Ultimate fuel additive? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by Gary48, Nov 19, 2005.
  1. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Ernie, good luck to you, I also picked up the glass shot glass thing from Wal-Mart. I was looking for something in stainless from the kitchen department but this will work fine. Don't forget 100% acetone which I also purchased from Wal-Mart, they will only let you buy a gallon at a time, its either the meth lab guys or the DOT afraid of a fire bomb in a car.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Oooops.
    I goofed with my calculation. It was actually 395.5 miles out of the last tank not 400.2. A few years back I had my speedometer/odometer tested by the AAA club and the odometer was off 3 miles for every 100 miles, or .03 per mile. My odometer read 385 at that fill up, so recalculating for my goof, the mpg was 30.39 on that tank.
  3. DMOORE
    DMOORE Formula 3
    Aug 23, 2005
    1,720
    San Diego
    Darrell
    Well guys, as of last night I am running the acetone in my Navigator. I reset my mileage computer which was averaging 12.4 miles per gallon. I am running 3oz per ten gallons. The Navigator is supposed to run 91 octane. I usually run 87 unless I am towing. If I am running 87 and accelerate up a steep grade from a stop,which is near my home, I usually hear a bit of detonation. Obviously I don't do this all the time, but it does happen. Now last night after filling with 87 and acetone, I heard no detonation up the hill. I'm going to try it for a month and see the difference. If I'm towing I'll put the 91 in ,otherwise I'll continue to run the 87. Keep ya posted.
    Darrell.
  4. Mario Gonzalez
    Mario Gonzalez Formula 3
    Apr 13, 2004
    1,333
    Out of my mind
    maybe I should try this on my Sedan de Ville. god knows it needs all the snake oil it can take to lower it's gas guzzling thirst.
  5. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Mario, When you add acetone, use the same amount of Marvel Mystery Oil.
  6. Mario Gonzalez
    Apr 13, 2004
    1,333
    Out of my mind
    mystery oil? why?
  7. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Oh, don't worry, folks, I'll be putting acetone in the next tank or the one after that on my daily driver. I've got... 30,000 miles of baseline data? Or I may just use the same time last year. I can chop and dissect this any way you can imagine! All from the sceptical viewpoint...
    P.S.-Did anyone notice this guy kept saying you need a ScanGuage to get accurate data? The thing's just an OBDII monitor. There are dozens out there. But never so much as "You need a ScanGuage or similar OBDII monitor". Fishy...
  8. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,814
    The twilight zone
    Hmmm, we's saying you need to read the ECU to get an "accurate"milage?... it sounds like what's really happening is the acetone screws up one of the sensors or something which confuses the ECU....
  9. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    Has anyone tried an emission test with this stuff on board? I am curious whether it would help or hurt obtaining a passing score.
  10. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    I would not be putting Acetone which is a super solvent, think nail polish remover, in my fuel system.
  11. velocityengineer
    velocityengineer Formula Junior
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    This is nothing new gents.
    This is not a "discovery" Oil companies and motor manufactures have been around the block. They are no fools, nor are they trying to rob you of fuel mileage.
    This is no "ultimate fuel additive". - It does serve a function when mixed with fuel, it helps the fuel to vaporize with incoming air and creates a more stable flame front and more complete fuel burn. Tolulene serves the same purpose.
    It will also destroy your injection and fuel system. Not really worth the minor % in possible gain.
    If you want better fuel (which is the root of the mileage increase), get a 5 gal minidrum of 100+ octane race gas and add some to your tank on fillup. You will get all of the above without the added bonus of a destroyed fuel system.
    Eric
  12. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    How so?
  13. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    I call a great big B.S. on any damage whatsoever in the fuel system. Zero, none, nadda. Its all hoky poky based on heresay and inuendo's. Now if you dump a gallon of the stuff in your tank you might see and o-ring or some plastic part swell or get soft. What do you think gasoline is? It might surprise a lot of people that it is not a pure singular element but is comprised of over 500 hydrocarbons not to mention a myraid of additives put in by the refineries. Some over the counter gasoline additives contain acetone and do no harm, only good. In the amounts were talking about here, again and again, it is very minuscule, about .25 of 1%.
  14. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Ernie, the M.M.O. is used for upper cylinder rings, valve guides, valve seat cushion and lubrication and contains additives that will help the acetone clean up carbon in your ports, backs of the valves and combustion chambers.
  15. velocityengineer
    Nov 8, 2003
    492
    Globally
    Eric Dahl
    I recall a paper on this from the SAE, its been a long time since I have seen it. Ill try to find it. I would hate to throw out things and not be able to back it up with some data.
    If I recall the issue is not in the acetone "eating" any fuel system components, it is that it emulsifies with water. and there is some small % of water in your fuel. This can destroy the injectors etc by plugging them up over time.
    Anyway, a small % race fuel will accomplish the same effect without risk. But its your car, knock yourself out.
    Eric
  16. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Oh I am. That's why I'm trying it on my Integra. The car has over 222,000 miles on it. So if the engine goes I'm not gonna cry over it.
    You guys will be getting an update on the milage later today, as I have to fill up.
    Anyone wanna speculate on what the milage will be?
    Place your bets now. Will it be better, the same, or worse?
    Stay tuned.:)
  17. whturner
    whturner Formula Junior
    Nov 25, 2003
    315
    Western Pennsylvania
    Warren Turner
    The Magic Elixir - see also the J. C. Whitney catalog
    Color me skeptical - but I did use some in my 9N Ford tractor to clean out the fuel lines and Carb to get ready for winter. Hurt nothing - ran the same as the previous year.
    Cheers
    Warren
  18. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    After we get this acetone thing sorted out we have another little secret to talk about. Stay tuned
  19. whturner
    Nov 25, 2003
    315
    Warren Turner
    I am not sure acetone is much of a "secret" - it is only that the composition of the various fuel additives tried over the years is not on the top of everyones "knowledge base".
    I used it in my '50 Ford when I worked at Monsanto, where it was used by the gallon. I would add a small bottle now and then to my gas tank - figuring it would help keep the Carb clean. It didn't hurt anything, but I can't prove it cleaned anything either. There was no obvious change in performance. I suppose an insignificant fraction less gas was used since acetone diluted the gasoline, and was burned instead of the gas.
    As a note - I can't help but think that this thread should have been be saved until April!
    Cheers
    Warren
  20. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Okay kids, the results for the first tank are in.
    Before I filled up at the station, the milage reading on the trip odometer was 375.5 miles. Does everyone have their decoder rings? Set them to correct for the error on my speedo (.03 per mile) gives us a corrected milage of 386.765 miles out of the tank. Now the last fill up was at a Costco using 87 grade gas. This time I filled up at a Unical76 station again using 87. The amount of gasoline used came to 12.236 gallons. Using our decoder rings again :D, dividing the milage by the gallons gives us 31.608 mpg.
    So compairing this to the gas milage I have been keeping track of on my car for the last 4 years, I saw zero gain, and zero loss. It was the same I have been getting all along. This was driving normal around town, and 65mph on the freeway using the cruse control. I drove a little over 120 miles in town, and the rest on the freeway.
    By the results of the first tank this is not looking good for the claims stated on the site posted. But before we cry BS, we are going to use up the rest of the can and see what the next few tanks will yield. The website does say to give it at least 5 tanks, and I think I can get 8 out of that can. I don't think I'll see anything different. But my injectors may get cleaned out real good.
    So stay tuned next fill-up for another exciting episode of "acetone".
  21. Perfusion
    Perfusion F1 Rookie
    Oct 16, 2004
    4,151
    Marietta, GA
    Aaron
    I don't see anything to sort out. The way I see things currently, you're no more than a troll spreading misinformation on an internet messageboard. Perhaps you've targeted this community because you have a grudge against Ferrari owners, or perhaps you want to see how far you can string along these folks.
  22. Mario Gonzalez
    Apr 13, 2004
    1,333
    Out of my mind
    Ernie,
    I also started the experiment today. filled up with 12.97 gal of 87 (tank nearly dry). added 3oz of acetone per 10 gal of gas and a bottle of Chevron Techron fuel additive.
    my mileage before fill up was 271.7
    stay tuned...
  23. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Aaron,
    Was it really necessary to flame the guy? Gary may be misinformed, but give the guy a break. We have a couple of people here who are currently either confirming the claims or debunking them. I read the website Gary mentioned and though I'm as sceptical as they come, parts of it made sense and actually sounded plausable. Gary didn't run out and say "Hey, everyone, you HAVE to do this, it's the greatest thing since sliced bread." Seems to me he asked a question -- Is this for real?
    Rather than wasting your time beating up on Gary, why not wait and see what the results say. So far, from Ernie's report, it's done nothing one way or the other for him. Let's see what his continued testing and others have to say. In the meantime, lighten up, Bro.
    Regards,
    Steve
    p.s. Since the only Ferrari's you own don't require any gas, I don't think you're the one who should be showing any indignation on our behalf. If we need to, we can take care of ourselves.
  24. whturner
    Nov 25, 2003
    315
    Warren Turner
    1) From Wikipedia, the free encyclopedia.
    Acetone is often the primary (or only) component in nail polish remover. Acetone is also used as a superglue remover. Small quantities of acetone can be added to fuel to improve economy and engine performance though this is only anecdotal and refuted by most automotive engineers.
    2) Shell Chemicals
    Product overview
    Product - Acetone
    3) Dan's Data letters #151 A Must read!
    http://www.dansdata.com/danletters151.htm
    4) From the Autoweek Forum
    Home » Forum Home » SHEETMETAL STUFF » Tech Talk and Vehicle Problems
    Topic: Using Acetone to increase fuel mileage.
    effes
    Re: Using Acetone to increase fuel mileage.
    Posted: Sep 29, 2005 10:06 PM
    Reply
    Oh G**, not this one again...
    Every few years this "Acetone" thing crops up, with really poor results.
    One consequence that's been picked up in warranty tracking is fuel pump noise/filter failure.
    In the vast majority of units out there, there are plastic components inside fuel pump housings (the moving fuel is actually cooling the mech), and acetone "scores" and "softens" those parts. The unit seldom fails, but noise levels do get pretty high.
    The other issue is that many units use inside the tank mounted filters w/plastic housings.... need I say more?
    Every time gas $$ go up, this surfaces - last time was around 9/11... *sigh*
    "Nuff said"
    Cheers
    Warren
  25. Gary48
    Gary48 Guest
    Dec 30, 2003
    940
    Perfusion, So far all you have contributed to a very interesting topic is to denounce the starter of the thread. You have charged that it wreaks of something fishey and that the starter is nothing but a troll spreading misinformation and stringing people along and that the starter has a grudge against Ferrari owners. Probably the statement that shows the greatest degree of arrogance is that the starter has the gall to keep his profile private and that the starter is someone called Alan Lambo.
    I have checked all your posts and you have a very nice collection of model's, the problem is that the majority of those posts talk about just that. I think you are confused. I have nothing to do with any infomercial and am not selling anything other than discussing an Idea. I do not have a grudge against Ferrari owners as I am the owner of two (not models) and I keep my privacy well guarded with no explanation offered. I am not Alan Lambo (whoever that is) Have fun with your models and do try to contribute to meaningful threads, you just might learn something.
