UK RHD M2.7 348 Running like a B***h at low revs | Page 3 | FerrariChat
Discussion in '348/355' started by dapper, May 6, 2010.
  1. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    No doubt,
    Thats what I thought, so without the engine running I should have got the speed sensor error from 'both' ECU's. It definitely wasn't presenting itself on the 1-4 bank ECU milk. But, if there is a prob I can't understand why I don't get a CEL from 1-4 bank ECU all this time whilst driving around with the rough running.
  2. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Thanks, I thought only 4114 (TDC) showed with engine off. I stand corrected.
  3. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    One of those two codes does as you indicate, maybe both. Now that you mention it, I've forgotten which one. Sorry.
  4. dapper
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Been under, both sensors look fine, wiring and connectors are undamaged (look like new actually). The pins are clean and shiny, no signs of corrosion. The gaps are at the top end of the tolerance or just nudging above, one at 0.9 and one at about 0.93. I took the two very thin shims off the 1-4 sensor, bringing it back into tolerance now at 0.8 or thereabouts.
    I checked their output once again with an oscilloscope (direct by backprobing the connectors this time). Both outputs are of the correct waveform, but one has lower amplitude than the workshop Fig. The 1-4 sensor has peak to peak of 25V (for the revs part of the signal), whereas the 5-8 sensor is only outputting peak to peak amplitude of 18V.
    Do any of you guys feel that voltage shortfall is significant, or do I continue looking for the fault elsewhere?
    May just buy a new sensor for the 5-8 position as the cars in the air and they are only a few pounds/dollars.
    Suns shining like billho over here in UK (for a change!!!!!) so I'm getting really cheesed off at not being able to drive the mello yello mother.
  5. dapper
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    Is 18 volts peak to peak on a Bosch Motronic 2.7 feeding crank rpm sensor significant compared to spec 25 volts?
  6. dapper
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    I pulled my plugs (again) and this time noticed that two of them were sat in a slight well of oil in the plug holes. The oil can only have come from between the camcover to head joint, even though when I last had the engine out to do the cambelts/tensioners etc I used new gaskets. I have a suspicion it was the new stainless dome head nuts I used for the camcovers, they aren't quite as deep as the Ferrari ones, so they don't pull the camcovers down sufficiently.
    Anyway, I made up something I can only describe as an oversized cotton bud tool, cleaned/soaked up the oil from the two affected plug wells and bingo, the car now runs beautifully.
    Now we just need to get yours right. I think you are on the right lines by checking the plugs.
  7. Ronnies348TS
    Ronnies348TS Rookie
    May 27, 2010
    35
    Chestermere Canada
    Ron
    Had the exact same issues as Dave ( Dapper ). It all started when my battery went dead. Rather than tirckle charge the battery I boosted it with the charger. From that day forward things went downhill. Te engine would surge every 10 seconds or so, then I started getting very strong fuel smell from the exhaust. Driving it home last night it was running so rough, I could hardly keep it going.
    So... this morning I pulled the airbox apart cleaned it out ( really bad!), reconnected one of the air intake hoses that was simply dangling almost, was not routed up through the fender properly, cleaned the MAFs, lubricated both sides and both ends of the throttle linkage and finally reset the ECUs via a battery negative disconnect for 3 minutes. Reconnected eveything started it up and bingo bango, runs like a dream!
