Unknown leak - need help | FerrariChat
Discussion in 'FF/Lusso' started by Duff Ace, Nov 18, 2022.
  1. Duff Ace
    Duff Ace Karting
    Oct 19, 2020
    110
    Tampa FL
    Adam Taylor
    Found this leak underneath my car. Not the first time.
    It was parked for a few days.
    wasn’t oily, more chalky after drying. I have no idea what it is.
    2017 Lusso V12. 10k miles on the clock
    thoughts?
  2. SVCalifornia
    SVCalifornia F1 Rookie
    2,571
    Silicon Valley
    Keith
    Exhaust ash. Off the exhaust pipes. Saw it on my Cali years ago. Not an issue. Does it line up with your exhaust pipes?
    SV
    Caeruleus11 likes this.
  3. Duff Ace
    Duff Ace Karting
    Oct 19, 2020
    110
    Tampa FL
    Adam Taylor
    That makes sense. Yes it aligns up with my exhaust perfectly
    I just had a FI system put on too.
    will this eventually go away or is there something I need to do to fix it?
  4. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,581
    Grant
    It's normal, made worse if the moisture in the air content is high.
  5. SeattleStew
    SeattleStew Formula 3
    1,019
    In the rain
    Stew
    If assembled with exhaust glue it usually isn’t an issue until the glue eventually becomes porous. I’ve got the same thing with my 812 after doing an Xpipe
  6. Duff Ace
    Duff Ace Karting
    Oct 19, 2020
    110
    Tampa FL
    Adam Taylor
    So I’ve had the exhaust now for a little over a month and I’m still getting exhaust ash on a daily basis. Does it eventually go away or do I need to have the exhaust looked at?
  7. SeattleStew
    1,019
    In the rain
    Stew
    It shouldn’t go away until the leak is sealed
  8. Solid State
    Solid State F1 World Champ
    10,584
    Maximus Decimus Meridius
    Completely normal due to moisture in the exhaust. If it just sat in the low spot of the system it would accelerate corrosion.
