Typical IFR XC is how much longer than direct VFR? | FerrariChat
Discussion in 'Aviation Chat' started by rob lay, Jun 29, 2009.
  1. Shorter
  2. Same
  3. 10% longer
  4. 25% longer
  5. 50% longer
  6. I like Frosted Flakes
Multiple votes are allowed.
Results are only viewable after voting.
  1. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,991
    Southlake, TX
    Rob Lay
  2. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    Rob, maybe some are not sure what you mean - for example: Do you mean you have to fly further going to say DFW to Okla City IFR than the same trip VFR because of possible holding pattern, IFR airways, etc? If so, I would say not much difference, as most IFR is probably vectors nowadays, right? Anyway, what I used to do was to declare IFR to get up and out into improving conditions and then just cancel and finish with VFR. Planes I could afford did not go up into all-IFR terrirory anyway.
    Or, do you just mean that the typical Sunday VFR flight tends to be shorter by nature than the average IFR flight which is done for business and not just local sight seeing?
  3. rob lay
    Dec 1, 2000
    63,991
    Southlake, TX
    Rob Lay
    sorry, thought basic assumption same departure and arrival locations.
  4. ylshih
    ylshih Shogun Assassin
    Honorary Owner
    Mar 21, 2004
    20,442
    Northern CA
    Yin
    #4 ylshih, Jun 29, 2009
    It probably varies, but assuming that it's not IMC (in which case VFR direct is longer :)), then my guesstimate is that it probably takes 5-10 minutes extra for your IFR release, if pre-filed for a particular departure time then figure it's front-loaded (i.e. you have to be ready to depart that much earlier). Then the actual flight time is situational, for example on one route I flew a lot between Socal and Norcal, the planned flight time was 15-20 minutes longer northbound than VFR direct because standard departure through LA Class B took you to the east during the climbout, while the enroute leg was west/northwest. Most times, ATC was fully aware of the route extension and if they had no traffic and you were following their vectors promptly, they could weave you into a gap to get you westbound as quickly as they could to save that extra time. The standard southbound flight plan didn't have that problem and most every leg was close to VFR direct. On arrivals, your IAP's are probably 5-10 minutes lengthier than just arriving into the downwind traffic pattern, but on a clear VFR day, you would probably just cancel IFR with airport in sight and save that time unless you wanted the practice.
  5. rob lay
    Dec 1, 2000
    63,991
    Southlake, TX
    Rob Lay
    #5 rob lay, Jun 29, 2009
    That's a great point. Around DFW we're pretty much stuck with DP's and wild vectoring. I just bring this up because many I hear say fly IFR even in VFR, mainly for safety. So far my experience has been about 10% more NM and a few more minutes flight planning and getting clearance.
    Here are flights I did Friday and Saturday IFR 52F to KIWS to 52F. 210 NM direct / 255 NM typical IFR routing. That doesn't even count doing an instrument approach, VFR you would never make it, but IFR approach would add another 5-15 minutes.
  6. tazandjan
    39,182
    Rob- The answer is too situationally dependent. If you are on an IFR flight plan, you can fly through controlled airspace, which is sometimes not possible when VFR. You can also file an IFR radio fix to radio fix flight plan and, once airborne, request INS or GPS direct, more often approved than denied, except in terminal control areas.
    So the answer is shorter, the same, and longer, depending on the circumstances.
    Taz
    Terry Phillips
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    my experience as well
