Unsprung weight and Active suspension | FerrariChat
Discussion in '360/430' started by Some Guy in the sky, May 10, 2022.
Tags:
  1. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    361
    I have a hypothetical that I am hoping someone will be able to answer. If I reduce the unsprung weight by about 6 lbs for each front wheel and about 8 lbs for each rear wheel, will the active suspension freak out? Is there a +/- weight window per wheel that needs to be maintained for the suspension to perform as intended?
  2. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,618
    San Jose
    dc
    360 or 430? I would think the system would freak out if you just did some of the wheels and not all of them.
  3. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,901
    Central NJ
    Dominick
    I believe there would be zero difference unless size is different
    The sensors monitor changes in the different axes including pitch roll yaw
  4. windsock
    windsock Formula 3
    1,151
    System is not that sophisticated it will not care
  5. Some Guy in the sky
    Sep 19, 2018
    361
    I finally got the new rims and tires on. The weight savings on the back was 10 pounds per side and the front was 8 pounds per side. The car did not complain in any mode (sport on, sport off, asr) in all gears. One thing I will say is the car drives much much smoother. There are 3 roads in my area that are so bumpy I have to switch sport mode off but with these new rims and tires the bumps were very mild and its feels like the suspension system was designed for the unsprung weight that I am now currently running. .
    kes7u likes this.
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,775
    The sensors measure vertical acceleration and react to it. There isn't a sophisticated model based on unsprung weight.
  7. Mario Andretti
    Mario Andretti Formula 3
    1,776
    Boston
    What car is this, what kind of rims? Pics or it never happened !
  8. Some Guy in the sky
    Sep 19, 2018
    361
    360 with forged aluminum BBS rims (re1347 front and re1348 rear) and Micheline Pilot sport 4S (225/45 front 285/40 rear). Pics will take awhile since I am away from the car. So until then, it didn't happen.
  9. Ferrarista98
    Ferrarista98 Formula Junior
    284
    Jason L
    8 and 10 lbs a corner is a lot! What did you have on there before?
  10. Some Guy in the sky
    Sep 19, 2018
    361
    Stock starfish rims with stock size Michelin Pilot Sport A/S 3+
