Tyres replacement for Granturismo | FerrariChat
Discussion in 'Maserati' started by leealfred, Sep 28, 2010.
  1. leealfred
    leealfred Rookie
    Jan 23, 2006
    29
    Singapore
    Hi all,
    Just to check with fellow GT owners here whats the mileage done on your original Tyres before you need to replace them?
    I am checking on this because my GT need it's front Tyres replaced at 15,000KM and at 15k km the inner side front tyres are exposing metal wires. I am running on the original birdcage 20" with P-zero Tyres. Basically never tracked and only city driving.
    Hope to hear some advise from fellow owners here.
    Cheers,
    Leealfred
  2. lpm 505
    lpm 505 Karting
    Aug 26, 2008
    187
    Bellevue, WA
    William
    I replaced my front tires at 12,350 miles, mine is 20" Birdcage with Continental.
  3. windsock
    windsock Formula 3
    1,153
    If you have inner tire wear this severe it is due to a alignment concern (Toe Out) common on these cars. Have your aligment shop reverse the factory specification so the car has slight toe in in the front rather then the toe out as specified in the technical documentation and you will get much better tire wear and you will not notice a difference in handling except it will likley track better in city streets. Particularly badly rutted roads.
    Good luck.
  4. mgv1
    mgv1 Formula Junior
    Feb 6, 2006
    496
    San Francisco
    Mark V
    The fronts will last longer than the back but the Pirelli's only get about 4-6 thousand miles on the Gran Turismo due to their being as soft as cheese. I've got 6K on mine at the moment and looking for an alternative.
    The car is heavy too but I'm thinking of going up in size from 285 to 295 on the back and from 245 to 255 on the front. This gives you more sizes/brands to choose from and a larger surface contact patch which slightly lessens the load per sq/inch on the tires.
    When you get the replacements find a good alignment shop and they will optimize the setup, I notice most Gran Turismo's have a bit too much camber.
  5. 360C
    360C F1 World Champ
    I am on my second Granturismo and have never had front tyres wear like that.
    My current "S" has just under 30,000km's on it and the front tyres would be lucky to be 50% worn- I check EVERY time I wash the car.
    I replaced the rear tyres at 23,000 km's and they were still road legal as they were not worn down to the tread wear indicators. I have had P-Zero's as standard fitment on both cars and they were both used as daily drivers and were never tracked.
