UPDATE: 348 lug bolts work for 355 rims... | FerrariChat
Discussion in '348/355' started by Husker, Jan 8, 2005.
  1. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    I just wanted to let everyone know, I successfully mounted 355 rims on my 348 today using the 348 lug bolts with no issues whatsoever. Legend had it that these bolts didn't have sufficient length to adequately hold the wheel on. This is incorrect - the 348 lug bolt actually has a very slightly longer SHAFT length, so it works just fine.
    So...if you're going to mount 355 wheels on your 348, use your 348 lug bolts!
    I will be posting pictures soon of the "new look". Believe me, it makes a huge difference on the car.
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Well blow me down!!! That is very interesting. I wonder if that holds true for all of the 348 model years? I'm gonna measure my bolts when I get home. Now to stir the pot even more, I wonder if the 348 bolts will work with 512tr rims? Hummmmm??? I hope so.
  3. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Ernie...Lyle Tanner measured the shaft length of the standard lug bolt for the 348ts (mine's a 1990) at 55.5 mm, about 3 mm LONGER than the F355 standard lug bolt. That was my first clue that everything was going to be OK. I was actually more worried that they would be too long, but again, everything turned out OK.
  4. 348SStb
    348SStb F1 Rookie
    It seems to me that 22 millimeter lug bolts are pretty standard on Ferraris.
    I base this supposition on the fact that my Dad's 360 uses the same size (22mm) lug bolts as my 348.
  5. Husker
    Dec 31, 2003
    11,792
    western hemisphere
    Dave, I know what a stickler you are for originality. I am pretty much the same way. But I can tell you this, if you put the 355 rim on your car, you'll never look back.
  6. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Shucks, I wish I'd known this was a big question... I've done quite a bit of research on lug bolts, 348 all seem to be compatible (Not sure about the Enzo), but it seems that everything newer (except for the crazy long rears on US 348s of some years) are about the same length. And isn't the length more like 55 vs 52 mm? Where's the 22? (That's from memory about the exact length, but I'm quite confident in the 348/355/360/550 using approximately the same lug bolts.)
  7. Steve Magnusson
    26,784
    22 mm is the lugbolt head size (which they all seem to be).
  8. 348paul
    348paul Formula 3
    Dec 27, 2002
    1,098
    Kent - UK
    Paul Hill
    Unless you have the later USA 94 car with the wider track rear wheels - these use 80mm bolts!
    http://ferrarichat.com/forum/showthread.php?t=44168
    Paul
  9. polartech
    polartech Karting
    Mar 4, 2004
    228
    East Yorkshire
    Geoff
    Well thanks... you`ve just saved me 180 quid or so ;-)
