hate to start a new thread but a search didn't help.
    My 348 the right rear turn signal (yellow) stays on when headlights are on.
    When headlights are off all turn signals work normally.
  2. 308 GTB
    308 GTB F1 World Champ
    11,650
    New Jersey
    Barry Wolinsky
    ShineKen, WATSON and Qavion like this.
  3. Qavion
    Qavion F1 World Champ
    13,851
    Ian Riddell
    Is it only headlights or sidelights, too?
  4. chris marsh
    5,742
    Detroit
    Chris Marsh
    Well, the side lights come on with the headlights.
    Do you need me to check and see if the side lights are on?
    BTW I just replaced all of the bulbs in the rear. My next step is to replace all of the bulbs in the front.
    I have bought the entire headlight assemblies but probably won't get around to installing them until winter.
  5. Qavion
    13,851
    Ian Riddell
    #5 Qavion, Aug 10, 2023
    Understood, but does the RH turn light come on with just the sidelights illuminated. I think I would have a hard time linking the headlight circuits (specifically) to the turn signals.
    I can't think of anything obvious at the moment other than earthing issues. On the F355, I know where the earths are (in impossible to reach places) above the radiators. Looking at the 348 parts diagram, I see an earth in that general area.
    I have a picture of the LEFT hand earth on the F355 here
    Basically, it's under the rear buttress. There is one on each side.
    Apart from that, I can only think of rear light assembly internal wiring issues.
  6. chris marsh
    5,742
    Detroit
    Chris Marsh
    I don't know anything about electricity. Frankly it scares the heck out of me.
    So, can a bad earth cause a light to come on? I thought that would only make it NOT work.
    When I replaced the bulbs I could not get one out because the wire was pinched behind the entire assembly. I was able to loosen the screws and slid the wire out. I don't know why but I wondered if someone previous might have unplugged those wires to change the bulb. If they plugged them back into the assembly in reverse could that affect anything?
  7. chris marsh
    5,742
    Detroit
    Chris Marsh
    Qavion likes this.
  8. Qavion
    13,851
    Ian Riddell
    You would think so, but I've seen it on my own car. i.e. unrelated lights illuminating or flashing due to a bad earth. Electricity tries to find a path back to the battery via a good earth and if it doesn't get one, it goes through the closest thing it can find to an earth (e.g. a bulb element).
    Unfortunately, I don't have a wiring diagram which goes into that kind of detail.
    Quite possibly. You would have to compare it with another 348. Unfortunately, I don't have a 348 to play on.
    Have you tried shaking/flexing the wiring harnesses in the engine bay to see if the light goes out?
    308 GTB likes this.
  9. chris marsh
    5,742
    Detroit
    Chris Marsh
    No. I haven't jiggled the wires but I will on your suggestion.
    I will also try swapping those wires around that I am suspicious of. Then I'll try getting to the ground connections that you suggested.
    I thank you very much for your input!
    Qavion likes this.
  10. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    921
    Europa
    Bob
    Most auto electricians in this situation would probably start with a visual inspection of any wiring that can be easily seen, looking for corrosion or fatigue points, then by pulling the front and rear lamp units containing the turn signal to check for continuity between the plug and each individual bulb sockets (switched & earth conductors) then checking for shorts across pins on the lamp units. Do a good visual inspection for corrosion, broken or loose conductors etc. as you go.
    If the lamp units check out, front & rear, then it’s time to check the pins in the harness for each lamp unit. Make sure you plug the other lamp unit back in, eg. when you’re testing the rear harness plug, reconnect the front lamp unit and vice versa.
    If you see a short in the wiring between the turn signal and position lights then pull the hazard & turn signal relays & check again, if the short has gone with the relay out then it might be the relay or wiring backwards from the relay. While you have the relay in your hand, check its function.
    If you still haven’t found the problem then it could be in the column stalks. IMO, the best way to test it thoroughly is on the bench. If the column stalks are fine, then you are left with a short in the wiring.
    If by now you haven’t found the fault then this is where the “fun” starts. You will need to isolate the issue as best you can before digging into the loom.
    Hopefully, you find that it is either a problem in one of the lamp units (eg. corroded earth) or a simple pinched wire in a readily accessible area. All the best with it.
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,153
    CT
    John Kreskovsky
    Yes. Not unusual. Problem is finding where the bad ground is. It's never where you think it might be.
    Example, a bad ground in my pickup's tail light causes the instrument panel lights to come on when ever I stepped on the brakes.
  12. Qavion
    13,851
    Ian Riddell
    #12 Qavion, Aug 11, 2023
  13. chris marsh
    5,742
    Detroit
    Chris Marsh
    I'll change the front bulbs before I do anything else.
    But I can't get to it until next week.
  14. spaghetti_jet
    Jan 5, 2005
    921
    Europa
    Bob
    I hope the front bulbs fix it, if they do, celebrate.
    otherwise, you should follow a systematic diagnosis approach like the best pros do. Internet guesses and theoretical postulating is unlikely to fix the issue (unless you get lucky).
  15. chris marsh
    5,742
    Detroit
    Chris Marsh
    I did change all bulbs front and rear. Fixed the lenses in front as well as they were cracked/ disconnected and floating around inside the housings.
    I checked all of the wires in the tail light assemblies and spliced out any questionable areas (smashed). Put new connectors were needed.
    Put everything back together and lights would come and go, even the ones I had just installed new connectors on. I took everything apart again and cleaned connectors with DeOxIt contact cleaner. Looks to be stable now.
    Everything is much brighter now, but still have exact same issue of turn sigal being illuminated when headlights are on.
    I'm tempted to order new light/turnsignal stalk but it is $2500.00.
    I'll get under the car and try those ground wires first as I have not done that yet.
    Qavion likes this.
  16. Qavion
    13,851
    Ian Riddell
    I don't see how only one light would be affected if the stalk was faulty.
    If the rear ground wires for the lights are the same as the F355's, they will be under the rear buttresses, not under the car.
    F355's shown here (left hand one) in the forward top corner of the engine bay.
    I'd be interested to know if the 348's are in the same location.
  17. chris marsh
    5,742
    Detroit
    Chris Marsh
    I'd be interested to know also before I start searching.
    I did try running a jumper from the black wire on each light to the negative battery post. (One at a time) That didn't change anything.
  18. Qavion
    13,851
    Ian Riddell
    Ah... ok... Seems we are running out of options.
  19. m.stojanovic
    m.stojanovic F1 Rookie
    3,165
    Malaysia - KL
    Miroljub Stojanovic
  20. Qavion
    13,851
    Ian Riddell
    If you pull the bulb for the RH rear turn light, can you check to see if there is 12 volts on the lamp holder (centre contact) with the sidelights turned on? Don't use the lampholder as your earth. Use a separate chassis earth.
    I'm just trying to make sure that there is not an issue on the power side of the turn light. I don't think there is, otherwise the turn arrow on the dash and the front right hand turn light would illuminate.
  21. chris marsh
    5,742
    Detroit
    Chris Marsh
    When in this mode, the yellow light is checking 10.5v and the red light 11.5v. (battery is at 12.05v). I did not think to check the voltage when in blinker mode and I won't be back at the car until monday.
  22. chris marsh
    5,742
    Detroit
    Chris Marsh
  23. Qavion
    13,851
    Ian Riddell
    From this, I would definitely say the fault is on the power side of the wiring, rather than on the earth side. But... if there was, say, a short between the sidelight power wiring and the brake light power wiring, why don't the red sidelights illuminate (when switched off) when the turn signals are used.
  24. Steve Magnusson
    26,542
    #24 Steve Magnusson, Sep 15, 2023
    What year/version 348? (Your Profile seems to have never been updated, and only shows a 308QV.)
    Is this a problem that wasn't there and suddenly showed up, or something that has always been there during your ownership? 348 have an unusual hazard light/turn signal architecture, and there is a relay that only runs the RH rear turn signal light in the hazard function so, if that's wacky (or someone substituted the wrong thing), it could turn "on" the RH rear turn signal light yet not turn "on" the RH turn signal lamp in the dash nor the RH front turn signal lamp. Not yet saying that that's it, but just unplugging some of these additional hazard function relays might give a clue of where the trouble lies IMO.
  25. Steve Magnusson
    26,542
    Need to correct myself (and the editing time expired!). Not so sure that anything (stock) could just turn "on" only the RH rear turn signal so could be molestation, but I can't even find where these hazard function relays (shown on the 348 WSM schematics) are located ;).
