UNDERCARRIAGE CLEANING | FerrariChat
Discussion in 'Detailing & Showroom' started by MARANELLONATION, Nov 26, 2017.
  1. MARANELLONATION
    MARANELLONATION Karting
    Nov 22, 2006
    133
    North Andover Ma. 01845
    Michael A. Ferrante
    Any tips as to the best way to wash the undercarriage of your car while on the ground ?
  2. energy88
    energy88 Three Time F1 World Champ
    32,169
    West of Fredericksburg, VA
    Possibly with a pressure washer with a right angle wand or 90 degree adaptor. But be careful of using too aggressive of a pressure nozzle to avoid damaging rubber parts.
  3. LBBP
    LBBP Formula Junior
    Assuming you haven't access to ramps, jack stands or a lift I guess a power washer would work. If you can make a curved spray arm that you can direct under the car this might be a good option. I don't like spraying the underside myself because it forces water into crevices and areas I cannot wipe dry or clean. If you can somehow get the car to where you can get underneath the undercarriage use a product called Boeshield T-9 on any metal parts and Adam's undercarriage spray on the rest. Boeshield lays on a protective coating that lasts for up to a year and prevents rust or corrosion and leaves a OEM matte finish.
    https://boeshield.com/automotive-motorcycle/
