UK 355 rough running ? Help please | FerrariChat
Discussion in '348/355' started by phib, Apr 12, 2020.
  1. phib
    phib Rookie
    Feb 14, 2014
    10
    Hi All, I am based in the UK and have a 5.2 355 which I have had for 17 years now with no issues ....
    Until yesterday...
    It had a major service in December and hasnt really been out since then.
    I took it out and all was fine until about a mile in then it lost power and the engine note changed, sounds like it went to runing on 4/5 cylinders but still drove ok and had no slow down lights on.
    Got it back, unplugged the Exhaust ECU's and they look ok, ran without them and it made no difference. Then turned off the battery switch and left it for 4 hours to hopefuly reset the ECU, the same thing happened when I restarted.
    Looked at the blue sensor on the back of the engine which had a bit of corrosion so claeaned that up put back together and again no better.
    It doesnt have a 16 pin OBD plug just the 3 pin ones so cant get a code reader there, there are connectors you can buy from amazon (16 to 3 pin) but not sure which ones work>
    In the UK all the garages are shut down so cant get any help there
    Can any one reccomend anything to try please
    Many thanks
    Phib
  2. Chad Thomas
    Chad Thomas Karting
    May 21, 2019
    85
    Sydney, Australia
    Chad Thomas
    Sounds like something simple. Have you checked that all of the ignition leads are connected properly? Have you ever had the injectors cleaned?
  3. phib
    phib Rookie
    Feb 14, 2014
    10
    Thanks, it does sound like something simple.
    It seems to have a stronger smell of fuel comming out of the right hand side.
    I need to tackle the leads later, they dont seem that easy to get to so will take my time.
    Not sure about injectors, I have never cleaned them. Not sure if garage has. Does the injector stuff you put in the fuel tank work or do they need to be taken out ?
    Many Thanks
    Phib
  4. Qavion
    Qavion F1 World Champ
    14,420
    Ian Riddell
    Google "Fiat 3-pin OBD2 adaptor". That should point you in the right direction.
    I put injector cleaner in my tank, but proactively. I haven't had any problems. Cleaner is going to help stop blockages. If you are getting too much fuel, it doesn't sound like a blocked injector.
    Not sure that would help with resetting the ECU. The 5.2 ECU has a non-volatile memory.
    It's odd that you're not getting any CEL/SDL lights, but there are some faults which don't produce them. If you can figure out which bank you're losing, then it will help with diagnosis.
  5. phib
    phib Rookie
    Feb 14, 2014
    10
    Pretty sure it is bank 1 i.e. cylinders 1,2,3 and 4
  6. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    262
    Woodside, CA
    Without having codes: If it smells like fuel, then I'd look into why you have unburned fuel.... meaning spark. Check the connectors on your ignition module and coils. If you have the means to do so, check the spark plugs.
    But if possible, get the codes. Should help diagnosis greatly.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    It never is anything simple when one back shuts down. Unless you have a code reader, this is shooting in the dark and relying on getting lucky.
    The thing to try is:
    1. Check to see if the TCU is plugged into the right connector (I am not sure if the Eu model has a third TCU that controls the bypass circuit)
    2. Swapping Thermal Control Unit left to right to see if it switches side
    3. Check the O2 sensors, their connectors, and whether the front O2 connection is swapped with the rear O2 connection
    4. Is your SDL light bulb turning on at start up?
    5. What is the cat temperature of the offending bank when it is running poorly? Compared to the other bank?
    Qavion likes this.
  8. Qavion
    14,420
    Ian Riddell
    If you're sure it's 1~4, then start swapping things.... easier things first, like coil packs, although, after a major it's more likely to be human error than a component failure.
    Make sure your cat sensor wiring isn't sitting on a hot exhaust.
    Make sure that your CEL and SD light bulbs haven't blown. Do they appear on startup?
    (EDIT: Sorry, crossposted with Mitch)
  9. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Did any dash lights come on
    SDL, cel, anything like that?
  10. cactussed
    cactussed Formula Junior
    Mar 12, 2008
    290
    Phil
    I'd be tempted to swap the coil pack on that side.
    Check the connections (you'll have to remove the cover) but they fail regularly.
    Luckily its a standard fiat / alfa part so not hard to locate or swap.
  11. phib
    phib Rookie
    Feb 14, 2014
    10
    So a little further along .. or not !!!
    The SDL and CEL do come on so they must be working.
    Tried to get to the spark plugs, all the little screws out only to find the cover must have been glued in place !!!
    Then the Fiat three pin / 16 pin adaptor turned up .... and guess what that doesnt seem to fit the three pin plugs I have coming out of my ECU's it just wont plug in ...
    Very frustrating !!
    Phib
  12. phib
    phib Rookie
    Feb 14, 2014
    10
    Well minor update !! Got the spart plug cover off !! Which seems like a major victory ... bloody car !! Need a beer now !!
    Thanks for all the advice so far
    Phib
  13. lanab
    lanab Formula Junior
    Feb 21, 2016
    516
    Stockholm, Sweden
    Could you post a video with how the engine is sounding?
    Still amazed some people use sealant for the spark plug cover, had a terrible time getting rid of it afterwards, not to mention the cover was stuck as glue so i feel pain with you.
  14. Qavion
    14,420
    Ian Riddell
    Bizarre.
    I noted you said "ECU's" (plural). The 5.2 only has one Motronics ECU behind the right hand seat under a leather cover. Are you trying to plug your new adaptor into your 4 pin thermocouple ECUs?
  15. cactussed
    Mar 12, 2008
    290
    Phil
    If its suddenly running a bit rough, then its likely to be spark or fuel related.
    Spark is the simplest to check and address.
    The coil packs can go without warning and produce rough running and loss of power, especially under load and when hot (less noticeable when cold or under light throttle). They're also easy and simple to swap (just note what wire goes where).
    https://www.ebay.co.uk/itm/Bosch-0-221-503-407-Ignition-Coil-for-Fiat/184200732457?fits=Car+Make%3AFerrari%7CModel%3AF355+Berlinetta&epid=25034186770&hash=item2ae3381f29:g:D2QAAOSwqMteGS8U
    GSF, EuroCarParts all do them.
    If that doesn't work, try checking wires and plugs (but be careful taking wires off plugs as the boots tend to break - Hills do a dedicated tool which indicates the likelihood of issues).
    If the plugs were changed at the major then unlikely to be them (though not impossible). Wires can degrade which again, are an easy (if slightly pricey) change...
  16. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    electrical connections at the injectors and around the engine, but that should be throwing a cel. I wouldn't do a lot of digging except swapping L&R parts until you get the code reader.
  17. Trevor Hammond
    Mar 28, 2019
    16
    Hudson valley
    Trevor
    Try a compression test.
  18. phib
    phib Rookie
    Feb 14, 2014
    10
    Thanks all, all is pointing to poor coil pack on 1-4, manifold is not getting that hot versus the other side.
    So I have ordered a new one that should (subject to lockdown) be with me on thursday ... lets hope its that simple !!
    If not its into compression tests etc etc
    Phib
  19. phib
    phib Rookie
    Feb 14, 2014
    10
    I will take a photo later, i have one three pin out of the ecu and another one out of the hood cover in the middle of the car
    Neither fit the adaptor !!
    Phib
    Qavion likes this.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    did you swap coil pack from bank 1 to bank 2.
    This would tell you for sure it’s the pack and not something else
  21. Qavion
    14,420
    Ian Riddell
    A photo might tell us if the plug looks non-standard. I assume you removed the protective cap prior to fitting :p. If you can identify the wire colours on the plug, I might be able to help you fit a suitable plug to the car. ECU fault codes can be a vital key to diagnostics.
  22. Trevor Hammond
    Mar 28, 2019
    16
    Hudson valley
    Trevor
    Compression test is the cheaper way.
    I am thinking you have a burnt valve.
    It’s the easiest thing to do as well.
  23. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,266
    CT
    John Kreskovsky
  24. 355OXO
    355OXO Karting
    Apr 16, 2006
    204
    Simon
    I have the same problem when I bought the adapter, I ordered another one from a different supplier for Fiat and it fitted fine. If you look at the prongs on the three pin adapter you will probably notice they are flatter and wider than they should be this was the problem I had with my three pin adapter.
    Qavion likes this.
  25. phib
    phib Rookie
    Feb 14, 2014
    10
