Turn signal flasher and "hazard relay", '79 308 | FerrariChat
Discussion in '308/328' started by AZDoug, Feb 24, 2020.
  1. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    What exactly, does that large square metal box, labeled relay for emergency flashing, in the owners manual, do?
    The basic turn signal wiring diagram i looked at online, doesn't show it, it shows the normal flasher as controlling the hazard lights function.
    Does the turn signal flasher act as a flashing switch for the relay? Does the relay actually do the flashing function when the hazard switch is turned on?
    I honestly feel like i am going blind from trying to read the wiring diagram in the owners manual with all the lines so close together.
    Trying to isolate a turn signal issue.
    Thanks,
    Doug
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,309
    South East
    Jimmie
    If your winkies give up after using the hazard switch it could be the output from the hazard switch to power the indicator system - cure = replacement hazard switch
  3. ragtop1
    ragtop1 F1 Rookie
    4,995
    Ontario
    Larry Warren
    order this wonderful color-coded wiring diagram from
    http://www.paul-bennett.com/Ferrari/
    Price - $30For lifetime access to ALL drawings.
    Plus many owner's and workshop manuals.
    Forever.
    I have mine printed at blueprint size 36x24 and laminated. AWESOME !!
  4. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    I ordered it, but have yet to hear back on a download link...
    Doug
  5. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    That begs the question:
    How is that console panel that contains the switches, removed?
    I see some screws holding the shifter gate in place, does removal of the shift gate allow the switch panel to swing up or off?
    Thanks,
    Doug
  6. ragtop1
    ragtop1 F1 Rookie
    4,995
    Ontario
    Larry Warren
    remove the ashtray. 2 screws. then it all comes apart. You don't have to take off the shift gate
  7. Banzairacer
    Banzairacer Formula Junior
    482
    San Diego, CA
    Sanjeev Thohan
    just be careful when you do lift it. there are switches that can come apart with some very very small pieces that are almost irretrievable unless you have surgical tools. My defroster switch came apart and I almost lost the little plastic nipple that connects it to the switch plate internal to the mechanism... Hemaostats, long forceps and some crazy glue to stabilize the plastic to the metal housing of the switch was the trick. also make sure that the slide sitches on the heating are all pushed forward otherwise you'll have to turn and torque the plate.... never a good idea in an older ferrari....
  8. Banzairacer
    482
    San Diego, CA
    Sanjeev Thohan
    here is a nice video of one taken apart....
  9. Steve Magnusson
    25,123
    #9 Steve Magnusson, Feb 24, 2020
    Unlike many other F models, 1978-79 US version 308B/S have 2 separate flashing units -- one flashes only the turn signals, the other flashes the hazard lights (i.e., more of them at the same time).
  10. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    Well left blinker works, the right occasionally, so probably dirty contacts in the turn signal switch.
    But, the hazard lights don't work. The dash indicator light comes on and stays on, no flashing anywhere. Not sure if the issue is the hazard switch, or that box relay box to the right of the fuse blocks.
    Doug
  11. Steve Magnusson
    25,123
    I don't think it is a problem with the hazard switch (but it still could be) as it has two functions:
    1. When "off" it conveys +12V to the turn signal flasher -- so, since your LH turn signal is working (even though the RH turn signal is flaky) that part is working, and
    2. When "on" it conveys +12V to the emergency flasher -- so, since you report that the emergency flasher light in the dash illuminates (even though it doesn't flash) shows that +12V power (or some power) is reaching the emergency flasher (even though it doesn't flash).
    The only other "simple" thing it could be is maybe a bad ground at the emergency flasher (bit your power windows also wouldn't work if this is the case). My suggestion (after unplugging and replugging the wires at the emergency flasher just to rewipe the connections) would be to measure with everything plugged in and the emergency flasher switch "on":
    A. The voltage between the H (grey) wire at the emergency flasher and the N (black) wires at the emergency flasher = should be +12V
    B. The voltage between the H (grey) wire at the emergency flasher and a known good ground = should be +12V
    C. The voltage between the N (black) wires at the emergency flasher and a known good ground = should be 0V
    If you pass tests A thru C = that has to cast suspicion on the emergency flasher itself being bad. If you get some different results for tests A thru C give a shout back with the results as that may give a clue of where to look for trouble.
    Just as a side issue, it's interesting to note that, on later models, they used a much more complex, multi-connection emergency flasher switch in order to eliminate the emergency flasher and use a single flashing device for both turn signals and emergency flashing.
  12. sranderson
    sranderson Formula Junior
    Nov 15, 2003
    286
    SRA
    Hello All
    Can anyone tell me which wires go onto which terminal on the emergency flasher relay (or post a picture)?
    Not sure the PO had it right
    As my unit stands, the
    the grey wire is on the + (power)
    the black wires are on the P (ground)
    the blue/white wire is on 31 (to dash indicator)
    the blue wires are on 5
    the blue/black wires are on 2
    thanks,
    Steve
  13. Steve Magnusson
    25,123
    The '78-'79 US 308 B/S 150/78 OM schematic shows:
    the black wires are on the 31 (ground)
    the blue/white wire is on P (to dash indicator)
  14. sranderson
    Nov 15, 2003
    286
    SRA
