update on my belt noise | FerrariChat
Discussion in 'Technical Q&A' started by jr328gtb, Dec 23, 2003.
  1. jr328gtb
    jr328gtb Karting
    May 10, 2003
    96
    New Jersey
    John Roberts
    A while back, I posted about some belt noise in my 328. It was kind of a flapping sound that went away after a while of driving. I recently had the car serviced and it turned out to be some slight rust on the cam pulleys. My mechanic removed belts, cleaned, lubed and replaced. He also suggested running a dehumidifier in the garage to keep moisture down.
    question - anyone had a similar problem in the past....anything preventitive that can be done or is it just circumstantial based on wash conditions, moisture level in garage etc
    thanks
  2. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    JR
    328's are known for belt noise, I was told this is caused by a build up of static in the belts and that the only long term way to resolve it is to replace the belts, maybe by removing them you mech has discharged them or did he replace with new anyway?
  3. jbanzai
    jbanzai Formula 3
    Feb 1, 2002
    1,564
    Madrid, Spain
    Julio
    I had a similar noice coming from the belts about 3 weeks ago. It was a really cold and wet day, early in the morning. At the garage was probably 5 C, out was below 0 C, there was ice in the cars outside.
    When I started the car I had that flaping sound for about 15 seconds, then it was gone. I haven't heard that noise again.
    - Julio.
  4. KKSBA
    KKSBA F1 World Champ
    14,920
    SBarbara-La Jolla CA
    KKSBA
    You know, I just started hearing a noise like that recently. It has been fairly cold, well for Santa Barbara anyway. It goes away after 30 seconds. It only does it for the first start of the day.
    I had the belts and tensioner bearings done about 6 months ago and maybe 2000 miles.
  5. jbrosseau
    jbrosseau Karting
    Nov 26, 2003
    182
    kirkland,wa
    joe brosseau
    my 308's belts will make a slapping sound on colder mornings. only for 5-10 seconds. after that it will not do it for the rest of the day. in the spring and summer they never do this. so i think it may be due to colder weather and in some cases rust on the pulleys. for you guys in colder areas try using some belt conditioner on the belts to keep them from getting to stiff.
