Turn Signal not working | Page 2 | FerrariChat
Discussion in '348/355' started by jssans, Aug 20, 2008.
  1. Qavion
    Qavion F1 World Champ
    14,625
    Ian Riddell
    Should be enough.
    Do the checks at the turn module, not the steering column!
  2. Shurik355
    Shurik355 Formula Junior
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    Yes I meant that turn module im working with.
  3. Qavion
    14,625
    Ian Riddell
    I've trying to figure out the meaning of the numbering on the modules. According to Ricambi, there are four different types of (apparently) non-interchangeable modules. The USA version of the late 5.2 cars has the part number 213326. When I Googled this number, I found a photo of the relay with "3(6)x21W" printed on it. I assumed this number applied to all USA F355's because of the extra side repeater lamps. My late model non-USA car's module has the number "12V/2(4)x21W" printed on it. Early non-USA cars also have "12/2(4)x21W" on them.
    Then I saw Alex's early USA car module which has "12V/2(4)x21W" printed on it. I now have no idea what relevance the numbers have.
    The electrical wattage (or current and resistance) of the indicator circuits is critical, otherwise you get "hyperflashing". On non-USA/Can/Jap cars, there are two 21 watt lamps (per side) plus a single 4 watt side repeater, a 2 watt instrument panel turn arrow and an acoustic repeater (which is part of the output circuit on early cars). Does anyone know the wattage of the USA side repeater lamps? Are they 3 watts each = a total of (6) watts per side?
    Does Alex have the wrong relay fitted?
  4. Qavion
    14,625
    Ian Riddell
    Wiring diagram updated to show alarm interface.
    F355 (2.7) Lighting_Diagram
    (Note: the alarm is not an issue in this case. The alarm uses the hazard light power source and outputs flashing light signals via normal left and right hand indicator splices "30043" and "30044".)
  5. Shurik355
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    Hmmmm interesting. Maybe my F355 is fitted with the wrong module? Weird.
    Well Im about to do the module soldering here and will check the #3 with voltmeter.
    With my USA car I have 12V/2(4)x21W same as your Non-USA car. Strange maybe 12V/2(4)x21W were made for all 2.7 Euro and USA???
    Need someone confirm what their module #s are on the 2.7 USA car.
  6. Shurik355
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    ok did my re-soldering and decided to test it out before checking the #3 with the voltmeter. After re-soldering the right blinker works now :D
    Ian you are the man! big thanks to you my friend. You were the right man in this discussion!!! Thank you so much!!!
    Wish we could give you 100 likes at once :D
    F355Bob, Qavion and SoCal1 like this.
  7. Qavion
    14,625
    Ian Riddell
    #32 Qavion, Jun 4, 2019
    YAY!!!! Too easy ))))
    Thanks for the update. Finally, a cheap fix.
    So your relay must be the correct type.
    (EDIT) Getting off topic, but here's a link to a photo of the later 5.2 USA car's module showing the 3(6)x22W numbering:
    https://www.ferrarichat.com/forum/posts/144148037/
  8. Shurik355
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    so pretty much;
    Euro and USA 2.7 cars have 12V/2(4)x21W
    Euro and USA 5.2 cars have 12V/3(6)x21W
    Thats sounds like how it is?
  9. Qavion
    14,625
    Ian Riddell
    No, Euro 5.2 cars also have 12V/2(4)x21, but, as others have noted, you can't go entirely by what is printed on the case. The Ferrari part number appears to be the only guarantee of compatability. I've assembled the following data based on Ferrari catalogue numbers and photos on the forum (and eBay) matched to those Ferrari catalogue numbers
    USA/Can/Jap (vehicle assembly number 24037 and before) P/N 164369 (No longer available) [B883 60570359 72631 12v/2(4)x21W 73404]
    USA/Can/Jap (vehicle assembly number 24038 and after): P/N 213326 (No longer available?) [SDC B883 171375 82019 12v/3(6)x21W]
    Other countries (vehicle assembly number 24037 and before): P/N 158019 [SDC B883 60570359 72631 12V/2(4)x21W 73404]
    Other countries (vehicle assembly number 24038 and after): P/N 171798 [SDC B883 46466571 81894 12V/2(4)x21W]
    When I had a problem with my indicators, I bought a module using the catalogue number, but it was worse than the one I already had. I don't know if the vendor had mixed up the modules or if it had been sitting on the shelf too long.
    The late model 5.2 USA module is compatible with (USA) F360's I see.
  10. andyw355
    andyw355 Karting
    Jul 5, 2011
    72
    Australia
    Andy
    This worked for me a few years ago. Same problem.
    Qavion likes this.
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Thank you this made my day very easy :)
    Qavion likes this.
  12. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,636
    Tim Dee
    #37 SoCal1, Jul 26, 2019
    Thanks again, got brake and signals now so I am TOTALLY legal.
    Tomorrow I'll find the front signal wires or run some and front daytime runners + signals
    Shurik355 and Qavion like this.
  13. 308Jon
    308Jon Rookie
    Sep 18, 2015
    24
    Jon Roberts
    What a brilliant, informative, detailed posting this thread is. I had an intermittent RH turn signal not working - located the relay and disassembled it. With a magnifying glass I found visibly cracked solder joints on 15R and L on the PCB. Re-soldered and problem solved. Thanks everybody !
    Qavion likes this.
  14. Odeezy
    Odeezy Rookie
    Oct 10, 2020
    45
    Los Angeles
    Jason O'Dell
    Just wanted to shout out to this forum! I had the same issue and a quick solder on the same connections as @Shurik355 did the trick!
    Qavion likes this.
