Unscratchable Lever Bezel Labels for Dinos | Page 2 | FerrariChat
Discussion in '206/246' started by Verell, Jun 4, 2008.
  1. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,502
    Germany
    Matthias
    correct Bob, between the seats in the middle console
  2. GermanDino
    Aug 14, 2007
    3,502
    Germany
    Matthias
    same on my M-series #01406, but the right plate blank
  3. jvj
    jvj Rookie
    Sep 18, 2009
    48
    South Australia
    Vince
    #28 jvj, Feb 14, 2012
    Quote:
    can we have the chassis no. please, I have never seen this one before...
    but I have seen a blank plate on some M-series...
    can please all M-series owner post pictures of their levers with chassis no`s please
    interesting stuff
    regards Matthias
    #01616 levers here (UK right hand drive GT/M collected from factory 8 March 71)
    regards, Vince
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #29 Verell, Feb 15, 2012
    Just received this from my customer:
    So he has the correct lever combination & when I get the O-down arrow plates I can supply a complete set of correct unscratchable lever label plates for his car!
    My thanks to all of you for your advise & assistance on helping with this issue!
    Hmm, is it possible the blank plate is a O&arrow plate with the icons worn off?
  5. Mark Shannon
    Mark Shannon Formula 3
    1,242
    Surrey, UK
    #30 Mark Shannon, Feb 16, 2012
  6. GermanDino
    Aug 14, 2007
    3,502
    Germany
    Matthias
    yes, it seems it`s original on early E-series only.....
    crazy Italians....
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #32 Verell, Mar 5, 2012
    The O/down arrow label plates just came in!!!
    Unobtainium can now supply two more label plate sets, see photos below.
    Ordering instructions are in my catalog, see: www.UnobtainiumSupply.com.
    1st photo: Lever Label Plate Set, Unscratchable, Dinos, Euro w/2 heaters (1-temp & 1-choke w/red & blue dots, 2-DEF)
    2nd photo: Lever Label Plate Set, Unscratchable, Dinos, Euro w/2 heaters (1-O&down arrow, 1-temp & 1-choke w/red & blue dots, 1-DEF)
    (Color miss-match is because I photoshopped the 1st photo to paste in a picture of the new O&down arrow label)
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    cross posted from Technical Q&A:
    solly,
    Yes, I still have what you need for your series 246 GTS, series E (1974).
    I have a limited supply of Unbreakable (solid aluminum) chrome plated bezels in stock. while they last, they are only $75.69 each, $300/set of 4!!! (3 for dash, + 1 for CHOKE on console).
    I also supply: Lever Label Plate Set, Unscratchable, Dinos (1-TEMP w/red & blue dots, 2-DEF,1-CHOKE) 246 Dino $95.00. Sold as complete sets to ensure full color match.
    To order click on my name by this post and select: [Send eMAIL to Verell]
    Sorry I haven't worked on a 246's bezels. However, from looking at the SPC it looks like it's either reach up under, or pull the dash. Can anyone help with this?
  9. DinoDriver
    DinoDriver Formula Junior
    Mar 14, 2005
    537
    Leesburg, VA
    Bill Ebert
    Solly, I've replaced all my slide controls including the choke. For the 3 on the dash, go in from the bottom. No need to pull the dash. You may need to remove the voltage regulator for better access . . . I vaguely remember that helping but not sure. I did remove the passenger seat so I could lay down a blanket in the passenger footwell for comfort as you will be on your back for awhile. It helps to have small hands, small tools and a lot of patience. BUT, it's well worth the effort!
    Bill
  10. pshoejberg
    pshoejberg Formula 3
    1,864
    Denmark
    Peter H
    #35 pshoejberg, Sep 10, 2013
    Hi Matthias and all other experts in interior,
    I noticed that I have one blank lever bezel in my early L series #504 and wondered if that is due to wear and tear or if it is purpose made from factory. I just ordered a set of bezels from Verell, but he had no blank bezels in stock since he's not sure if these blanks are period correct. What is your opinion; should it be blank or is it a worn "0 to arrow" label?
    Regards
    Peter
  11. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Looks to be worn off, should be first one on left in post #32 (DEF; 0<-><-).
    I did a quick check on 4 L's and they are all the same.
    Carefully check for any signs of remaining marks before declaring it a blank.
  12. pshoejberg
    1,864
    Denmark
    Peter H
    Thanks a lot!
    Close inspection revealed slight traces of the "DEF" marks on the left side of the label. Verell was on the right track. Case closed.
    Peter
  13. GermanDino
    Aug 14, 2007
    3,502
    Germany
    Matthias
    I would agree
  14. rosso dino
    rosso dino Karting
    Mar 5, 2009
    195
    #39 rosso dino, Sep 10, 2013
  15. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Glad you are getting the correct set.
    You may wear the satin clear topcoat off the Unscratchable lever labels you're receiving, but you won't wear the lettering & icons off, they are under a layer of clear synthetic sapphire!! W/o the clear coating the labels can be cleaned with steel wool & pumice without damage!!!
  16. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    There are two bezels for the Dino in the catalog and I'm unsure which is correct for a 1972 246 GTS Euro version, any help possible?
    http://www.unobtainiumsupply.com/attachments/File/UnobtainiumSupply_Product_List.PDF
    60044302-BEZL Bezel, Lever Chrome Unbreakable Al (See our matching Unscratchable Label Plate Sets) 308GTS/B Can be used on: Dinos, 400, Daytona, others 2 oz 8 oz/4 $129.00/bezel $516.00/4 bezels
    60548100-BEZL Bezel, Lever Early Chrome Unbreakable Al, w/groove on tab, 1 hole w/rounded ends (See our matching Unscratchable Label Plate Sets) 206/246, 365 GTB4, Boxer, others 2 oz 8 oz/4 $75.69/bezel NOTE: Supply limited
    Thank you
  17. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #42 Verell, Aug 6, 2014
    60548100-BEZL should be the correct one, they have the groove on the lever mounting tab, and the small, rounded end hole for the lever mounting pin. See pictures below.
    You're lucky, I still have some in stock.
    BTW, the 60044302-BEZL is sold out & I'm having trouble finding a shop that can/will make them at a reasonable price. It can be used on a Dino, but takes a bit of work as it doesn't have the groove on the tab's back & the mounting hole may need some rework. Also, the corners of the top are more rounded than the original Dino part.
