Unexpected "jerking" in first gear | FerrariChat
Discussion in '360/430' started by drcripp, Feb 4, 2017.
  1. drcripp
    drcripp Karting
    Nov 1, 2016
    123
    Pittsburgh
    David Crippen
    I'm noticing a strange phenomenon. Sometimes, when turning usually left to go up a bit of road incline, the car starts rhythmically "jerking" in first gear. Very---jerk----jerk and gets worse if I give it more gas or even less gas. Settles down after I let off the gas completely. Very irritating and possibly dangerous. Has anyone else noticed this in a 360 with F1?
  2. mkzhang
    mkzhang Formula Junior
    544
    Philadelphia
    You can replicate this with a manual too. It happens when you clutch out and don't give it enough gas so the engine is just at the point where it's about to stall but it doesn't and it bucks your car. It gets worse when you give it some gas so you have to clutch in again to stop it.
    Get your PIS settings checked, and see if the clutch is grabbing too soon without enough slip
  3. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,513
    Honolulu
    Kevin
    Could it be the ASR doing it's job? Try switching it off on the same patch of road and see. Just dont get in over your head if the road is unsafe!
  4. drcripp
    drcripp Karting
    Nov 1, 2016
    123
    Pittsburgh
    David Crippen
    Thanks for info, I'm not 100% sure what the "ASR" does, how it works and when to use it/shut it off?
  5. Falcon Wing
    Falcon Wing Formula 3
    Aug 4, 2010
    1,294
    Colorado Springs
    ....upshift.
  6. RedNeck
    RedNeck F1 World Champ
    12,322
    The CSA
    Me
    That happened to me the first time I floored it in first...luckily I got ahold of myself and put it away before the cop pulled me over. I just really, really enjoyed the power.
  7. Skidkid
    Skidkid F1 Veteran
    9,531
    Campbell, CA
    John Zornes
    This is most likely cause. If you give it a lot of gas in a turn you get wheel spin. With ASR on the system will back off the gas and you can get an osculation.
    With ASR off you will spin the wheels and the car will step out.
  8. KJB355
    KJB355 Karting
    Apr 4, 2006
    154
    Chicago
    Kenneth Brom
    Are you by chance at near full lock, with old tires and cold temps (less that 45 degrees F)?
  9. Kevin Rev'n
    Nov 29, 2009
    24,513
    Honolulu
    Kevin
    My ASR can be overbearing if I am on a slope and want to gas it a little too. I am hopeful that is what it is for the OP.
  10. Turbotuner20v
    Turbotuner20v Formula Junior
    Mar 18, 2014
    362
    What rpm?
    Are you downshifting from a roll down to 1st gear and letting off the gas and reapplying?
    This is normal under that type of driving. Take the turn in 2nd and avoid downshifting to 1st gear while moving and applying/lifting off throttle
  11. HIO Silver
    HIO Silver Formula Junior
    Mar 12, 2016
    497
    Northern California
    Alonso C.
    Concur.
    F1s are highly reliant on throttle position.... Fussy in fact. I have induced a CEL a few times by "confusing" the ECU with my footwork and paddle shifter actuation.
  12. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    ASR = Anti Slip Regulation.
    When I had my 360, I remember it getting in the way a lot. I would routinely switch it off... in my F430 and now 16M, the nannies are much better behaved so I tend to leave them on.
  13. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,754
    Boston, MA
    John E. Kenney
    ASR yes but also simple friction dynamics on the clutch (for whatever reason). It's like when you slide your thumb or finger across a smooth surface like a counter top or glass. At a certain point, you will either meet or exceed the friction level of "grip" on the surface (here it is the clutch disc and flywheel). When you are close to that point with a consistent application of force, the fingertip or clutch disc will hop and skip in a cycle with a low frequency vibration or buzzing effect. Like "Squeaky Clean" but not pleasant. ;)
  14. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,587
    on a 2002 or earlier
    gas it
