U.S. Model Mirror Question... | FerrariChat
Discussion in '308/328' started by wazie7262, Sep 21, 2009.
  1. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    #1 wazie7262, Sep 21, 2009
    Is it possible to replace the God-awful U.S. - style flag mirrors with a more "euro variant"? I.e. something flows with the lines of the car but can also be easily removed, if need be, for originality sake?
    Thanks,
    Scott
  2. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    #2 speedy, Sep 21, 2009
  3. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
    The Baby Turbo's are the same style but WAY TOO SMALL. They belong on Ducati's.
  4. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    When you say they are way too small, are you speaking of their funcionality as mirrors, or aesthetically...or both? :)
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    I must have the Baby Turbos on 22127, they are fine and make a pair if you want RH/LH.
    Tha Californias are correct for the early cars....
  6. BigTex
    79,386
    Houston, Texas
    Bubba
    You can;t see much in the Californias unless they are mounted correctly for your viwing angle and they only move thru one "plane" of adjustment, the Turbos are better in that aspect as they have dual ball joint fittings for a wider range....
  7. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    I never use my mirrors anyway; always look over my shoulder. I'm looking for my 328 ;-)
  8. Papa G
    Papa G Formula 3
    Dec 29, 2003
    1,406
    Same here. I take a quick look in the mirror ( I only have one), but I'm always looking over my shoulder.
  9. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,338
    Encino, Ca
    Carl T
  10. Dr Tommy Cosgrove
    36,453
    Birmingham, AL
    Tommy
    They are way too small. I tried that once. Somehow I got lucky and found a pair of the euro versions on ebay out of Canada. BIG difference from the baby turbos which look more suited for a toy car.
    It is not THAT easy to swap them out. There is a metal block that your US mirrors screw into under the door skin. The euros have holes in different spots. That means that not only do you need to drill at least one new hole, you need to do it with some sort of drill bit that will drill threads for your new screw. What I did was simply drilled new holes all the way thru and used screws and nuts from Home Depot. This, of course, means that you need to remove the door panel and get your hand up in there to hold everything as you do it.
    After all that you will still have one screw hole that will just peek out from under the euro's base. I don't think there is any way around it either.
  11. Dino246gt
    Dino246gt Formula 3
    Mar 26, 2007
    1,038
    Winnipeg, Manitoba,
    Dennis Ezmerlian
    I'm still searching for a passenger side mirror to match the original big ugly flag mirror, why are they so difficult to find? The RHD cars had them, and the QVs had both sides. Any leads are greatly appreciated, thanks, Dino or p.m. me at [email protected] (82 GTBi)
  12. wazie7262
    wazie7262 Formula 3
    Feb 13, 2008
    2,357
    Temecula, CA
    Scott
    Gads. Thanks guys.
    Scott
  13. furnacerepair
    furnacerepair Formula Junior
    Feb 9, 2009
    744
    Wisconsin
    Martini
    Firsta rule of Italian driving - Whatsa behind you is nota important.
  14. flyngti
    flyngti Formula 3
    Jul 16, 2009
    1,246
    Snohomish, WA
    Eric L
    LOL. Reminds me of a what my cousin had on his passenger side convex mirror:
    "OBJECTS IN MIRROR ARE LOSING"
  15. BigTex
    79,386
    Houston, Texas
    Bubba
    It's called "drill and tap"..Dr. Tommy..LOL!
    Mirrors are a widely varying item early on, then later they WERE Factory installed, even electric!
    WHAT will they think of, next????
  16. BigTex
    79,386
    Houston, Texas
    Bubba
    Worst case you would remove them and repaint that area, then re install new base plates and gaskets....
    At some point the door skin itself had the threaded inserts and position was standardized...in the early years the Dealer field positoned them based upon driver's seating position.
