Uneven Exhaust Flow 1985 308 GTS | FerrariChat
Discussion in '308/328' started by Salbones, Apr 29, 2019.
  1. Salbones
    Salbones Rookie
    Apr 14, 2019
    16
    Salvatore Celeste
    I have no doubt this issue has been covered but I am unable to find the answer I need. 1985 308 GTS: Is it normal that the driver's side exhaust to have a substantially weaker flow at idle than the passenger side? That is to say, the passenger side exhaust output is probably twice that of the other side. Other than that, no performance or idle issues. If this is indeed "normal", what is the reason for the disparity?
    Thanks,
    Sal
  2. Steve Magnusson
    26,786
    it's normal for a stock F muffler -- the internal design is asymmetric.
    Albert-LP likes this.
  3. Salbones
    Salbones Rookie
    Apr 14, 2019
    16
    Salvatore Celeste
    Thank you, I appreciate the quick response!
  4. Jdubbya
    Jdubbya The $10 Trillion Man
    43,179
    PNW
    But would it even out if you used the choke lever or flipped the emergency flasher switch a few times? ;)
    Sorry, couldn't resist. :D
  5. nerofer
    nerofer F1 World Champ
    Mar 26, 2011
    12,083
    FRANCE
    This is the "innards" of a stock "marmitte" from an "euro" 328, that is without catalysator: you can see that the tubes are assymetric; note that the design of the catalysed exhaust is not the same, even if the outcome is identical.
    Rgds
  6. Rifledriver
    37,093
    Turn the battery off and see what happens.
  7. millsj
    millsj Karting
    Oct 17, 2011
    214
    Charleston, SC
    Joe
    I sure am glad I ran across this thread. I have had the same observation with my exhaust and wondered if it is normal. One less thing to worry about. :)
  8. damntall
    damntall Karting
    Jun 15, 2018
    85
    San Jose, CA
    Bryan Wright
    I have an ANSA exhaust on my car, so I'm not sure whether this would apply for you... but I had this same problem.
    Turns out it was misfiring on 2 cylinders in the front bank. Got that sorted with new plugs, wires, and resistors and it's equal exhaust pressure all round now.
  9. Salbones
    Salbones Rookie
    Apr 14, 2019
    16
    Salvatore Celeste
    Thanks for taking the time to attach the photo. I get it now, Thanks again!
