Turn signals not working | FerrariChat
Discussion in '308/328' started by jonesdds, May 11, 2008.
  1. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    #1 jonesdds, May 11, 2008
    Turn signals stopped working recently. Fuse checks out fine. Got out the manual to see where the relay is. Found it but the cover of the relays in the passenger floorboard states it is the "Antiskid" relay, not the flasher for the turn signals. Basically, it contradicts the manual. I've got a picture of it and wondered if anyone else can confirm which it is. Also, how can these be tested to see if they work? Maybe there is another problem causing the turn signals not to work. They do not work either way, no sound or lights when on.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I don't know much about 328's, but it's always worth a try to just turn on the emergency flasher for a few seconds, then try the turn signals again. Sometimes it's just a "glitch".
  3. ragtop1
    ragtop1 F1 Veteran
    5,258
    Ontario
    Larry Warren
    check to ensure all lamps are good. On my '79, if one filament is broken, it opens the circuit and prevents the signals from working
  4. blainewest
    blainewest Formula Junior
    Aug 26, 2005
    729
    Kelowna, BC
    Blaine W
    I just went through my left side signal not working. Sprayed some contact cleaner into the switch (without removing it) working it while doing this, and it works like new now. You should try this before doing anything difficult.
  5. Steve Magnusson
    26,932
    That most definitely is not the Flasher for the direction indicators -- unfortunately, there is another relay called "relay for flashing" (which leads to confusion), but that's for flashing the (white) front lights when you pull back on the stalk. The Flasher has a larger rectangular outer case (rather than a cube shape) -- what your picture shows is relay similar to a common Bosch ...113 relay (but with a lower current rating).
    Item J (behind the passenger footwell) in this 1989 US 328 OM figure is the "flasher for the direction indicators" (note the taller shape):
    Jeff gave a good suggestion -- try your emergency flasher -- it uses the same flasher unit to do the blinking, so, if that works, you know the flasher is OK and the trouble is in the direction indicators wiring/switch/etc.. If the emergency flashers don't work either, then that warrants making some voltage measurements in the relay J socket.
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Interesting..... my Swiss Market 328 has the turn signal flasher underneath the dash in the steering wheel shaft area.
  7. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,298
    Colorado
    Dave
    You might want to check to see if there are any loose connections under the steering column. They come off pretty easy. Happened to me once.
    Dave
  8. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    The J socket is where this "relay" came from unless I'm reading the diagram in the manual wrong(I don't think I am). It's not cubed it is taller than the cubed relays and there is an empty socket next to it. But, the diagram on the cover(underside of it) states it's antiskid relay and I confirmed I didn't have the cover on backwards. Really makes no sense. Is it possible that non-ABS 328's have it in that location but with ABS 328's it's located somewhere else and the manual was never properly changed for the ABS cars. I'll check the emg flashers, didn't try that yet and look for the flasher where eulk suggested. Anyone with an ABS car confirm this?
    Jeff
  9. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Can you give me a more detailed location-right or left of the steering shaft, etc.?
    Also, how can one voltage test to see if the flasher/relay is bad?
    Jeff
  10. Steve Magnusson
    26,932
    #10 Steve Magnusson, May 11, 2008
    What "manual" are you referring to? -- can you post the diagram?
    I know of many cases where the later OMs don't get updated correctly -- so anything's possible, and I just noticed that in the non-ABS and ABS 328 wiring diagrams for the relays they show nothing at all in that "J" position (so that seems strange too if you've got something there).
    The flasher is shown a three terminal device in the non-ABS and ABS US 328 wiring diagram schematics -- can you please give the terminal numbers shown on that particular relay.
  11. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    The original manual for my car. It's the same diagram you posted above, exactly. Backside of the floorboard, passenger side, I pulled what I took a picture of from the J position. I'd have to look and see if the J position this relay was plugged into has three or four pin inputs, maybe the relay I took the picture of was not a correct relay?
    Jeff
  12. Steve Magnusson
    26,932
    Sometimes there are extra unused pins on devices, so having 4 tabs doesn't necessarily mean it's wrong. Unfortunately, the terminal numbers in the .pdf files of the 328 wiring diagrams I have are just illegible (maybe one is "31"), but if you can post what's shown on that relay (and which ones actually have a mating wire in the socket) perhaps someone with a better copy can see if the terminal numbers match up.
  13. Steve Magnusson
    26,932
    Forgot to add that the wire colors at the socket might help identify things -- both ABS and non-ABS 328 US wiring diagrams show the connections to those three used terminals on the Flasher as:
    one terminal = one N (black) wire = always ground
    one terminal = one M (brown) wire = always +12V when key "on"
    one terminal = two BN (white/black) wires = one goes to the turn signal switch center pole and one goes to the hazard switch. When the flasher unit cycles "closed" -- these BN wires are connected to the M wire.
    Once you confirm the Flasher location, and if the hazard lights don't work either with the Flasher in place, remove the Flasher and connect a male-to-male jumper wire between the M wire and the BN wire female terminals in the relay socket (simulating a "closed" Flasher). Turn the key "on" and set the turn signal stalk to signal left (hazard lights "off") -- all of the LH turn indicator lamps should come "on". Likewise, set the turn signal stalk to right with key "on", and all of the RH turn indicator lamps should come "on". If you pass this test, you can be pretty sure the the wiring and switch is OK and that the Flasher unit itself is bad. If you don't pass this test, you can't conclude anything about the Flasher and need to find out why. Good Hunting!
  14. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    The relay/flasher has this config, a standard relay config I think:
    ____
    87
    [ 86 ] 85
    ] 30/51
    Hope this makes sense. This isn't a flasher, but a relay, correct?
    jeff
  15. Steve Magnusson
    26,932
    With those terminal labels I would make the same conclusion -- it's simple relay -- not a flasher. Is the wiring in the socket (either # of contacts, wire colors, etc.) also different than as I described?
  16. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    I haven't had a chance to check, will tonight. Thanks for the help, Steve.
    Jeff
  17. BlueMax
    BlueMax Formula Junior
    Aug 6, 2006
    317
    Murrieta, CA
    JR
    Someone else chime in if I'm way off-base here, but I'd be careful spraying contact cleaner into your stalk switch. I have heard of other folks doing this and it eventually eats away at the plastic internals of the switch. (Read $$$ for replacement.) If you need to replace, though, Verell does a nice replacement for these switches at a fraction of what it would cost to even find one these stalks...
  18. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    Figured it out. The flasher is under the dash just to the right of the steering wheel. PO installer for the alarm system tied a alarm module to the wiring to the flasher and the weight of it unplugged it. Simply plugged it back in. Wonder why the manual states the flasher is in the J position on the diagram. Probably not the first thing the manual has been wrong on though. Thanks eulk328 for the post, it got me looking in that area.
    Jeff
  19. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    It's a lot easier to find when it's working and making a nice clicking sound so you can track it down. But then..... why would you be looking for it if it's working :)
  20. DGS
    DGS Seven Time F1 World Champ
    73,050
    MidTN
    DGS
    From the Oct '88 spare parts catalog:
    #9 - "Flascher for direction lights"
    61111200 - Until car 64125 - Not for US - Behind the footrest
    61048000 - From car 64127 - Not for US - Underneath the dashboard
    61814700 - US - Beneath the footrest
    61651800 - US - Underneath the dash board
    It doesn't specify the change point for US models.
    Tav 126 itself shows item 9 next to (and taller than) item 42: 62567200 - "Control relay for ABS system - USA and J MY89"
  21. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I wonder if this was done so it would be easier to hear the clicking of the flasher unit?? I imagine you would not hear much or maybe anything if it were mounted underneath the footrest.
  22. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    Jeff
    DGS, thanks for that info.
    Jeff
  23. MPalilonis
    MPalilonis Karting
    Sep 30, 2003
    216
    I have an early 86 328 Euro, number 916, and the relay is in the passanger foot well. I too had the same issue and after tearing apart the console and finding that the contacts needed to be cleaned inside the hazard flasher I still noticed an intermitant problem. So I traced it to the relay in the foot well and found that the coil was failing and a little kick of the panel, when installed, brings it back to life...interesting.
    Where can I buy a new relay from?? Can I go to a local parts place???
  24. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    This is what I'm using: http://superbrightleds.com/tail-brake-turn.html (scroll down to Electronic LED Flashers)
    It will work with standard incandescent bulbs or LED's. You want relay part # CF13GL-02 for this application.
    No yellow box with a horse on it but $12.95 + $5.00 postage works for me :)
  25. MPalilonis
    MPalilonis Karting
    Sep 30, 2003
    216
    Great...THANKS !!!
