turnsignal problems | FerrariChat
turnsignal problems
Discussion in '348/355' started by Dominique F348, Aug 8, 2013.
  1. Dominique F348
    Jun 8, 2013
    15
    Belgium
    Verbeke Dominique
    Hi,
    can anyone help me with the turnsignal lights ?
    if i use left or right they do not work but if i use the 4 signal lights at the same time they work !
    i've control the surance in the front and on the passengers side but there's all ok, maby the signallight box but i just find the box of the 4 signallights , i've changed the box just next the that box off the 4 signallights (don't know if this is the sapperate signalbox )but it did'nt help !
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,650
    South East
    Jimmie
    #2 greyboxer, Aug 8, 2013
    I'm sure this has come up before but in theory it could be the power and/or earth into the steering column
    I think there are two indicator fuses - one in each box - have you checked both ? Presumably there must be a relay somewhere too
  3. Dominique F348
    Jun 8, 2013
    15
    Belgium
    Verbeke Dominique
    where can i find the seperate signalbox ?
  4. greyboxer
    Dec 8, 2004
    12,650
    South East
    Jimmie
    Correction : both fuses are in the foot fuse box
  5. Intheflesh
    Intheflesh Formula 3
    Jun 2, 2006
    1,180
    Salem NH
    John T
    I had this issue. 4 way flashers worked, but my right (I think) blinker when used alone didn't.
    There's a relay behind the carpet in the drivers side foot well. Check there.
    I'll see if I can find a diagram.
  6. Dominique F348
    Jun 8, 2013
    15
    Belgium
    Verbeke Dominique
    this is what i try to tell in the first post about that signalbox, there are 2 boxes (one is for the 4 flashers and the 2nd° ??? don't know but i have changed that box to with no result ....
  7. Dominique F348
    Jun 8, 2013
    15
    Belgium
    Verbeke Dominique
    the problem is fixt, it was a bad massa(earth)
