Unheated garage solution? | FerrariChat
Discussion in 'Technical Q&A' started by Huskymaniac, Nov 25, 2020.
  1. Huskymaniac
    Huskymaniac Formula Junior
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    I am in upstate NY and my garage is not heated. I was thinking of putting a couple of these under the car for the winter:
    https://heattrak.com/products/heated-snow-melting-entrance-mat-large-40x60
    Are there any potential issues with this idea? I can't think of any.
    Also should the car be up on jack stands or should I just keep the wheels on the floor? I put high performance all season tires on the car so they aren't super soft.
  2. Alcav5
    Alcav5 F1 Rookie
    4,088
    Scarsdale, NY
    Al
    If you can get electric in your garage , what about a heat pump.
    I installed one last year. Very satisfied so far , no significant change in electric bill I had left it on 62deg all winter last year. Not that expensive and controllable remotely , also does ac but no need for that.
  3. George Vosburgh
    George Vosburgh F1 Rookie
    Any chance you have gas going to the garage? A small wall unit is what I did and it works incredibly well. I feel like a fool for not doing it years ago.
  4. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    I thought about that but it would be tough to install right now. I was going to look for a window mount unit.
  5. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    I don't. I was thinking of propane though. But I doubt my wife would feel comfortable with that.
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Whats the heat mat going to do? Is the garage insulated? Honestly I see no point in that matt.
    Put some rigid foam under the tires, full gas with stabilizer, cleaned, oil changed, car cover, battery tender, dont start it... hope for earlyspring.
  7. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
  8. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    My problem is that there is zero chance my wife will let me put a 250 gallon tank of propane near our house. Our garage is insulated aside from the door, which I am taking care of over this long break.
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,083
    Central NJ
    Dominick
  10. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Marriage...been there doen that, but whats the objection? LP is just as safe as any other energy source, half the US runs on it.
    If you don't mind the $ look into electric radiant heat. Or a mini split that can do both heat and cool for the summer.
  11. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #11 eulk328, Nov 27, 2020
    A split air conditioner that uses the compressor to provide heat in cool/cold weather will shut down with near freezing outdoor temps and below. The freeze protection safety circuitry will keep it from running.
  12. Doctor Mark
    Doctor Mark Formula Junior
    Dec 15, 2005
    921
    Georgia
    Mark Gronsbell
    Cheap and viable way is to use an electric garage heater. Runs on 220V and has an adjustable thermostat. Works fairly well and reasonable cost solution.
  13. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    yes the combo units will shut down and or lose efficiency at colder temps. I've got a couple hyper heat units, I think they are Mitsubishi. I believe they operated down to -6 ambient but may have to review that info.
  14. Huskymaniac
    Jul 9, 2020
    281
    Finger Lakes, NY
    Tony
    That's not a bad option. I would need to bring 240V from the basement to the garage. But that should easily generate enough heat.
  15. Doctor Mark
    Dec 15, 2005
    921
    Georgia
    Mark Gronsbell
    That is exactly what I did. I did add a circuit breaker box for the line running out to the garage The job is quite easy. The cost is quite low and the results keep the garage at a reasonable temperature during the winter season.
  16. tomberlin
    tomberlin Formula Junior
    854
    Bethesda
    tom berlin
    I have one of these in the garage, but twice the output, and one in an unheated section of the basement. They both work great. I would recommend a 220v line thermostat and not count on the one on the unit to be at all consistent.
  17. Teenferrarifan
    Teenferrarifan F1 Rookie
    Feb 21, 2003
    3,112
    Media, PA
    Erik
    We recently built a 700 sq ft detached garage. Getting gas to it wasn’t very doable and we were putting in a 100amp electrical service anyway (for lifts, future EV’s, etc). So we installed two of these electric heaters with remote wall thermostats mounted in the coldest area of the garage in between the doors. I forget the spec but they needed a 220 line and I believe are 3-5k watts each.
    We keep it at 50 during the winter and I crank it up if I’m messing around in the garage. Heats up quick and due to the good insulation we used cost very little per month to operate ($50-75 month).
    In the picture the heater is the rectangular box on the wall in the upper right.
    Erik
    EastMemphis and waymar like this.
  18. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    Noticed the high reach, wall mounted garage door opener. Any details on that one?
  19. Scudmsl
    Scudmsl Formula Junior
    Aug 12, 2014
    856
    Move South! [emoji2]
    EastMemphis likes this.
  20. Teenferrarifan
    Feb 21, 2003
    3,112
    Media, PA
    Erik
    #20 Teenferrarifan, Dec 19, 2020
    It’s a lift master 8500, we also had the rails custom made so that they follow the front wall and ceiling as close as possible. The finished product has the door literally a half an inch from the Sheetrock when open, and it’s a very clean appearance.
    Sorry for going a bit off topic.
    Erik
    unreelviper and jjason981 like this.
  21. absostone
    absostone F1 World Champ
    10,167
    I bought a small unit 2 yrs ago for $130. It’s really small and keeps a even temp. It’s really tiny. It’s around 12 x12 cube if that
