Twin disk clutch installed height problem | FerrariChat
Discussion in '348/355' started by bosshog8, Jun 8, 2013.
  1. bosshog8
    bosshog8 Formula Junior
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    #1 bosshog8, Jun 8, 2013
    I am replacing my clutch disks in a twin disk system and have run into a problem with the installed height being too short. The manual specs it at 47 - 51 mm and I have definitely less than 45 mm and probably around 43 mm (it's a very hard measurement to actually get).
    The reason for the shortness is the new disks are 7.87 mm and supposed to be 7.25 mm. This has the effect of flattening out the pressure plate fingers too far and now they are so flat the release bearing doesn't even go far enough to release the clutch. I have the shims (0.76 mm) that came in the original setup installed.
    So my question is: Is there a source for these shims anywhere or some other thing I could use (besides washers) to shim it? Or some other solution?
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Why not just get the new discs machined down to the proper thickness?
  3. fatbillybob
    Aug 10, 2002
    29,256
    socal
    yes! E knows our famous rebuilder who knows what to do but rarely does it. Some of these guys have been breathing clutch and brake linings for too long. Make the vendor make it right. Don't bandaid this
  4. bosshog8
    Mar 13, 2011
    448
    Pinelands NJ
    Demetrius
    This would be a great solution if the "vendor" wasn't a guy from England who was getting rid of his unused new parts 8 months ago. So I own them and that's pretty much that. I need like 1 mm maybe 2 mm at best to get the fingers in the proper position.
  5. fatbillybob
    Aug 10, 2002
    29,256
    socal
    Fort Wayne clutch or friction materials co. Near you. Have them trim the material to the right thickness or remove and replace to spec with organic or Kevlar material.
