Unlock-Lock-Unlock Required to Release Charger on 296 & SF90 – Is This Normal? | FerrariChat
Discussion in '296' started by q8ferrari, Oct 14, 2024.
  1. q8ferrari
    q8ferrari Rookie
    Jun 25, 2006
    29
    Kuwait
    Hi everyone,
    I’ve noticed a bit of an odd process with my Ferrari 296 (and I’ve experienced the same on the SF90) when it comes to removing the charger. To get the charger to release, I have to first unlock the car, then lock it, and finally unlock it again before I can safely detach the charger.
    Is this normal behavior, or could there be an issue with the charging lock mechanism? It seems a bit cumbersome, so I wanted to see if anyone else has had the same experience or if there’s a way to simplify the process.
    Thanks for any insights!
  2. PieGre
    PieGre Karting
    Jan 9, 2019
    172
    Luxembourg
    PG
    I have to unlock it twice.
  3. ntatfas
    ntatfas Formula Junior
    Apr 27, 2011
    288
    I unlock the car, switch the charger off at the mains and then detach it from the car. I would say there is a few seconds delay between switching the charger off to hearing the electronic release from the car attachment point.
    DragonRR likes this.
  4. JPC296
    JPC296 Rookie
    Jul 27, 2023
    31
    Same for me
  5. JSwan724
    JSwan724 Karting
    Jun 1, 2023
    65
    MY SF90
    1. Car is locked
    2. Unplug the cable from the car
    3. Unplug the cable from the wall.
    Do you have auto lock and unlock on the car enabled?
    BigJay2050 likes this.
  6. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    I have to have access to the cabin to unlock/open the charging port, but I can plug/unplug the charger itself whether the car is locked or unlocked from that point forward. What MY is your car?
  7. Potentialshock
    Potentialshock Karting
    Jan 7, 2024
    56
    J
    The trick I use is to unlock the car, then there’s a small delay of cable being unlatched sound, followed by a tiny window of a second or two to pull out the cable.
  8. MikeS
    MikeS Karting
    Nov 21, 2003
    164
    Connecticut
    Mike S
    MY24, same for me. Just pull the plug out of the car.
  9. ZubayrC
    ZubayrC Karting
    Apr 1, 2024
    82
    Middle East
    Was told by the dealer when I had the car delivered to press unlock, wait almost a second or more then press unlock again (like opening the trunk but slower)... Worked for me every time
  10. Junaid13
    Junaid13 Karting
    209
    London, UK
    Junaid Peracha
    The manual has information on the procedure
