Unofficial 308 tool kit specifications | Page 19 | FerrariChat
Discussion in '308/328' started by piezo, Nov 21, 2015.
  1. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    I concur with Markus except that the carb wrench looks like a fiat one to me. The Ferrari one is a little bit different as the tube middle portion where the little rod goes thru should be somewhat depressed or curved inward on those I have seen so far.
  2. FrannyB
    FrannyB Formula Junior
    May 20, 2014
    293
    Arvada, CO
    Hi there, I noticed your photos look identical to my car's toolkit - even the blue handled pliers. I am missing my flathead smaller screw driver. I was wondering if I could get you to measure yours? I am also missing the window crank. Do you have that? Is there dimensions for that as well? I have to do an Ebay search. My number is slightly lower than yours, but it's still an 85 QV Euro. Thanks. Franny (53641- Jan/85). I would love the help.
  3. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    I'll leave the measurements to others. The window crank should be the T type as seen from quite a number of kits reported. You will have a hard time finding an individual one for sale. Last one on eBay was this and that's probably the first one popped up in 2-3 years prior I think. Perhaps those guys selling tools here may have one. Good luck.
    http://www.ebay.com/itm/Ferrari-308-Emergency-Electric-Window-Crank-Tool-/172158119918
  4. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    #454 robo330, May 6, 2016
  5. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Plus, is there anything else missing or incorrect? Let me know. Thanks guy's!
  6. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Looks like it's a Utema N1200 14/14 combination which is correct combination with the rest of the wrenches. So as you said you are missing the large flat and the correct pliers should be the blue one. Good luck finding them.
  7. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Thanks Steven! I found the missing Pliers and the Large Flat Blade Screwdriver!!! Had been hiding under the carpet in the rear quarter panel. BTW, the Pliers have a Blue handle, no markings and the metal is just raw metal color, not Black or Chrome Plated. The Large Flat Blade Screwdriver is longer than the 2 small ones but shorter than the Long Phillips Screwdriver. I will post pictures after the weekend. Thanks for clarifying all the Tools. In the Jack Bag, I have a Black finished Jack, a short extension for the Ratchet, the Ratchet, a L shaped wheel nut tool and a Green topped, round container for the fuses, the bulbs and a spark plug. I will swap out the ceramic fuses for the glass type because I have changed my Fuse Blocks from the original Ferrari Fuse Blocks to the "Birdman" type. This is not meant to be a plug for Birdman, but I must say that they have made a big difference along with the Window Accelerators! Boy! The windows go up and down very quickly and they are smooth.
  8. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Boy, don't you love that? Now your tool kit is complete! The jack kit seems to be complete and correct as well judging from your description except that you need 2 Champion N6GY spark plugs. Don't forget the belts, and you also need the emergency triangle if it's a euro 308.
  9. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    I have Champion Plugs in the little cardboard boxes with cellophane but unfortunately they are not N6GY's which are very hard to find. I do have 2 spare belts and it's a US model so I guess I won't need the emergency triangle. Thanks for your help!
  10. offtheworkigo
    offtheworkigo Karting
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    I also have a 85qv euro #53415. Built in Sept 84. I believe I have the tool kit, emergency triangle, full jack kit and the emergency light but missing the t handle for the windows. I will take pictures of them tonight.
  11. offtheworkigo
    Feb 23, 2016
    237
    Rockwall
    Dave Hoffer
    #461 offtheworkigo, May 18, 2016
  12. italianjoe
    italianjoe Formula Junior
    Jun 30, 2010
    295
    dearborn heights mi
    joe
    I have noticed that the kits with the blue pliers are missing one thing or another. Wonder if ferrari had a shortage of tools them years and was putting in what ever tools they had at that time?
  13. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Yeah the small flat screwdriver and the T type window crank are missing. The Allen wrench is not shown in the manuals but different types of them were noted from different kits. Could be anything, so I've never put them in the list cuz of the uncertainty. Not sure which type of wrench you have, all those reported kits with blue handle pliers seem to be having the Ferrari wrench with sizes in a circle depression plus a Utema N 1200 14/14mm combination wrench. See post #438 for a brief visual image of them.
    You have a great looking jack kit, though I'm not sure about the emergency triangle. Usually it's the Costaplastik one with white backing for 308s.
  14. FrannyB
    May 20, 2014
    293
    Arvada, CO
    Wow, this has been very helpful. I agree with ItalianJoe. It almost seems like the Euro QV versions only had three screwdrivers and no window crank. I know of another car manufacturer who would take what was on the shelf as well. Good call. :)
  15. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    It could be and we never know :)
    I believe the window crank was not originally placed inside the tool roll but in the door pocket. The small flat screwdriver might be the most useful for other purposes and could have been left outside the tool roll. This might explain why the screwdrivers and window crank are the usual ones missing.
    Just my theory though :D
  16. 455Fosbery
    455Fosbery Karting
    Oct 3, 2013
    212
    There is an '84 Euro QV listed on eBay that has some photos of the tool kit:
    Ferrari: 308 GTS Quattrovalvole Targa | eBay
    Note the blue handles on the pliers. Seems to be the norm for the '84 year models (what mine has).
  17. pj911
    pj911 Karting
    Jun 10, 2005
    78
    Vermont
    PJ
    I have a very late build 85 Euro QV with 4 screwdrivers and the "T" style window crank.
  18. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    Very good example with all accessories and manuals there to support the originality.
  19. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    If you are crazy about tool kits and jack kits like me and want to have the original Champion N6GY spark plugs in your jack kit, I've got a few extra here. PM me if interested. Only 4 available to supply 2 jack kits for QVs.
  20. 455Fosbery
    455Fosbery Karting
    Oct 3, 2013
    212
    Looks like you have the blue handled pliers (which I believe is totally correct for that specific year model) plus two other things that are definitely 'Euro':
    - The warning triangle (which you must have in your car by law in Germany)
    - Replacement main headlight bulb for a non-sealed beam unit
    Given the condition of this tool set, I would coat them in RIG and put them in a vault and assemble what bits you need from readily available/replaceable sources, stick them in a bag, and put them in the boot!
    Best,
    John.
  21. FrannyB
    May 20, 2014
    293
    Arvada, CO
    Hi All,
    This may have been covered, and, if so I apologize...
    Just where does this tool kit and jack go in the car? I saw a photo somewhere with a couple straps on the rear wall, but I don't see anything like this on my car ('85 Euro - German car). The spare bulbs go in the Jack bag, but how about the trouble light? Where does that go? How about the emergency triangle? If you were to pick this car up new in the Munich dealership in 1985, where would all this stuff be?
    Photos would be great!
    Thanks!
    Franny
  22. BigTex
    79,407
    Houston, Texas
    Bubba
    In the early 308s, both rolls were depicted in the Owners Manual lying in the spare tire under the front bonnet.
    Or maybe just the smaller tool roll.
    My 1977s have the rubber straps in the LH rear trunk, that make a handy place for the jack roll (or maybe a Fire extinguisher!!)
    Hazard triangle (Euro only) goes in the Jack Kit.
    Trouble light could go into the console storage (on a GTB!!!)
  23. BigTex
    79,407
    Houston, Texas
    Bubba
    Two plugs, one of each recommended heat range...one is colder for Track Use.
  24. BigTex
    79,407
    Houston, Texas
    Bubba
    You need an Allen wrench to change gear or engine oil......the drain plugs are a recessed hex.
    Not a Factory Tool item, though.
  25. robo330
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Steven,
    Ref: #469. I am interested in the Champion Spark Plugs if they are still for sale. All 4 or 2, whichever you want to sell me. My address is robertsonpdt at comcast dot net Thanks!
