355 - Ugh, Valve Guides are Going... | FerrariChat
355 Ugh, Valve Guides are Going...
Discussion in '348/355' started by sgtpeper, Nov 18, 2021.
  1. sgtpeper
    sgtpeper Formula Junior
    May 4, 2004
    426
    Denver
    Jeff
    Hi All,
    I'm having my major done right now. My trusted mechanic did a leak down annnnnnnd a few cylinders are starting to go. Really bummed as I have records of the car being fine at the last major only 4 years ago.
    He is sending everything out to be rebuilt right now. It sounds like they will use different guides. He did say he believes my valves themselves are okay. If so they will clean and reuse them.
    Also turns out my clutch is pretty much toast - which I was expecting.
    Any thoughts on anything else to do while it is apart? This is a '97 GTS gated.
    Thanks!
  2. f355spider
    f355spider F1 World Champ
    18,044
    How many miles. My Feb 97 355 spider had its last major (before I sold it) at around 57k miles and compression/leak down was still fine.
  3. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    I have about 37k on mine. It's a late '96 build date.
  4. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    Dirty valve seats. Just built up carbon on them.
    leak down testing is not a good indicator of valve guides. Just the sealing ability of the valve to seat.
    If the heads are out, have the machine shop measure value guide clearance. Most likely you just need to do a standard valve job. Not valve guides…
    GTUnit and f355spider like this.
  5. f355spider
    18,044
    Good point. When I bought my car in 2004, it had around 27k miles and in the records from earlier in the year (previous owner), it had some 14% to 17% leak down on three cylinders, while all the others were single digits.
    Ferrari of Seattle suspected carbon build up on the valves and recommended their technician running GM "Top Cleaner" or something like that through the intake system, then run the car "spiritedly" for a weekend, then bring it back for another test. The second test showed the previously high leak down numbers now around 7 to 9% and they said in the notes it will probably continue to improve if the customer quit driving so sedately. :) I owned the car for ten years and went through two major services and never had another issue with compression or leak down numbers.
    Kokose7en, jjtjr, MAD828 and 2 others like this.
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Which cylinders were bad?
  7. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    There's a cottage industry of people on Rennlist who are certain that 993's don't really have valve guide problems. Sure, maybe you had some carbon on the valve seats. But you probably have worn guides. Very easy to check with the engine out. Don't get your hopes up that it just needs an Italian tune up.
  8. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Any smoke or excessive oil use?
  9. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    ^^^Exactly. The old adage if it aint broke... Blue smoke, and oil consumption would worry me before I would tear my engine down and replace valve guides. Although I suppose if this car is being used in a racing application where every ounce of HP is critical then why stop at guides?
  10. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    No smoke. He tried snapping the valves into place but was still getting over 60% on multiple cylinders. He's quite positive it is my valve guides. The heads are being sent to CA to someone who makes his own special guides. He's hopeful the valves themselves are fine though.
  11. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    60 percent is crazy. This is from guides being so worn the valve heads have beaten up the seats. You must have had significant oil consumption?
  12. Rifledriver
    37,087
    And what part makes sure those skinny little valve faces land on the seat in such a way it has a chance of sealing?
    The valve guide. Sorry but you are wrong. A leak down test is a good and widely accepted method of diagnosing valve guides....at least to those of us who understand how a piston engine works.
  13. Rifledriver
    37,087
    A dry sump engine does not always have a high oil consumption issue from guides. One of the advantages of a dry sump is the amount of vacuum it produces in the interior of the engine. That vacuum helps reduce the amount of oil that can flow past the guides. A 308 with bad guides will smoke like a choo choo train. A 348 or 355 will not.
  14. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    This is what I wanted clarification on. My car suffered no smoke at all and didn’t have excessive oil burn between annual services and yet the valve guides were shot.
  15. Rifledriver
    37,087
    So rough running and poor power output isn't a reason to fix it?
    If that is your standard why even have a Ferrari. Just get a clapped out Toyota.
    Julia likes this.
  16. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Good to see you back on the forum Brian. Please visit more often! Your knowledge is invaluable.
    Dr Tommy Cosgrove likes this.
  17. IvanRico
    IvanRico Karting
    197
    Westchester NY
    Ivan Rico
    #17 IvanRico, Nov 19, 2021
    Out of curiosity, what is excessive consumption? If the average 355 driver puts on 2k miles in a year and consumes a quart of oil is this excessive? Personally I won’t find out how much oil I use until next year since the car is new to me.
  18. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    Correct, I had no smoke or excessive oil usage.
  19. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,218
    CT
    John Kreskovsky
    Obvious question. Did the mechanics listen to see if he heard leaking from the exhaust or intake. Usually before you assume bad guides you listed to see if you can determine where the cylinder is leaking.
  20. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    Engine is already out of the car to perform the major.
  21. sgtpeper
    May 4, 2004
    426
    Denver
    Jeff
    I believe he said mine is leaking on the intake side.
  22. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    If the engines out anyway then its a no brainer, purely for resale if anything, essential to be able to prove that the one thing buyers of 355s panic about and that is if the guides have been done recently.
    Mike Morrissey likes this.
  23. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    Interesting. Most of my experience is working on air cooled 911's and they are dry sump but drink tons of oil when guides are worn.
  24. yelcab
    Nov 29, 2001
    13,547
    San Carlos, CA
    Mitchell Le
    Way different engine...
    Rifledriver likes this.
  25. fatbillybob
    Aug 10, 2002
    28,969
    socal
    Great thing is a well built 355 runs and sounds like a scaled cat! Your wallet is going to hurt but the smile on your face will be priceless. Maybe get some new sticky tires and have fun. These cars see few miles and often ride on old tires.
