Updated list of parts for sale - 308, 328, Mondial, Testarossa, Daytona, Dino... | FerrariChat
Discussion in 'Ad Archives' started by i-velocita, Oct 9, 2013.
Thread Status:
Not open for further replies.
  1. i-velocita
    i-velocita F1 Rookie
    2,520
    Colorado
    James
    #1 i-velocita, Oct 9, 2013
    Updated list of parts - 308, 328, Mondial, Testarossa, Daytona, Dino...
    Posted selected pics. Please PM with questions.
    Thanks...Jim
    EXTERIOR/BODY
    -Ferrari fender shields, genuine cloisonné, finest quality reproductions, NEW @ $245/pair (fit Mondial/308/328/348/355/360/430/456/550/575/599/612/California,others)
    -308 front trunk spare wheel tub (covers brake booster) @ $175
    -308 washer fluid reservoir with pump and lid @ $165
    -308 hood (non QV) black @ $350
    -308 hood (non QV) silver, excellent @ $500
    -328 doors, rust free, complete w/glass, mechanicals, electricals @ $950 each
    -308 gravel guard (fender liner panel) left front @$50
    -308 gravel guard (fender liner panel) right front @ $50
    -308/328 undercar access panel @ $45
    -308 left shield, P/N 600770700, NEW @ $35
    -308 right exterior door handle @ $75
    -308/328 gts rear quarter glass, L&R @ $150 ea
    -308/328 gtb rear quarter glass, R @ $150
    -308/328 gts rear quarter window gaskets, L&R @ $50 ea
    -308 left catalytic converter cooling duct @ $50
    -308/328 front trunk latches @ $35 each
    -308/328 rear deck lid latches @ $35 each
    -308/328 rear deck lid hinges @ $45 each
    -308 passenger door latch assembly @ $150
    -308 front bumper, U.S. @ offer
    -308 front grille, U.S. @ $600
    -308gt4 front grille cavalino @ $75
    -308gt4 rear muffler shroud/grille @ offer
    -Testarossa rear grilles @ $ offer
    -Mondial rear quarter panel, right @ $500
    INTERIOR
    -308 gts QV sun visors, L&R @ $125/pair
    -308 gtb sun visors, L&R @ $65/pair
    -308gt4 leather door panels, black @ $700/pair
    -308 seats, tan @ $1800/pair
    -308 seats, tan w/new correct leather @ $2800/pair
    -88 Ferrari Mondial dash windshield vent trims @ $100
    -308 fiberglass interior rear trunk pieces, left, right and center @ $50 each
    -308 complete rear trunk carpet set, OEM Ferrari @ $200
    TOOL/JACK
    -Ferrari wrench, 9/8mm, “Ferrari, KRAVM” on handle, NEW @ $50
    -275/330/365 reproduction Ferrari flat/standard blade screwdriver, NEW @ $150
    ENGINE/IGNITION/FUEL
    -308/Mondial (4) camshafts @ offer
    -308 distributor cap bases, front & rear @ $65 each
    -308 Cavis plug wire set @ $100
    -308 spark plug extenders, 8 @ offer
    -308 emissions equipment for carb car, smog pump (w/upper bracket, heat shield, tube), charcoal canister, vacuum sphere, valves, hoses, air injection rail @ $675/all
    -308 smog pump lower bracket @ $150
    -308 engine crank shield @ $50
    -308 crankshaft damper/pulley @ $250
    -308 rear header, 2 @ $400 ea
    -308 catalytic converters (pair from 81 gtb, empty) @ offer
    -308 fuel crossover pipe @ offer
    -308gt4 fuel crossover pipe @ offer
    -308gt4 fuel tank, right @ offer
    COOLING
    -308 coolant pipes @ $65 each
    -308 coolant pipes - long under body @ $125 each
    -308 radiator fan (black plastic) @ $50
    A/C, HEATER
    -308 A/C compressor bracket upper @ $100
    -308 A/C compressor bracket lower @ $25
    -308 A/C dryer, right, includes hoses, temp sensor and t-stat @ $95
    -308 A/C dryer, left @ $50
    -308 condensor @ $75
    -308 heat/AC blower fans assemblies, (3) @ offer
    -308 heat/AC blower fan motors, (2) @ offer
    ELECTRICAL, LIGHTING
    -308 gauge pod wiring harness @ $100
    -308/Mondial remanufactured Bosch alternator, 65A, (2) @ $125 ea
    -308/Mondial OEM Bosch starter, 2 @ $400 ea (no core charge)
    -308/Mondial OEM Fiat brand starter @ $400 (no core charge)
    -308/Mondial seat belt relay/ecu (60528200) @ $50
    -308/Mondial relay/switch (112198) @ $75
    -328 right window motor @ $125
    -308 left headlight motor and bracket @ $175
    -308 “slow down cyl 1-4” lens @ $10
    -308 amber right front turn signal lens, OEM Carello – NOT reproduction @ $100
    -308 fender parking light lens w/gasket 2 @ $25 ea
    -308 radiator fan motors @ $85 ea
    BRAKES
    -308/Testarossa brake & clutch pedal box (includes pedals) @ $500
    -308 hand brake lever assembly (2) @ $175 each
    -308 front calipers, (2) L & (2) R @ $250 each
    -308 rear rotor @ $100
    -Testarossa front calipers L&R @ $350 each
    -Testarossa rear calipers L&R @ $350 each
    SUSPENSION & STEERING
    -308 steering column w/lock and ignition switch/key @ $1500/offer
    -308 steering rack clamps/mounts, 2 @ $35 each
    -308 right rear hub assembly @ $350
    -308 right rear hub assembly (needs rebuild) @ $200
    -308 right rear upper control arm @ $200
    -308 right rear lower control arm @ $200
    -308 front sway bar @ $150
    -308 shocks and springs, 4 @ $650
    OLDER FERRARI/MASERATI
    -Daytona grille @ $1000
    -Daytona right door @ $1000
    -Daytona assorted right door hardware @ $500
    -Daytona window motor and regulator @ $250
    -Daytona/365/246 column switch @ $850
    -246 Dino door hardware L&R + misc parts @ $1000
    -246 Dino parts manual @ $500
    -246 Dino misc lights @ offer
    -246 Dino dash vent @ $200
    -246 Dino vent/quarter window lever/latch @ $100
    -330gtc rear center bumper, headlight trim and door trim @ $1000
    -365gtc/4 front quarter panels, L&R @ $500 ea
    -250gt Lusso windshield, NEW @ $1000
    -Maserati Indy windshields (2), NEW @ $1000 ea
    -Maserati Indy windshield gasket, NEW @ $300
  2. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    Do you have any pics of the cooling pipes and condenser you could post or email?
    Thanks.
  3. i-velocita
    2,520
    Colorado
    James
    #3 i-velocita, Oct 15, 2013
  4. George Vosburgh
    George Vosburgh F1 Rookie
    Hi Jim,
    I'm currently looking for engine plaques (the metal signs in the engine compartment)
    Do you have anything?
    Thanks,
    George
  5. i-velocita
    2,520
    Colorado
    James
    Possibly George. Let me check. Best...Jim
  6. i-velocita
    2,520
    Colorado
    James
    #6 i-velocita, Oct 16, 2013
  7. George Vosburgh
    Hey Jim we have a winner!
    I'll take the Ferrari Agip badge.
    PM me and we we'll work it out.
  8. Jdubbya
    Jdubbya The $10 Trillion Man
    37,450
    PNW
    Jim,
    I'm looking for a couple small interior parts. One is the half round section that normally covers the bottom of the steering column. The other is the vent that ties between the lower A/C plenum and the dash vents. If you need a better description of either let me know and I'll look up the part drawings. Both for a '78 308 by the way. :)
    Thanks,
  9. i-velocita
    2,520
    Colorado
    James
    #9 i-velocita, Oct 18, 2013
    Hi John,
    Thanks for your inquiry.
    Sorry, don't have those parts. I'll keep an eye out though.
    These might be what you are looking for...
    60092103 COLUMN COVER, 60375021 A/C OUTLET CONVEYOR
    Best...Jim
  10. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,334
    Encino, Ca
    Carl T
    Jim I'm interested in the Ferrari cavallino flat metal badge if it is in fact a grille badge. PM me the size and price. Thanks, Carl
  11. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    If you ever come across a set of Euro Bumpers for the 308 let me know!
  12. i-velocita
    2,520
    Colorado
    James
    Will do!
  13. i-velocita
    2,520
    Colorado
    James
    Hi Carl,
    Sorry, the horse sold.
    Best...Jim
  14. Jdubbya
    37,450
    PNW
    Jim.
    I have the conveyor, I just need the pipe that ties into the back of it..60133204 [60133204 PIPE] and yes I think you have the right number for the cover. Thanks for the reply! I'll keep an eye out.
    Thanks,
  15. Mauri nowytarger
    Nov 6, 2013
    1
    I am interested in the 2 front quarters for a 365gtc4 offered for sale.
    I would like an image of the parts, please ,
  16. i-velocita
    2,520
    Colorado
    James
    #16 i-velocita, Nov 6, 2013
  17. radrickroth
    radrickroth Karting
    144
    Virginia, USA
    Rick Rothenberger
    1970 Ferrari GTB/4 Daytona Competition.
    1st car built after original 13-14 (sanctioned by Ferrari factory) to be built by Ferrari trained mechanic with all OEM parts.
    Ulf 'Barbarosa' Boman from Sweden, Builder, driver, mechanic.
    Raced at Silverstone, Falkenberg, and Grand Bahama in the early 80s.
    Many Brian Redman, Ulf Boman organized events. Nick Mason's cars, among others, were present.
    2nd owner, Rick Rothenberger from Pennsylvania.
    Raced in a variety of Mid Ohio, Watkins Glen, and Moroso Speedway SVRA events.
    This engine was the spare to this car:
    365 GTB/4 engine 4 cam
    It was bought in 1986 from Bob Wallace of Phoenix, AZ. (well known Lamborghini and Ferrari mechanic)
    At that time he sold it newly rebuilt and spec'd to my dad for use as a spare to his Daytona Comp Car
    Engine totally stock, street Daytona engine. No aftermarket parts. Unmolested.
    The engine has never been in a car from that time or used at all.
    Always stored in climate control and the crank turns freely.
    S/N B2016
    Complete engine with (2) distributers, flywheel and (6) Weber carbs
    No headers
    [email protected]
  18. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,178
    Austin, TX USA
    Greg
    Jim,
    Are you able to get a gas filler door for an 87 328? It's probably identical to a 308 gas filler door. Mine broke off today at both the upper and lower hinge pin attach points as I was filling up; obviously old Italian plastic gets brittle with age!
    I can probably super/gorilla glue it back together, but if I can find a working one at a reasonable price, I'll get it…
    Thanks,
    Greg
    Houston
    87 328 GTB
  19. i-velocita
    2,520
    Colorado
    James
    Hi Greg,
    Sorry to hear about your fuel door! I don't have one at this time but will keep an eye out.
    Best...Jim
  20. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,178
    Austin, TX USA
    Greg
    Thanks Jim,
    Greg
  21. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    422
    Singapore
    BCChoo
    Jim do you have the pic of the seats with new leather ?
  22. i-velocita
    2,520
    Colorado
    James
    #22 i-velocita, May 18, 2014
    Hi Leslie,
    Sorry to take so long.
    Here is a pic of my seats. I'll post more tomorrow.
    Seats are upholstered to a very high standard. Top quality Austrian hides purchased through Bill Hirsch. Original Ferrari Beige color/texture (Connolly 3218 Saddle).
    Adjusters are like new.
    Best...Jim
  23. HotShoe
    HotShoe F1 Veteran
    7,524
    Lake Worth, FL
    Anthony Lauro
    Do you know if by chance the hoods are interchangeable? I need a donor for a custom idea I have.
  24. i-velocita
    2,520
    Colorado
    James
    Sorry, all of my hoods have sold.
