Unknown Plug in engine bay | FerrariChat
Discussion in 'Technical Q&A' started by Kipper, Jul 26, 2010.
  1. Kipper
    Kipper Karting
    May 1, 2010
    103
    Australia
    Kipper
    #1 Kipper, Jul 26, 2010
    Hello members,
    This is a post that I made on the 360 section but have not received many responses, I thought I would try here wher hopefully some one can anwser my question
    On my 2005 360 spider there is a grey 2 pin square plug in the engine bay attached to the wiring lume under the RH throttle body and i cannot see where it should plug in. can any member help with advise as to what it is for please.
    Looking at the engine towards the front have placed it onto the chassis member for a better shot
    See attached picture, hopefully picture attaches, not quite sure how to do this?
    Under the left hand throttle body is the vacuum valves with two plugs in it a Brown and a white one of the same kind. The plug that i have is coming out of the lume under the RH throttle body
    Any direction will be appreciated
    Kipper
  2. mrpcar
    mrpcar Formula 3
    May 27, 2007
    1,114
    Chino hills, CA
    Robin
    #2 mrpcar, Jul 26, 2010
  3. Kipper
    Kipper Karting
    May 1, 2010
    103
    Australia
    Kipper
    Hi MRPCAR,
    I really appreciate your reply and the effort you have gone to to show me the plug, On my car it appears that there is no solenoid on the right side. On the left side i have a double solenoid with two plugs on the right side none.
    Maybe this is a spare plug for some reason, My car is a UK delivered car if this makes any difference.
    Will it help if I take some more detailed photos of the area?
    Thanks again
    Regards
    Kipper
