Turn Signal Relay | FerrariChat
Turn Signal Relay
Discussion in '348/355' started by frogwo, Feb 12, 2007.
  1. frogwo
    frogwo Formula Junior
    Jan 15, 2005
    283
    Would anyone be able to provide me with the manufacturer's name and ten digit part number of the FERRARI part (number 164369) Turn Signal Relay.
    Found in FERRARI 355 (2.7 Motronic) - DIRECTION-EMERGENCY LIGHTS RELAY
    FERRARI 355 (5.2 Motronic) - DIRECTION-EMERGENCY LIGHTS RELAY
    Thank You.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I don't know if this will help in the slightest, but I have a note regarding the numbers on the turn signal flasher on my 348. It is marked:
    ITALAMEC 12V 42/46W(x2) DOT299 73352
    This would be for Ferrari part number 159265, "Direction Lights and Emergency Flasher", item #45 in Tav.145 of the 348 Parts Book.
  3. frogwo
    Jan 15, 2005
    283
    Part number is different for the 355 as you can see from my request.
    Thank you anyway.
  4. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I know that the Ferrari part number is different. I thought you might be able to determine if both the 348 and the 355 (or some other Ferrari model, or an Alfa, or....) use the same ITALAMEC number, if a 355 owner came up with the information you requested.
  5. ronrob
    ronrob Formula Junior
    Jan 15, 2007
    395
    Var, S.E. France
    Ronald Brown
    The flasher relay for my 1997 355 (Euro version) has the following written on its case (in common with the other relays on the same side of the box):
    12V 20/30A
    0 332 209 159
    BOSCH
    Hopefully, this is the info you are looking for.
  6. frogwo
    Jan 15, 2005
    283
    Thank you RonRob Turn Signal Relay is different on EURO Car five (5) pins.
    US 355 has a eight (8) pins.
    Somebody please help with information needed.
    Than you.
