Turning over a 308 Engine | FerrariChat
Discussion in '308/328' started by xpensivewino, Nov 17, 2022.
  1. xpensivewino
    xpensivewino Formula Junior
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    Good morning gents. I’m going to look at a 308 that is in “disrepair”. The engine supposedly will crank and turn over, but is said to have or is only running on 4 cylinders. That would point to an ignition issue not a mechanical seizure. Can you please advise me on the correct place to physically turn the engine over by hand? Which pulley in which location and what size MM wrench is required? This would be for a GT4. Any advice is greatly appreciated. Cheers Steve
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    1. Pulley rotation is clockwise.
    2. The crank pulley is always the one you're rotating.
    3. I believe the bolt needs a 36mm socket (going by memory here). You'll need a socket and long ratchet/bar - you can't do it with a wrench.
    absostone likes this.
  3. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    More than likely an ignition issue, but the front and rear bank have separate timing belts, so it would be possible it has a broken belt on one bank. Just something to consider if this is an exercise as part of a PPI because the ramifications are so much greater.
    Steve Magnusson likes this.
  4. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    Thanks for this info guys! Is the crank pulley on the drivers or passengers side ? US car. I can’t imagine the engine would turn through with a broken belt on one bank? A broken belt would almost certainly mean a wiped valve train. Are both belts visible from above or only with the wheel well access opened ?
  5. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,349
    Dumpster Fire #31
    SMG
    Passenger side, the belts are kinda visible. If it's a 308QV with the backing shields on the covers then no, you can't see the belts. Std 308 2V you can get a peak at them, best to use an inspection mirror. It's a tight squeeze top side but doable.
    You can certainly turn the engine by hand with broken belts and even with timing so far out that valves kiss pistons, but you'll feel the kiss point as enough resistance to stop before bending anything.
    Running on 4 is most always an ignition issue.
  6. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    Very very helpful guys. Thanks to all who replied
  7. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,192
    Kingsport, TN
    Lawrence A. Coppari
    36 mm socket is the correct one. I'm assuming you're going to remove spark plugs to make it easy to rotate.
  8. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    Well I went to see the car today at a very disreputable shop. Both engine cam belts are intact. The engine turns through, but the dealer claims that only 4 cylinders are showing compression?? If that is true, I’d have to assume that one bank was wiped and valves are at issue. I don’t mind doing a rebuild, as I do my own engines, but I’m fairly certain 308 engine bits are damn expensive these days.
  9. Schulz308
    Schulz308 Formula 3
    1,506
    STL USA
    I suggest you get a PPI from a reputable mechanic.
    Get the facts for $250 or so;)
  10. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,875
    Mike 996
    Since you do your own engine work, you know that with an interference engine, if the cam belt/chain breaks, not only are some of the valves toast, there is a good chance some pistons are as well. If so, it's a very pricy repair, though if you are doing it yourself, you are only paying for very pricy parts. ;)
    Assuming the dealer will allow it, if it was me, I'd do my own compression check before making any further decision re PPI/other inspection.
  11. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    The dealer is near impossible to deal with. They’re basically a sight unseen type of operation. I happen to live only an hour away, so it’s why I was able to go see the car. It’s not a nice example at all but it’s “all there” so a decent starting point for a restoration. As I said, both belts are intact so I don’t think a belt broke. I’ll see if they’ll allow a proper PPI to be done on the engine.
  12. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    If they want allow an inspection. Run. Better to pay for more $ for a nice example than than to try to restore a poor one.
  13. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    First off, I am not a professional and have very little experience buying 308s. I have only bought one. As a hobbyist mechanic however, I have now looked at pretty much every nut and bolt on my car.
    A concern is that some cars have been modified in subtle but significant ways and restoring them to stock can be expensive (e.g. wheels, seats, ignition). Having a knowledgeable expert identify what parts are correct and incorrect on an unknown exotic car is a big part of why a PPI is so important.
    The Ferrari parts that are expensive are the Ferrari-specific stuff. Wear parts – fuel injectors, spark plugs, etc. – are not silly-priced. Even the “expensive” services don’t use expensive parts. Timing belts are $37 each; the suspension bushing kit is a few hundred. However, both the belt service and suspension renovation are hugely labor intensive so the cost gap between DIY and professional service are huge. The engine has a trove of gaskets, seals, hoses and bearings that can be tired and can be expensive to replace only because of the labor cost to replace them.
    ... and the Professional Technicians say they witness a lot of problems caused by hack home mechanics.
  14. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    As a home mechanic, I’ve corrected a lot more issues caused by “hack professional technicians” than vice versa.
    Brian A and Extreme1 like this.
  15. ferrariowner
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    So we agree?
  16. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,640
    Toronto / SoCal
    Rob C.
    Everything can be fixed and the big consideration is what the car costs. If you are handy with tools and the price is right then there could be an opportunity for you here.
    It is true that the most expensive example will be the cheapest in the long rung but at the same time when you are a DIY'er you can do well for yourself, learn a lot, and have fun along the way. Parts are not horribly expensive what is VERY expensive is when you have to rely on someone else to do all the work for you.
  17. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    I do almost all my own work with the exception of painting. I enjoy the challenge of saving a car, so I tend to gravitate towards the lower examples. Much of that is driven purely by finances.
    dino1971 likes this.
  18. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    You can get a feel for engine part prices on the superformance.co.uk website. Rebuild cost depends on whether you just want to get it running again or get it back to almost like new. Pistons, liners, gasket set, valves and guides are most expensive items assuming heads, cams, rods, crank, block are all serviceable. Lots of “while you are in there” items that will add another 50% to your budget.
  19. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    I think a lot of the engine is serviceable. The problem is the dealer wants $50k and it’s worth $20k as it sits, and that’s being generous. It needs $15 in mechanical, $15 in paint, $10 in interior, and another $10 in seals and ancillary bits. And that’s with almost all my labor. Oh well nothing ventured nothing gained. I still learned a lot looking at it.
  20. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Walk away.
  21. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,243
    CT
    John Kreskovsky
    If that's the car at Beverly Hill Car Club, yes. walk away.
  22. johnk...
    Jun 11, 2004
    11,243
    CT
    John Kreskovsky
  23. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Seems to me like 50K for something you don't know pretty much what's wrong with is way to much. I think your 20K number is more realistic. If you can't at least use a bore scope to access the damage (if any) and run it (runs on 4 cyl) to check the trans and rear end I would walk away in a heartbeat. Last year I bent the exhaust valves in my 308, my fault, and ended up replacing all eight in the REAR head which I managed to get off with no trouble. If on the other hand its the front head or the head is corroded on (read threads about this) it will be a real pita. As far as cost goes most parts are available from superformance at a reasonable, albeit more than popular muscle cars. The rub comes when you get into things like sleeves or major castings as they can get expensive in a hurry. Recent article in Hagerty insurance pub details one of their guys buying a GT4 and sending the engine to a shop for what he thought was a minor problem. 20K later he got it back and even at that all the castings were ok. If you've never worked on a 3x8 I hope you have the right attitude. It's not that they are particularly difficult to work on just time consuming and more than a little frustrating at times. I spent the better part of the day yesterday changing a CV joint boot. So I spent most of the day replacing a $9 part. You sound like me as I'm in the school that says if I can't fix it myself it won't get fixed and that includes paint.
    Good luck
    Barry
  24. xpensivewino
    Jan 26, 2008
    954
    Simi Valley CA
    Need to know basis
    It is the BHCC car. I knew better going into it because they are the dregs of society, but I’m a sucker for the Charlie Brown Xmas tree. I am walking away. I do really appreciate all the info on this thread though. You guys are great and gave me some much needed info. Someday I’ll find the right car. Cheers
    MFlanagan and Saabguy like this.
  25. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    Next time, lead with that info. ;)
