Unplugging gas cap switch on 575M | FerrariChat
Discussion in '456/550/575' started by Boy Wonder, Oct 29, 2021.
Tags:
  1. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    173
    Boulder, CO
    Fred Wolf
    Having trouble figuring how to unplug the gas cap switch on my 575M
    seems so simple
    i can't operate the gas cap from the switch,, and am starting to trouble- shoot starting with the switch
    A simple switch, but it has at least 4 wires on it, the Blk and White , i assume are 12 v power
    does anyone have a wiring diagram on this?
    thanks
    Fred
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,657
    Ian Riddell
    No wiring diagrams are available for the 575 (outside dealer workshops).
    Have you tried replacing the fuse or swapping relays?
    Possibly two of the wires are simply for switch backlighting (usually black and yellow/red on Ferraris). The other wires will be power from the fuse (maybe a single colour) and perhaps a striped wire for the fuel lid actuator relay.
    I'm not really sure. I haven't seen a car of this era with a relay in the circuit. Does the 575 need the ignition switch to be on to open the lid?
  3. vandevanterSH
    vandevanterSH F1 Rookie Silver Subscribed
    Jan 27, 2005
    3,432
    AR
    Stephen Van Devanter
    "i can't operate the gas cap from the switch,,"
    What is the problem with the gas cap cover? Do you hear the solenoid when pushing the switch?
    Qavion likes this.
  4. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    173
    Boulder, CO
    Fred Wolf
    I am going to look at the fuse, but i assumed the trunk latch , which works fine, would be on the same fuse
    and .. NO . the solenoid doesn't click,, so i am starting with the switch,, will check the fuse, and relay
    thanks. will keep you posted
  5. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    173
    Boulder, CO
    Fred Wolf
    thats an interesting thought, i will test , but i would think the answer is NO ,, also as they say,, when all else fails, read the manual
    Qavion likes this.
  6. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    The manual won't bring you very far. Quavion will.
    Qavion likes this.
  7. Qavion
    Feb 20, 2015
    14,657
    Ian Riddell
    Good point. I forgot that both were on the same fuse. I don't understand why the trunk latch and fuel lid are on the same relay though. Since the two are unrelated, it must be for power. But why would a relay be required at all unless there was some other interlock (like ignition power or, perhaps, vehicle speed)?
    (EDIT) The "frunk" on the Ferrari 360 Spider has an ignition requirement for security reasons. Also, child safety locks on later cars have a speed requirement for full frunk unlocking. But there is a dedicated (separate) relay for that function
  8. tazandjan
    tazandjan Three Time F1 World Champ Lifetime Rossa Owner
    39,402
    Did you try swapping out the trunk release switch for the fuel door release switch? Pretty much identical except for the graphics.
    Qavion likes this.
  9. Qavion
    Feb 20, 2015
    14,657
    Ian Riddell
    Terry, do you need the ignition to be on for trunk and gas cap operation on the 575M?
    It's not mentioned in the 575 Owner's Handbook, but neither is it mentioned in the 550 WSM (and the 550 fuel cap is powered via fuse 4 which needs the ignition to be on).
  10. vandevanterSH
    Jan 27, 2005
    3,432
    AR
    " do you need the ignition to be on for trunk and gas cap operation on the 575M? "
    Both release with ignition off.
    Qavion likes this.
  11. tazandjan
    39,402
    Affirmative.
    Qavion likes this.
  12. Qavion
    Feb 20, 2015
    14,657
    Ian Riddell
    Thanks, guys.... So the relay must have some other function other than ignition power.
    Speed? Volunteers to open the gas cap/trunk at > 5kph ??? :D
  13. Boy Wonder
    Boy Wonder Karting
    May 23, 2014
    173
    Boulder, CO
    Fred Wolf
    i didn;t check further as i am pondering the purchase of a 250GT for 100 Mil USD. That car has a simple gas cap what i can manage (saw that post on F Life )
    however , i did check the voltages at the switch, and i do have 12V, another however, i can;t figure out how to disconnect the plug/ switch in order to try the other trunk latch switch
    BTW if you are looking for a another in your stable, look no further than
    https://www.***********.com/threads/selling-a-ferrari-250-gto-series-1-available-only-till-sunday.60152/?utm_source=threadloom&utm_medium=email&utm_campaign=ed283&utm_content=iss179#post-737519
    I am sure you can manage it if you return some of those beer cans kicking around in your garage.
    I backed out because it doesn;t have a radio , not sure about the heater
