Update: Adjustable cam pulley | Page 6 | FerrariChat
Discussion in 'Technical Q&A' started by smg2, Jan 25, 2006.
  1. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    So, now that it appears we've all moved on... :)
    Can I gently ask that we return to our regularly scheduled post #108?
    Paul bumped this thread forward with important thought and question. He's put what appears to be quite a bit of time trying to figure this stuff out. Stuff I don't have answers for but that has impact to me as well. Can we fall back and pick up where Paul was?
    Thanks! :)
  2. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,868
    The twilight zone
    I thought it was only the 328s that had a different cam pulley bore.
  3. dell550
    dell550 Karting
    Aug 24, 2005
    209
    London
    george c
    #128 dell550, Sep 28, 2007
    Hey just happened across this thread-been making these for my 308 race engines for the last 10 years with no problems-currently out of stock but a new batch will be ready in 6-8 weeks and will then fix prices if any body wants them.I also have drawings for 328 and Testa Rossa pulleys.
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    #129 smg2, Sep 28, 2007
    Okay guys here's the list of part numbers to model. it's in a excel formatt. these pullies also are used by the 512 BB/i and 365 GT4/BB, 288GTO and 208 turbo. I haven't crossed over yrs to part number on them yet.
    if you try and cross reference by part number it'll get you screwed up as the documentation supersedes itself with out being correct.
    hope this helps.
  5. 308tr6
    308tr6 Formula Junior
    Dec 23, 2003
    466
    SDakota
    Rico
    Excuse my ignorance here, but reading back I am a bit confused on this thread. What exactly is on the market and at what price, and from whom? Obviously I haven't followed this....but interested. So any help to us less informed?
  6. Moku
    Moku Karting
    Dec 17, 2004
    107
    Santa Rosa, CA
    Rob & Jody
    Scott McGehee (smg2) designed and now manufactures the sprocket set shown in the pictures in post 121 above. In addition to providing the ability to easily manipulate timing, they also utilize a more modern belt profile that pushes the belt replacement interval out to about 600 years / 2 million miles. Whichever occurs first, of course... :) I would contact Scott directly for additional info.
    I have no knowledge of what George has produced. But there are quite a few things in that picture above I want to know more about! :)
  7. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    George C., I may be interested in a set, depending on your pricing. I have a late-1977 308 GTB USA model, #23227..
    Let us know..
    Greg
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Looks like the same old original OEM belt with straight aluminum pulleys. Sorry, but its not gaining anything over the stock pulleys other than being prettier and maybe slightly lighter, unless thier adjustable.
  9. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Right, and even if they ARE adjustable, I want the added benefit of Scott's, which utilizes newer, more robust belt design than the 20-30 year old style of the stock belts.
  10. 308tr6
    Dec 23, 2003
    466
    SDakota
    Rico
    So what is the cost of Scott's system - ballpark at least...
  11. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,286
    Illinois
    I seem to remember in that thread that these new items were individually constructed so the majority of the cost was in the time,.........something like $10K. I also do not know if the belts were yet designed, although it shouldn't be that hard. The issue is how many does one make for cam pulleys that aren't in mass production? Belts would probably be expensive as well.
    There was also the issue of testing the new design before selling them.
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    the belts are a new design but being used by mitsubishi for the Evo. so they are off the shelf, depending upon location i.e. Napa etc they run about $16~$25 per belt. the original run thru sold at $1200 per set, these due to cost increase on materials and labor will be around $1500 per set, which this time will include the belt as I can get them wholesale direct now.
    I have just over 20k miles on mine and they are still going strong with zero problems. Gates designed the life of the belt for 100k miles.
  13. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Scott,
    I was going thru my private Fchat archives & came across this in Ed Gault's thread about his new cam system:
    Isn't this comment relevant to your system's design as well?
    I'm starting my major service, & will be finally installing the new belt system I purchased from you way back when.
  15. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    in talking with Gates, there should be no difference in the tension needed. in fact most of the new timing belt designs use a very high tension spring vs the one we have. hope that helps.
  16. SonomaRik
    SonomaRik F1 Veteran
    Scott;
    does any of this translate over to the 348 series too?
  17. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I would think the setting tension on the belt to be of almost minimal significance unless at the extremes of tension. I would imagine the running engine torque pulling the belt over the tensioner should put far greater strains on the belt, especially at low engine speed.
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Scott,
    Thanks for clarifying about belt tension. Brought it up because I didn't remember it being discussed on any of the new belt system posts.
    Paul,
    The tensioner is actually under minimum pressure from the belt when the engine is accelerating the cams. The engine is pulling on the long straight section to accelerate & rotate the cams counterclockwise, so max belt tension is between the drive gear & the 2 cam gears. Any slack in the belt will be on the belt section around the tensioner pulley.
    Or were you just referring to the fact that the belt would be being bent around the tensioner at a fairly sharp angle while traveling at fairly high speed?
  19. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    #144 smg2, Mar 6, 2008
  20. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    Oooh those look nice.
    Now i have to see what kind of funds i'll have after my gearbox/engine rebuild.:eek:
    Scott, you doing payment plans?? ;)
  21. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    MODERATOR NOTE:
    We're going to treat this stuff like Verell's and "tolerate" it as a low-volume non-sponsor...
    Scott, we appreciate the innovation here, and that you made some extra sets of this unique stuff you're making for yourself!
  22. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Sorta. Actually I was imagining the rising and falling tension as the cams flip over out of sequence with the power pulses coming from the crankshaft. At idle speed it must throw some pretty dramatic loads on the timing drive system, much more than at higher speeds.
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Hmm, possibly,
    My SWAG is that the dynamic peaks would be at higher engine RPM as the valves are being accelerated to much higher velocities as each lobe lifts them. Just a gut as I don't have any way of simulating the dynamic loading tho.
  24. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,518
    Dumpster Fire #31
    SMG
    Okay I've had some requests for the earlier carb'd 308's. here's the thing, there are 3 versions of the lower drive pulleys and 2 versions of the cam pulleys. the lower drive pulleys were design changes to the timing case. and the difference in the cam pulleys is the 308/328 cams.
    I have made 10 sets each for the 308 and 328, however on the 308 it's for the late carb'd thru i. If there are some sets available out of the 308 ones I can have new lower drives made for the early carb'd 308's. but as of right now I don't have any available for them. Ferrari tracked the change by crankcase numbers but that seems to have been an iffy documentation as well. the crankcase numbers are some where in the thread, I'll digg them up and post again.
    I can get the belts too to make it a one stop deal. let me check on availability for that many belts.
  25. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Scott,
    Gates cross - references the NAPA NBH 250288 to a Gates T288 which is the belt for a Mitsubishi Mirage 1997-02 1.8L 4-Cyl. Belts are available from: Gates T288 - RockAuto.com for $ 25.79 or NAPA NBH 250288 for $42.49!
    The Gates T288 description looks correct, so is T2088 a typo?
