Turn signal switchgear for Countach and early Diablo | FerrariChat
Discussion in 'LamborghiniChat.com' started by JohnMH, Nov 6, 2017.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,825
    Bologna
    Anyone have a source for the turn signal / lights steering column switchgear for a Countach?
    Part no. is 004320773, but I understand it may be NLA.
    Thanks to all.
  2. S_AGATA
    S_AGATA Formula Junior
    Aug 24, 2016
    572
    Mill Valley CA
    Jon/Sean Sohaei
    I may have a couple. I'll send some photos either tonight or tomorrow morning.
  3. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,825
    Bologna
    Awesome! I have not yet mastered the PM with the new site but perhaps try me.
    S_AGATA likes this.
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Trawl round on ebay they are lucas 163sa and 164sa from memory can be found but may take a while
  5. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
  6. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,825
    Bologna
    Can the switch be opened and repaired with new parts? I found a 163sa Lucas unit (new) but the unit only has a turn signal / light switch, no wiper switch. If the internals are the same a fix may be possible if I cannibalize the new car new one.
  7. hashiriya
    hashiriya Formula Junior
    Feb 26, 2010
    352
    Kinda like so. Also if you find the complete turnlight unit, it's likely the connector would not fit any.
    Free hint: Rover SD1
  8. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,854
    Italia
    i have the 400, 400S unit if you need it
  9. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    I got one from a classic Mini (lucas unit) brand new a few years back for about $60. Wiring and switches were the same but the pin positions on the connectors were different. Just had to take time to ohm it out to figure out which wires did what and move the pins around. There was also a reason I had to disassemble the unit to change something over, but cant remember what it was exactly ??? If you need the part # I can dig up the receipt.
    Jalpa_Mike likes this.
  10. blown daytona
    Feb 6, 2008
    1,679
    maryland
    Just came to me , the cancelling cam size on the lucas unit was too small. I used the main housing and cancelling cam from the lambo and transfered all the switches from the lucas unit.
  11. Doug R
    Doug R Karting
    Oct 11, 2005
    208
    Yellow Springs Ohio
    That's is some handy info, part number would be great!
  12. blown daytona
    Feb 6, 2008
    1,679
    maryland
    EarlyCat and Jalpa_Mike like this.
  13. Doug R
    Doug R Karting
    Oct 11, 2005
    208
    Yellow Springs Ohio
    Thank you. My lever is also sloppy, I always leave it forward to avoid accidental contact. I just ordered one, will be good to have on hand.
  14. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Did you also replace the wiper stalk as well? Looks like they carry that as well.
  15. blown daytona
    Feb 6, 2008
    1,679
    maryland
    I used my existing one
  16. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Image Unavailable, Please Login MiniSport has this neat little chart showing the differences in the turn signal/wiper stalks used on the Mini, TR-7, TR-8, Rover, etc... . Pretty obvious which one is like the Countach. :)
    (BAU5345 and BAU5346)
    I just ordered a set. Mine are not broken, just loose. So, I may just take parts and pieces from one or the other. I’ll make some side-by-side photos of the new units next to the old ones to show any similarities or differences. Can’t go wrong with the price...
    The turn signal, horn, flasher stalk was: $30.44
    The Wiper stalk was: $26.49
    Shipping from the UK was about $17.00
