Unobtanium /308 switch stalk blocks | FerrariChat
Discussion in '308/328' started by kerrari, Dec 5, 2019.
  1. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,051
    Coolum Beach AUSTRALIA
    Karen H.
    I know in the past Verrell was refurbishing these - any body know what the current situation is? Seems like a perfect thing to 3D print , anybody heard of this being done any where?
    Matto likes this.
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    As far as I'm aware, Verrell still is. Have you tried emailing him?
  3. Cirorsi
    Cirorsi Formula Junior
    790
    Louisiana / Lac du Saint Sacrement, NY
    Steven
    Verell still does these for sure. He rebuilt mine and I appreciated the one year warranty!
  4. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    I can help with the modelling/3-d printing part if someone has one I can measure.
    sjd
  5. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,286
    Black Forest Germany
    Martin N.
    #5 Martin308GTB, Dec 9, 2019
    Would be a fair 3D-printing challenge, if one has watched how Verell refurbishes these. You have to mould metal parts into the plastic part. Anyone able to print around a metal stalk and achieving a strong plastic/metal bond? It's by far not just a R&R job.
    BTW I am worried about strength and durability when this is 3D-printed.
    Best from Germany
    Martin
  6. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I'm awaiting the day a thread queries the possibility of 3D printing reproduction rims.
    Martin308GTB likes this.
  7. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    or wishbones :)
    Best
    Martin
    thorn likes this.
  8. kerrari
    Oct 22, 2004
    24,051
    Karen H.
    Thanks for the update - I did google Unobtanium but the page was dated 2017 and for some reason I thought Verrell was no longer around.
    BTW, it’s always seemed to me the weak part of the original design was the the ‘casting in’ of the stalks... I was wondering about stronger blocks with a threaded hole and threading the end of the stalk to suit...
  9. JuLiTrO
    JuLiTrO Formula Junior
    Nov 2, 2017
    393
    Julio Saiz
    Hi,
    I bought stuff from Verell this year. Try this email adress [email protected]
    Best
    Julio
  10. JuLiTrO
    Nov 2, 2017
    393
    Julio Saiz
  11. steved033
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    That day is close.
    HRE did these:
  12. steved033
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    Do you have a picture of one? they can do metal inserts in 3-d printing. They're inserted after the fact. Or are you saying the end of the signal stalk is co-molded? (I'm a 348 owner, but I'm an engineer with an interest in product development and additive manufacturing)
    for those interested, here's the vid:
    sjd
  13. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    Hi workmate,
    sorry, no picture of the stalk/switch innards. It's in my car, but shows first signs of cracking. So the refurbishment will probably be due in the nearer future.
    I'm a mechanical engineer too and after decades of heavy injection moulding machinery my interest in additive manufacturing is growing.
    Yes, I meant the metal stalk and plastic switch part are co-molded.
    I am familiar with those threaded inserts, though I mostly -if there's no space restriction- I print simple cavities for hex nuts. I like this better because of the larger plane surface which takes the surface pressure. And installation works without application of heat. But like said, I grew up in the heavy machinery world :)
    This is a simple part, but the only picture I have, which shows my way of adding metal threads:
    Best from Germany
    Martin
    steved033 likes this.
  14. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    Hi Steve,
    I just cringed :)
    While that's a great example to show what 3D printing can do, I still worry about long term strength of this 3D printing method of 'electron beam melting magnesium powder'. I cringed once more, while I wrote that sentence :) Or in other words; I believe I am too old to dare trying those out at high speed.
    https://www.cnet.com/roadshow/news/hre-3d-printed-titanium-wheels-concepts/#
    Best
    Martin
  15. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #15 Verell, Dec 10, 2019
    Still kicking, just busy between Unobtainium & my family.
    From the reference to 2017 you probably found my Facebook page (am way behind on updates - sign). If you found my web page, you would find that the catalog cover has a very current date.
    Yes: Image Unavailable, Please Login
    Yes, definitely co-molded:
    [QUOTE="kerrari"BTW, it’s always seemed to me the weak part of the original design was the the ‘casting in’ of the stalks... I was wondering about stronger blocks with a threaded hole and threading the end of the stalk to suit...[/QUOTE]
    The original design actually has much stronger retention than threading: The wiper & turn stalk ends are heavily swaged with textured ridges on them.. They can't just be inserted into a pre-molded knob or pivot end.
    Threading doesn't provide stronger retention than the swaging & the stalk could be unscrewed & be miss-oriented (I tried it early on). However, it's on the right track, After trying threading I came up with heavily knurled ends for my reproduction stalks: Image Unavailable, Please Login
    BTW,Most of the stalk failures are because the ageing plastic is drying out & trying to shrink onto the incompressable metal shaft.
    The other cause of failure is someone yanking too hard on the stalk. The original plastic was actually pretty tough stuff. I've actually seen a couple of stalks where the metal shaft had bent before breaking out of the plastic.!!
    [QUOTE="kerrari,]Seems like a perfect thing to 3D print , anybody heard of this being done any where?[/QUOTE]
    3D printing can't be used because of the heavily swaged ends.
    BTW, I'm very familiar with 3D printing, I have a friend who designed SLA printers starting in the early '90s. So I've watched the technology evolve.. In fact, I just bought an EPAX X1-DJ resin 3D printer & am setting it up this week.
    I don't expect to use X1 for production ports as it takes way too long to make even a small part ( 4-8 hours!!!). However, it will be invaluable in making mold patterns of parts where I can't find one good enough to restore.. Also I can print mold negatives to use for replacing molds that fail in use.
    steved033 and miketuason like this.
  16. BigTex
    79,406
    Houston, Texas
    Bubba
    Verell checks in!!!
    :D :D :D
  17. steved033
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    If you look up Markforged or desktop Metal, they're using MIM powder, then sintering in an oven. They've got tool steel as an available material, which IMO will revolutionize injection molding.
    While not good for wheels, I think it will make smaller part manufacturing a reality.
    My fear is that as this becomes available to the masses, non-engineered product will make its way into the market.
    sjd
  18. steved033
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    Fantastic, so why not change a tolerance and just bond the end in place.
    sjd
  19. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    No doubt, that it's meanwhile possible to make high tensile strength parts with sintering techniques.
    But there are other properties I need or expect from metal parts, which are still problematic with sintered parts. Like the elastic coefficient, or especially impact strength. I know what happens, when I drop one of my sintered hard metal cutting tools for my lathe or mill onto my floor with tiles.
    Best from Germany
    Martin
  20. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Not sure what you mean by bonding..
    Remember that 90% of my customers want to retain as much OEM material as possible so most of my repairs are casting new pivot ends onto existing stalks. Thus my molds are designed for use to restore the OEM parts.. Knurled stalk ends are compatible with my existing molds. Most years I only sell 2-3 full reproduction stalks, so it's economically undesirable to have unique molds for them.
  21. steved033
    Apr 12, 2017
    10,335
    Atlanta, GA
    Steve D.
    I see. I envisioned a 3-d printed part with the stalk epoxied in place. Some of the newest MJF nylons might work well for that. they might even have enough stretch to press a stalk in.
    sjd
  22. Martin308GTB
    Jan 22, 2003
    4,286
    Martin N.
    I have built a prototype for a consumer product this summer with most innards made from MJF PA (Multijet Fusion Nylon). The local 3D-print supplier with his 100k€-HP-printer convinced me.
    It was seriously frustrating regarding strength and durability. I had to remake the most stressed parts with simple FDM and from ABS. Luckily those survived the product presentation while the MJF parts didn't survive the tests in my workshop.
    Best from Germany
    Martin
    JuLiTrO and steved033 like this.
  23. kerrari
    Oct 22, 2004
    24,051
    Karen H.
    Threading doesn't provide stronger retention than the swaging & the stalk could be unscrewed & be miss-oriented (I tried it early on). However, it's on the right track, After trying threading I came up with heavily knurled ends for my reproduction stalks: View attachment 2864696
    I don't expect to use X1 for production ports as it takes way too long to make even a small part ( 4-8 hours!!!). However, it will be invaluable in making mold patterns of parts where I can't find one good enough to restore.. Also I can print mold negatives to use for replacing molds that fail in use.[/QUOTE]
    Thanks for that Verrell and glad you ARE still around! I’ll be in touch...
