Two Black Wires under Ignition Switch | FerrariChat
Discussion in '308/328' started by miketuason, Apr 26, 2020.
  1. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,825
    Cerritos, CA.
  2. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
  3. 308 milano
    308 milano F1 Veteran
    5,342
    Montana
    Kim
    I am away from home at the moment So no way to check but does the parts manual List it as ignition switch buzzer?
    miketuason likes this.
  4. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
    It appears to be the seatbelt buzzer, per wiring diagram
  5. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Not sure, I’m going to look at my parts manual and see if it shows anything, thanks Kim!
  6. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Larry so the 308 has two buzzer, one for the key and one for the seat belt? I believe my key buzzer works but I don’t have anything for the seat belts. I have to search under the dashboard for a disconnected seat belt buzzer.
  7. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    406
    PA
    Alex
    I am interested in this thread. Both my door and seatbelt buzzing was disabled long ago, but the buzzer itself (mounted to the underside of the removable passenger footwell panel on an '85) is still connected. I was told many customers deactivated them on day one because they are so annoying. I want to be able to reactivate mine for regional concours events, but haven't yet found where it is disconnected!
  8. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
    As you are probably aware, The fuse is right side 7th from the left. I have been trying to trace the wiring back searching for the key buzzer. It doesn't seem to in the diagram. I will search tonight when I have more time. Do you have Paul Bennets wiring diagrams ?
  9. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Alex, just a few moths ago, I reconnected the wire or plug on the chime under the passenger forward footrest and now whenever the door is open and the ignition switch is on, the buzzer turns on and turns off when you close the door but I don’t hear anything for the seat belt.
  10. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Larry I remember getting the diagram from Paul back when he first offered it but have not made any copy of it yet, hopefully it’s still in my email. But anyway, I really would appreciate if there’s a way you can search it tonight, in the mean time like I said I will see if I can find any disconnected buzzer under the dash for the seat belt. Thanks Larry!
  11. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
    here's a start.. seatbelt relay under passenger floor.
    Red wire #1 runs to door jam switch
    red wire #2 runs to left fuse box, 2nd fuse
    yellow # 4 goes to driver seat belt switch
    black # 5 goes to key switch
    brown # 6 seatbelt warning light
    still searching for key buzzer wires and switch
  12. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
    #12 ragtop1, Apr 27, 2020
    I cannot find any key buzzer switch, relay or wiring information of any kind on the wiring diagram. :(
    My only conclusion is that the seat belt and key buzzer are one and the same
  13. miketuason
    Feb 24, 2006
    15,825
    Cerritos, CA.
    Larry, this is the key/door buzzer (right) I plugged back in and it works, so I’m just wondering now if there is a separate buzzer for the seat belt and if there is, where is it located on the 84 QV?
  14. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
  15. ragtop1
    ragtop1 F1 Veteran
    5,253
    Ontario
    Larry Warren
    Pero likes this.
  16. Pero
    Pero Formula Junior
    Apr 22, 2011
    825
    Sweden
    Peter R
    ragtop1 and miketuason like this.
